6 minut temu, jgab napisał:
Strange. What happens if you try to push using the fibaro api?
fibaro.alert(alert_type, user_ids, notification_content)
Send custom notification.
  • alert_type – one of the notification types: “email”, “sms” or “push”
  • user_ids – list of user identifiers to send the notification to
  • notification_content – content of the notification to send
Examples:
Send notification with “Test notification” content using email to users with id 2, 3 and 4.
1
fibaro.alert("push", {2,3,4}, "Test notification")
Then i got only one message, and working fine ............WTF :)
    Hmmm, can you try this
    fibaro.alert("push", {2,3,4}, "Test notification",false)
    i.e. with an extra false as 4th argument. Does it go to your phone then?
    Guys,
    If I "push"
    fibaro alert one ID sends to 2 phones,  two different users
    same in ER rule
    succes
    //Sjakie
    false will give message on phone too
    (other rules disabled)
    Then i got only one message, and working fine ............WTF :)>>>>> why I get 2 phones??
    Yes I know my HC3 has his own life??
    //Sjakie
    2 hours ago, AshleyJoseph said:
    Hi Guys
    First attempt at using Event Runner.
    Could someone let me know if the below makes sense or ive missed something?
    Also do you need to set the parameters to use sunrise & sunset or is that something that is already set?
    dblight = 359
    dbfan = 362
    dbhum = 599
    dblux = 598
    dbmotion = 397
      Util.defvars(HT)
      Util.reverseMapDef(HT)
    rule("dbmotion:breached => 06:00..18:00 >> dblight:value=30, 18:00..6:00 >> dblight:value=70")
    rule("trueFor(00:01,dbmotion:safe) => dblight:off")
    You could put the variables in a table (HT). ER4 rules can use Lua globals or variables defined with Util.defvars.
    The "if-then" has the format "|| <test1> >> <actions1> || <test2> >> <actions2> ...
    It reads nicer using a multi-line string [[ ..... ]]
    The usage of a table with values allows you to structure your constants like this
    then you can have a variable named 'light' in some other place than db... like kitchen.light
    Also ok , one message on my phone ..... by running this fibaro.alert("push", {2,20}, "Test notification",false)
    2 and 20 are id's of users
    but on ER when run this :
      rule("@@00:01 => 2:msg=log('push 2')")
      rule("@@00:01 => 20:msg=log('push 20')")
    got push from both
    sunset, sunrise,dawn,dusk are ready constants to use in the rules
    rule("@sunset-00:10 => log('10min before sunset')")
    Thanks @jgab
    I get the following error - Is there anything I need to amend?
    [04.09.2020] [19:59:35] [DEBUG] [QUICKAPP618]: ------------------------------------- Setting up rules (main) -------------------------------------[04.09.2020] [19:59:35] [ERROR] [QUICKAPP618]: Error in 'db.motion:breached =>      || 06:00..18:00 >> db.light:value=30     || 18:00..6:00 >> db.light:value=70     ': ./include/EventRunner.lua:1193: non constant property 'function: 0x11fec320'[04.09.2020] [19:59:35] [ERROR] [QUICKAPP618]: ./include/EventRunner.lua:1982: Main() ERROR:./include/EventRunner.lua:1840: ./include/EventRunner.lua:1193: non constant property 'function: 0x11fec320'
    25 minutes ago, AshleyJoseph said:
    Thanks @jgab
    Sorry, the time must be on format 'HH:MM' - 2 digits for hour and 2 digits for minutes
    Ex. "|| 18:00..06:00 >> db.light:value=70"
    6:00 gives a strange error message as it's interpreted as <device>:<method> where method is '00'...
    Good error messages are hard to implement - lets see if I can improve on this....
    16 godzin temu, jgab napisał:
    But testing on temp/month/closed windows etc is easily done in the rule head.
    For You, for sure :)
    How to create a rule so that it uses the outside temperature from YR Weather? I've been struggling with this for an hour and no success...
    To always turn off a light 1minute after it's turned on, no matter what
    rule("trueFor(00:01,light:isOn) => light:off")
    I want to make rule like this:
    rule("door:isbreached & light:isOff & sunset..sunrise & (lux:lux < 20) & motion:safe =>       turn the light on for one minute
    is it possible without using a scene ?
    For the weather you could do something like
    The second question
    In general, these way of writing rules are not optimal. Here we turn on the light, wait a minute, and no matter what we turn off the light after 1minute. If someone opens the door and starts the light and then closes the door and open it again after 30s, it's still the first rule that will turn off the lights after 30s.
    One would probably like that if the rule triggers again the minute timer would be extended.
    One way to do that is to re-fire an event every time the rule triggers and let that event turn off the light.
    As always, the answer is complete and solving the problem :)
    The second question
    in this case, first one is a sufficient solution, but thank You once again for showing how it should be done :)
    can You please tell me how to write this rule to loop checking if the window is closed?
    rule("trueFor(24:00,window:safe) => 2:msg=log('air out bedroom')")
    It will send a push every time the window been safe for 24 hours. If it's not opened it will repeat at 48, 72, 96 hours etc.
    'again' is the function that re-triggers the trueFor statement.
    again can also take an argument that is the number of times it should re-trigger the trueFor
    again also return as a value the number of times it has re-triggered. That number can be used to give better messages
    18 godzin temu, jgab napisał:
    rule("trueFor(24:00,window:safe) => 2:msg=log('air out bedroom'); again()")
    I thought this rule would work a little different ... But after enabling this rule it doesn't start working until I open and close the windows again ... is it possible to force it to work right away? otherwise, after each restart or HC3 or QA, you would have to open, close all windows, or turn on / off all switches for which such a rule was created.
    I thought just adding "again ()" would make it count its time after restarting QA / HC3
    Yes, rules typically only run when a state change in a device/variable in the head triggers the rule.
    You can force the rule to trigger by adding .start()
    'again' just makes it start to watch another 24h period.
    The problem with trueFor is that it will restart to count time when the HC3/QA is restarted. There is no "memory"
    You could make a rule that checks every hour if the window has been closed for 24 hours (and make
    :last is the time since the device changed state last, and then we check that it was a 'close' (i.e. :safe)
    This will continue to run the action every hour after 24 hours.
    Only do it once
    ..then the window needs to be opened and closed for it to trigger again.
    Come to think about it.... this may also work ?
    it should reduce the waiting time with the time it has been closed when the rule starts
    @jgab And what about to create new "function" that will setup for define devices and properties last values (via direct reading from system after HC3 start)
    But device properties are preserved, like :last. It's part of the device properties.
    It's just that the trueFor is a local timer in the scene, and to preserve timers over restarts.... no I don't think so. (most of the cases you don't want that anyway)
    is it possible to use two or more conditions with "trueFor"? for more windows in one room im my exaple?
    in this case:
    rule("bedroomwindows = {window1,window2,window3}")
    rule("trueFor(24:00,bedroomwindows:safe) => 2:msg=log('air out bedroom'); again()").start()
    i get:
    ./include/EventRunner.lua:1982: Main() ERROR:./include/Toolbox_events.lua:211: attempt to call a nil value (field '_invokeRule')
    in this case:
    i get:
    Your rule is perfectly valid. This is the way to check it.  It was a bug in the code that must have happened some versions ago.
    I'm trying to understand why I haven't seen this before.. strange.
    Anyway, I have pushed v0.5fix14 - so if you have the update rules enabled it should work by restarting the QA.
    Updated...
    Now this one works:
    But that two, not:
    rule("bedroomwindows = {window1,window2}")
    rule("@@01:00 & bedroomwindows:last >= 24:00 & bedroomwindows:isOff => log('Closed for 24+ hours')")
    [06.09.2020] [20:53:31] [DEBUG] [QUICKAPP367]: tokenizer failed at  & bedroomwindows:last >= 24:00 & bedroomwindows:isOff => log('Closed for 24+ hours')
    [06.09.2020] [20:53:31] [DEBUG] [QUICKAPP367]: @@01:00 & bedroomwindows:last >= 24:00 & bedroomwindows:isOff => log('Closed for 24+ hours') = true
    rule("trueFor(24:00-bedroomwindows:last,bedroomwindows:isOff) => log('Closed for 24+ hours')").start()
    [06.09.2020] [19:20:52] [ERROR] [QUICKAPP367]: in Rule:17[trueFor(24:00-bedroomwindows:last,bedroomwindows:isOff) => log('Closed for 24+ h...]: {"msg":"Error executing instruction:'[\"-\",2]'","src":"Rule:17[trueFor(24:00-bedroomwindows:last,bedroomwindows:isOff) => log('Closed for 24+ h...]","ERR":true,"err":".\/include\/EventRunner.lua:1391: attempt to perform arithmetic on a table value"}
