Jan,
How I can make a back up of my ER scenes?
Instead of open them one by one and copy content into Notepath?
Thanks in advance,
//Sjakie
    On HC3? There you can just save the QA in one of the QA preference tabs (advanced).
    HC2? You need to run something on an external machine that download/backup the code.
    I have a solution for ZBS. There is also the toolkit from @Krikroff
    Jan,
    Great thanks!!
    //Sjakie
    On 8/14/2020 at 4:18 PM, Earybeongbeong7 said:
    Hello?
    The update is complete (ZBS, ER4 & all toolbox)
    Now the Incoming trigger content comes out.
    However, when you click the button, there is no response and you can see the following debug.
    [WARNING] [QUICKAPP442]: UI callback for element:debugTriggernot found.
    [WARNING] [QUICKAPP442]: UI callback for element:debugRulenot found.
    And
    rule("@{catch,05:00} => Util.checkForUpdates()")
    rule("#File_update{} => log('New file version:%s - %s',env.event.file,env.event.version)")
    rule("#File_update{} => Util.updateFile(env.event.file)")
    What updates are you checking for? (every 5 hours?)
    Do you check for updates to the ER4 toolbox and engine files?
    If there is an update when checking, will it be automatically updated?
    Hi. jgab.
    Since I deleted the ZBS update and installed a new FQA file, On/Off such as Incomming Triger works well.
    Thank you for responding quickly every time.
    Edited by Earybeongbeong7
    @jgab Hi jgab..
    is there a site that describes the commands available in ER4 with explanations?
    17 hours ago, Earybeongbeong7 said:
    @jgab Hi jgab..
    There are some docs for ER3 that is the same
    • Please login or register to see this link.
    That's great.
    Thank you very much.
    Does the page continue to be updated after that?
    Hi. jgab,
    Rule("trueFor(00:10,downstair.door:breached) => phone:msg=log('Door is open for %s min',again(3)*10)")
    What does *10 mean in again(3)*10?
    1 hour ago, Earybeongbeong7 said:
    Hi. jgab,
    trueFor is true when the condition has been true for the specified time (10min in the example).
    Then the action parts execute.
    The function 'again' resets the timer that trueFor monitors so it will start to watch another 10min and execute the action again. Without 'again' the door has to close and open again for the rule to start watching the condition.
    The typical use case is to warn if a windows is open for 10min, and then warn again every 10min the window continues to be open.
    'again' takes a number as argument that is the max number of times it should re-trigger the rules (0 means infinite). In the example, 3 times.
    The function 'again' returns the number of times the rule has repeated. In the example above we use it to log 10min, 20min, 30min in the message.
    Thanks for the explanation.  May I ask you additional questions?  Does the msg command not work in HC3?  It is displayed in the log, but there is no notification in the iPhone app.
    rule("trueFor(00:10,downstair.door:breached) => 179:msg=log('Door is open for %s min',again(3)")
    I realised that there was a bug in ER4. The format is slightly changed from HC2 to HC3 and I missed that.
    I just pushed v0.5,fix4 - and if you have v0.5,fix3 the automatic update should work
    Jan,
    This I see when I open a QA.
    After save and reopen its updated.
    I thought it should update at 05:00?
    //Sjakie
    /monthly_2020_08/image.png.a9b64a2e0795f68e23bd88bf7761fb30.png" />
    31 minutes ago, Sjakie said:
    Jan,
    //Sjakie
    Yes, but I pushed the update after 05:00 so the update would run tomorrow at 5. Or now if you restart the QA
    Jan,
    I am on fix 4
    If I try:
    rule("trueFor(00:00:05,hoofdSlaapKamer.wcdLader:isOn) => 48:msg=log('lader slaapkamer is aan',again(3))")
    it will generate an error or do I need to specify msg in a rule?
    [30.08.2020] [13:32:31] [DEBUG] [QUICKAPP396]: [true]>>'Rule:4[trueFor(00:00:05,hoofdSlaapKamer.wcdLader:isOn) => 48:msg=log('lader slaapkamer ...]'
    [30.08.2020] [13:32:31] [TRACE] [QUICKAPP396]: lader slaapkamer is aan
    [30.08.2020] [13:32:31] [ERROR] [QUICKAPP396]: in Rule:4[trueFor(00:00:05,hoofdSlaapKamer.wcdLader:isOn) => 48:msg=log('lader slaapkamer ...]: {"ERR":true,"err":".\/include\/EventRunner.lua:1373: Wrong parameter type, string required. Provided param 'nil' is type of nil","msg":"Error executing instruction:'[\"%setprop\",2,false,[\"msg\"]]'","src":"Rule:4[trueFor(00:00:05,hoofdSlaapKamer.wcdLader:isOn) => 48:msg=log('lader slaapkamer ...]"}
    Thanks for th esupport!
    //Sjakie
    Automatic update works fine.  Thank you.
    However, the following error occurs in the message function.
    QUICKAPP447]: in Rule:25[trueFor(00:10, bth.BathDoor:breached) => 179:msg=log('Door is open for %s min',a...]: {"src":"Rule:25[trueFor(00:10, bth.BathDoor:breached) => 179:msg=log('Door is open for %s min',a...]","ERR":true,"err":".\/include\/EventRunner.lua:1373: Wrong parameter type, string required. Provided param 'nil' is type of nil","msg":"Error executing instruction:'[\"%setprop\",2,false,[\"msg\"]]'"}
    Also, rule is not turned on or off.
    And do I have to write down the HC3 address below?
    Pushed 0.5,"fix5"
    Sorry, log was broken and didn't return the string it printed, so :msg got nil as value.
    Restart should update the QA.
    _HC3IPADDRESS is not needed and set automatically now.
    The Rules: ON I have to look at later.
    Jan,
    fix 5
    I cant get it send th emessage.
    If I manually create new scene and push message it will come true.
    no other messages till 20.27
    Please advice.
    //Sjakie
    1 minute ago, Sjakie said:
    Jan,
    fix 5
    Please advice.
    //Sjakie
    On the HC3, the "device" id the id of the user, not the device.
    Thanks, now its working.
    space show &nbsp how to correct?
    //Sjakie
    Hmm, that's an unintended effect. I have to think how to deal with this (when I log to the console I replace <space> with &nbsp to get spaces, but when we send to devices we don't want it...
    For now a quick fix is to set
    self._HTML = false
    in the beginning of QuickApp:main()
