    2 minutes ago, Hans_Raven said:
    Is there a way to easily translate this to another z-wave remote control with multiple buttons? I have a RC-90 where each button can be given different tasks for one press, double press, and "long" press. I tried the below rule where I want to turn on a window lamp that is connected through a Fibaro wall plug. I do not get any error message so it is hard to say what is wrong...
     rule("Remote_entre:centralSceneEvent=='1' => Arbetsrum_fonster:on")
    The <id>:central returns the 'data' part of the CentralSceneEvent, typically {keyId=<x>, keyAttribute='attribute'}
    keyId is the number of the key and 'attribute' is usually 'Pressed', "Hold' etc.
    That's why we can test ex.
    <id>:central.keyId == 1
    or
    <id>:central.keyAttribute == 'Pressed'
    You can check your remote by doing
    and it will log the data structure and you can see what key values it provides.
    However, it may be that your remote sends "SceneActivation" events.
    In that case the rule looks like
    and the rule will log the sceneIds returned.
    Is it possible to arm zone alarm from rule without using scene?
    rule("@00:00 => fibaro.alarm(<partition_id>, 'arm')")
    10 hours ago, jgab said:
    Ok, I managed to trigger one.
    I have pushed v0.5fix15
    Rule
    {type='location', id=<user>, value=<"leave"/"enter">, property=<location id>}
    and remember to self:enableTriggerType({"location"})
    With the "new" location trigger one can do rules like this
    The set of rules keep track of the number of people at home, all, some, and none.
    It can trigger rules with the trigger variables 'allAway', 'allAtHome' and 'someAtHome'
    Now 'allAtHome' causes 'someAtHome' to trigger too - it's easy to modify if you want it exclusive.
    When the QA starts locations are unknown - need some more code to lookup current positions.
    or
    Thanks for getting back so quickly. I'm a real rookie with the eventrunner so maybe I have missed something basic in the coding but I tried your proposals but nothing happens when I push the buttons on my RC-90 remote.  Maybe something completely obvious that is wrong? (I know the remote works as I have used it for activating some simple block scenes etc)
    %% properties
    185 value
    %% events
    22 GeofenceEvent 220
    21 GeofenceEvent 220
    %% globals
    %% autostart
    -- Don't forget to declare triggers from devices in the header!!!
    if dofile and not _EMULATED then _EMULATED={name="EventRunner", id=10} dofile("HC2.lua") end
    _version,_fix = "2.0","B66"  -- July 29, 2019
    -- EventRunner. Event based scheduler/device trigger handler
    -- Copyright 2019 Jan Gabrielsson. All Rights Reserved.
    -- Email: [email protected]
    _sceneName   = "Demo"      -- Set to scene/script name
    _homeTable   = "devicemap" -- Name of your HomeTable variable (fibaro global)
    _HueHubs     = {}          -- Hue bridges, Ex. {{name='Hue',user=_HueUserName,ip=_HueIP}}
    _myNodeRed   = "http://192.168.1.50:1880/eventrunner" -- Ex. used for Event.postRemote(_myNodeRed,{type='test'})
    --if dofile then dofile("credentials.lua") end -- To not accidently commit credentials to Github, or post at forum :-)
    -- E.g. Hue user names, icloud passwords etc. HC2 credentials is set from HC2.lua, but can use same file.
    -- debug flags for various subsystems...
    _debugFlags = {
      post=true,invoke=false,triggers=true,dailys=false,rule=true,ruleTrue=false,hue=false,msgTime=false,
      fcall=true, fglobal=false, fget=true, fother=true
    ---------------- Here you place rules and user code, called once at startup --------------------
    function main()
      local rule = Rule.eval
      local HT =   {                    -- Define your devices
        kontakt = 185,                    --Virtual device home_away arbrum
        Spots_entre = 7,                --Takspotlights entréhallen
        Remote_entre = 187,                --Fjärrkontroll entréhallen
        Gymnastikrum_tak = 12,
        Home_away_switch = 174,            --Fysisk hemma_borta-brytare
        Sovrum_vuxna_tak = 22,            --Taklampa föräldrasovrum
        Sovrum_vuxna_fonster = 124,        --Fönsterlampa föräldrasovrum
        Dressing_room = 27,             --Klädkammare sovrum
        Sovrum_barn = 32,                --Taklampa barnsovrum
        Sovrum_barn_fonster = 126,        --Fönsterlampa barnsovrum
        Badrum_spots = 37,
        Badrum_spegel = 42,
        Badrum_Sonos = 133,
        Tvattstuga_spots = 52,
        Tvattstuga_bank = 47,
        Tvattstuga_rorelse = 164,
        Tvattstuga_temp = 165,
        Tvattstuga_lux = 166,
        Hall_uppe_tak = 57,
        Vardagsrum_tak_kamin = 62,
        Vardagsrum_tak_soffa = 67,
        Vardagsrum_fonster_gavel = 130,
        Vardagsrum_fonster_balkong = 116,
        Koksbord = 77,
        Kok_tak = 87,
        Kok_fonster_gata = 122,
        Kok_fonster_gavel = 120,
        Matsal_tak = 82,
        Matsal_fonster = 147,
        Matsal_skap = 110,
        WC_tak = 92,
        WC_spegel = 93,
        Arbetsrum_tak = 97,
        Arbetsrum_fonster = 114,
        Fasad_entre = 17,
        Fasad_garage = 108,
        Fasad_uterum = 102,
        Fasad_balkong = 72,
        Fasad_forrad = 138,
        PIR = 103,                            --Strålkastare fasad
        Garage_inne = 107,
        Garage_temp = 156,
        Garage_rorelse = 155,
        Garage_lux = 157,
        Forrad_inne = 139
      Util.defvars(HT)                -- Make HomeTable variables available in EventScript
      Util.reverseMapDef(HT)     -- Make HomeTable variable names available for logger
      rule("kontakt:isOff => $Home_Away='Away' ")
      rule("kontakt:isOn => $Home_Away='Home' ")
      rule("@22:18 & $Home_Away=='Away' => Arbetsrum_fonster:off")
      rule("@22:19 & $Home_Away=='Away' => Arbetsrum_fonster:on")
      rule("@22:18 & $Home_Away=='Home' => Arbetsrum_fonster:off")
      rule("@22:19 & $Home_Away=='Home' => Arbetsrum_fonster:on")
      rule("Remote_entre:central.keyID=='1' & keyAttribute=='Pressed' => Arbetsrum_fonster:on")
      rule("Remote_entre:scene=='1' & keyAttribute=='Pressed' => Arbetsrum_fonster:on")
      rule("Remote_entre:central => log('Remote:%s',Remote_entre:central)")
      rule("Remote_entre:scene => log('Remote:%s',Remote_entre:scene)")
    Ok, so you are on the HC2?
    You need to declare the trigger in the header
    Be careful with the capitalisation
    If it happens to be a sceneActivation it's under properties
    Yes, I run it on my HC2 as I'm not authorized to install software on my employer's laptop. It is in my pipeline to install the offline scene emulator on my old and slow Mac Mini but it hasn't happened yet.
    Thanks for the input! Now I'm able to read the code when I push the buttons on the remote but I'm still not able to turn on a light (wallplug) with rule #7. I'm aware that the rule doesn't seem to be complete (ends with an "o") when you read the debug but I double checked the code and it is and goes like this:
    rule("Remote_entre:central.keyId=='1' & keyAttribute=='Pressed' => Arbetsrum_fonster:on"
    I also tried to turn on another wallplug and I get same error message.
    [DEBUG] 22:48:35: Demo - EventRunner v2.0 B66
    [DEBUG] 22:48:35: Fibaro software version: 4.600
    [DEBUG] 22:48:35: HC2 uptime: 311 hours
    [DEBUG] 22:48:35: fibaro:getValue(1,"sunriseHour")="06:06"
    [DEBUG] 22:48:35: fibaro:getValue(1,"sunsetHour")="19:22"
    [DEBUG] 22:48:35: Sunrise 06:06, Sunset 19:22
    [DEBUG] 22:48:35: Hue system inited (experimental)
    [DEBUG] 22:48:35:
    [DEBUG] 22:48:35: Loading rules
    [DEBUG] 22:48:35: Rule:1:kontakt:isOff => $Home_Away='Away'
    [DEBUG] 22:48:35: Rule:2:kontakt:isOn => $Home_Away='Home'
    [DEBUG] 22:48:35: Rule:3:@22:18 & $Home_Away=='Away' => Arbetsrum_fonster:off
    [DEBUG] 22:48:35: Rule:4:@22:19 & $Home_Away=='Away' => Arbetsrum_fonster:on
    [DEBUG] 22:48:35: Rule:5:@22:18 & $Home_Away=='Home' => Arbetsrum_fonster:off
    [DEBUG] 22:48:35: Rule:6:@22:19 & $Home_Away=='Home' => Arbetsrum_fonster:on
    [DEBUG] 22:48:35: Rule:7:Remote_entre:central.keyId=='1' & keyAttribute=='Pressed' => Arbetsrum_fonster:o
    [DEBUG] 22:48:35: Rule:8:Remote_entre:central => log('Remote:%s',Remote_entre:central)
    [DEBUG] 22:48:35:
    [DEBUG] 22:48:35: Scene running
    [DEBUG] 22:48:50: Incoming event:{"type":"event","event":{"type":"CentralSceneEvent","data":{"icon":{},"deviceId":187,"keyId":1,"keyAttribute":"Pressed"}}}
    [DEBUG] 22:48:50: [false]>>'Remote_entre:central.keyId=='1' & keyAttribute=='Pressed' => Arbetsrum_fonster:on'
    [DEBUG] 22:48:50: [{"icon":{},"keyAttribute":"Pressed","keyId":1,"deviceId":187,"timestamp":1599770930}]>>'Remote_entre:central => log('Remote:%s',Remote_entre:central)'
    [DEBUG] 22:48:50: Remote:table: 0x8bc8c08
    Sorry, to log a table in a readable format you need to trosform it to a json string
    log('Remote:%s',tjson(Remote_entre:central))
    'tjson' is the same function as json.encode, just shorter to write.
    However, you do see that the incoming trigger is a CentralsSceneEvent and the keyId is 1 and the keyAttribute is "Pressed".
    The only problem is the rule now.
    You need to test against the value returned from Remote_entre:central
    You could assign it a local variable
    ...but I'm not sure it looks better.
    What I would recommend is to let the different keys post events. (ex. REPressed Remote Entre Pressed)
    Ex.
    Hmm, feel like an idiot here (I actually manage to write some code in R at work) but I'm not getting this to work...
    The above rule doesn't work, I inserted the second and last " but that didn't help. It give this error message when I run it so I guess there is just some basic sign missing in the code:
    The above is ok to run but when I push 1-key on the remote I get this log. What does that "attempting to index non table with key:'keyId' mean?
    Missing parentheses at the end
    index non table means that you do x.y where x is not a table. In this case csl. Because you assign cs, not csl at the start
    You should test against 1 and not '1' as the keyId value in the CS event is a number.
    Thanks for helping out, much appreciated and the parenthesis issue I should have spotted myself. The other part, despite your proposed corrections, still cause a problem (Rule 8 is complete and ends with Arbetsrum_fonster:on")
    It was my fault. Assignment (=) has a lower priority than ‘and’ (&), like in most programming languages. Thus you need to put a parenthesis around it.
    No problem,  now it works!! Thanks again! ?
    So, remotes with keys can be used in various ways
    The above example listens for a code (1-3-2-4) and if input in right order and less than 2s in-between it will post an #codeOK event that can trigger some action
    I have a keyfob with 6 buttons but I like to assign more functions. These simple rules concatenates two keypresses into a two-key code that is posted.
    Ex. #Key1_1  or #Key_4_1
    The keys needs to be pressed within 2s to count as a double code
    This way I have 36 buttons...
    So, continuing with the key events in the previous post.
    One way to structure the rules in EventRunner is to think in "events".
    Actions that causes events to be posted, and actions that are carried out when the events are posted.
    Ex. assume you have a time in the evening when you turn on some lights. Like at sunset. (and the reverse at sunrise) One way to do that is
    A better way is to split it up.
    Define an event, #turnOnLights and create rule that trigger on sunset and post the event. Then another rule that carries out the action when it sees the event.
    It has the same effect but now you can turn on the lights with other actions also.
    Now when we come home before sunset and it's a bit dark we can turn on the light with our remote also.
    ...and we could have a fire alarm that also post #turnOnLights etc.
    So our rule becomes subroutines that can be triggered by posting events. (and events can carry arguments too, like #myEvent{value=42} )
    So, think in "events" :-)
    Hello. I am using ER4 well. I would like to provide additional comments.
    I wish there was a restart button for ER4 and an update confirmation button (or automatic update on-off button, etc.) on the preview screen of ER4. It looks like a good test for home center errors (or other checks).
    Some more use-cases for new comers to  ER.
    1. Turn off light in a room after x minutes of inactivity
    many sensors and many lights
    2. Turn on light decided by current lux or level decided by time or ...
    many lux sensors
    light level depending on time
    3. Remind me of an open window
    4. Randomly turn on lights from a list of lights when global variable 'Away' is set to "true"
    (this could be made more intelligently but works as a simple case...)
    Hi @jgab , I discovered your brilliant Eventrunner4 for myself and have a question right away.
    Is it possible to give a rule a random value?
    for example:
    I use the random values for all of my outdoor lights and shutters. So that nobody recognizes an automatism behind it.
    Thanks for this great job.
    for example:
    Time constants HH:MM(:SS) ex. 10:15 or 10:15:30 is translated to numbers representing the seconds.
    Ex. 10:15 is 3600*10+60*15,  10:15:30 is 3600*10+60*15+30
    This allows us to do arithmetic with time constants as they are treated as numbers by the rules.
    'sunset' in rules is a variable that is set to the current day's sunset time ex. 20:00 (the variable is updated every midnight)
    So this allows us to add offsets to ex. sunset.
     In your example (besides missing the +) it would only randomise -10s to +15s and 5s to 20s
    The time scheduling function '@<expr>' schedules the rule <expr> seconds after midnight - so that's how it works.
    This means that we can also use a fibaro global (or any expression that calculates a valid number)
    assuming that the fibaro global contains a number with seconds after midnight. In fact, when accessing a fibaro global and the content is a string that looks like a time constants (HH:MM(:SS)) it is automatically translated to a number when accessed. So we can set the fibaro global MORNING to the string ex. "07:00" and it works too.
    (another trick here is that if the global changes value the rule is re-scheduled to take into account the global's new value)
    Thanks @jgab , that sounds good, I'll try
