1 hour ago, jgab said:
The best
ER
Jgab
Thank you
Edited by minsad79
Hi jgab
ER4 some errors
1.'Rule: 15 [House_sensor: breached => || Gate_sensor: safe >> home = true; post (#ArrivalHouse)] ': {"msg": "Error executing instruction:' ["% prop ", 1," breached "] '", "src": "Rule: 15 [House_sensor: breached => || Gate_sensor: safe >> home = true; post (#ArrivalHouse)] "," ERR ": true," err ":" ./ quickApp.lua: 2542: attempt to compare string with number "}
2.Rule: 48 [$ PresentState == 'Home' & lr.LivingRgbw: isOn => ...] ': {"msg": "Error executing instruction:' ["% prop ", 1," isOn "] '"," src ":" Rule: 48 [$ PresentState ==' Home '& lr.LivingRgbw: isOn => ...] "," ERR ": true," err ":" ./ quickApp.lua: 2542: attempt to compare string with number "}
3.Rule: 77 [rm.Philiocolorbutton3: central.keyId == '1' & ch.kidcurtain: isOpen => ch.kidcurta ...] ': {"msg": "Error executing instruction:' ["% prop ", 1," isOpen "] '", "src": "Rule: 77 [rm.Philiocolorbutton3: central.keyId ==' 1 '& ch.kidcurtain: isOpen => ch.kidcurta ...]", " ERR ": true," err ":" ./ quickApp.lua: 2542: attempt to compare string with number "}
During the rules. >> It looks like an error
E_VERSION, E_FIX = 0.2, "fix1"
in use
Edited by minsad79
    10 minutes ago, minsad79 said:
    Hi jgab
    ER4 some errors
    Sorry, try this version
    Works fine
    Edited by minsad79
    Just updated to 4.582 and ER wont start and nothing in the debug window :(
    4.581 beta worked just fine.
    Tried to roll back to 4.581 beta and still same problem.
    Anyone else that have the same problem?
    I just upgraded from 4.57..something to 5.582 and everything runs fine.
    Nothing at all in the debug window?
    Nothing at all in the debug window.
    i wrote to Fibaro yesterday, no scenes runs at all and nothing works.
    Tried to make a new ER scene, only got "forbidden 403"
    Rolled back to previous version, did not work.
    So now i just wait for support from fibaro tech.
    Our house is back to analog again and it sucks...
    Guest kallecux
    Hi @jgab,
    when I look at the diagram on the first page, it describes that EventRunner can react to an http event.
    I would like to send an http POST to the HC3 and transfer a payload and process it further in ER4.
    Specifically, it is about evaluating location information from the Geofency app.
    So far I have sent the POST to Homeassistant / NodeRed, but I would like to do without it.
    Is there a way to handle this?
    Greetings
    Karl Heinz
    To send an event to ER4 you need to do the equivalent of below, ex. calling ER4 with deviceID 963 and event {type='foo'}
    fibaro.call(963,"ER_remoteEvent","E"..json.encode({type='foo', value=77}))
    With the api it becomes a post to
    http://<HC3IP>/api/devices/963/action/ER_remoteEvent
    with the json payload of the ("E"..json.encode(event))
    The hack with the "E" infront of it was to overcome some strange bugs when it comes to how the HC3 interpret its payload. I may change it if I find another way.
    But for now you need to prepend "E" to the json encoded string of the event.
    That event can then be picked up by a rule type
    Rule.eval("#foo => log('Value is:%s',env.event.value)")
    Guest kallecux
    Hi @jgab,
    sorry, but somehow I have a bar in my head.
    I am trying to get the connection to NodeRed (i did it in the past, but i lost some code) and use your example from March 17th from this post.
    I use this code in ER4:
    and I get the following answer in the HC3 debug window:
    the rule #echo1 is not responding....please give me a tip!
    Thank you!
    Karl Heinz
    P.S: I use E_VERSION,E_FIX = 0.2,"fix3"
    14 hours ago, kallecux said:
    Hi @jgab,
    Thank you!
    Karl Heinz
    The value echoed back doesn't have a 'data' field so the rule doesn't match.
    try
    Guest kallecux
    Hello @jgab, thanks for the tip....i did it with your example.
    But now, I want to send a message from NodeRed to ER4 without first sending anything from ER4 to NodeRed.
    What is the standard message that has to be sent to ER4 so that it can be intercepted via an event rule.
    Not just the payload, but the entire property. I've done a lot of experiments, but I can't do it.
    Maybe a small flow like this:
    /monthly_2020_05/image.png.53e318a2cf5226e5bc27d4f00b6e34aa.png" />
    and the machting rule in ER4.
    Thanks in advance!
    Greetings
    Karl Heinz
    Thanks in advance!
    Greetings
    Karl Heinz
    The way I encode the message when sending it. out from NodeRed is
    Also, msg.EDeviceID should be the QA id. Look at the "encodeEvent" node below. Look also at the "timestamp" flow that is started from NR.
    The outgoing GET in NR is
    and I check the box for " Append msg.payload as query string parameters"
    Here is. an experimental flow that I use to test with (It contains some MQTT stuff that is under test too)
    Hello Jan,
    Supervisor stopped checking due to
    /monthly_2020_06/image.png.c7ff1d9ec9492256b4007be5a096539e.png" />
    Today I saw at around 22:30 all scenes are running?
    Any idea?
    Who checks Supervisor?
    //Sjakie
    9 hours ago, Sjakie said:
    Hello Jan,
    Any idea?
    //Sjakie
    This was a new one. Seems to be something from within the Lua framework. Very difficult to speculate what it can be.
    Anyway, it dies at 06:47:40 and from that on it will not receive events anymore and drop them.
    Just restart the scene and keep an eye on it if it happens often. Unfortunately there is no Supervisor for the Supervisor...
    Jan, thanks
    Good morning Jan,
    Previous screenshot was version 4.59
    Due to problems with my bath room and toilet lights I decided to revert back to 4.58. The delay of switch on was around 4 sec.
    Mem 15-25% Ram 16% (remark 4 Gb Mem)
    It did not make any difference, HUE sometimes show if scene starts after modification error >>>handshake error >>modify again>>>starts without any error. This happens with more than one HUE scene. (Scenes with HUE are 5-9-12-13-14-18
    Supervisor stopped again, shows dead devices??? those scenes are still running.
    I have no clue what is happend or hapenning System was running smooth.
    /monthly_2020_06/image.png.6274b1e5d62872dad52173bf42545f14.png" />
    scene 15 shows
    scene 9,6,18,4 debug is the day after
    25 shows also the announcements
    Please advice,
    //Sjakie
    Hi jgab
    the rules used in er3
    There is an error when applied to er4
    My rules
    Util.map(Util.defTriggerVar,{'_roomManual'})
    rule("of.OfficeLight:manual==0 => _roomManual=1; log('Manual lights in room')")
    rule("of.OfficeMotion:breached & of.OfficeLight:isOff & _roomManual==0 => of.OfficeLight:on; log('Light On')")
    rule("trueFor(00:10,of.OfficeMotion:safe) & of.OfficeLight:isOn & _roomManual==0 => of.OfficeLight:off; log('Light Off')")
    - reset manual lights after xx minutes (40 minutes), again automatic light in room
    rule("trueFor(00:40,_roomManual>0) => _roomManual=0; log('Reset _roomManual')")
    - reset variable _roomManual after start
    rule("wait(+/00:00:01); log('Reset after start-Manual');_roomManual=0")
    under
    Debug
    [2020-06-12] [18:13:55] [ERROR] [QUICKAPP740]: in'Rule:87[of.OfficeLight:manual==0 => _roomManual=1; log('Manual lights in room')]': {"msg":"Error executing instruction:'["%prop",1,"manual"]'","src":"Rule:87[of.OfficeLight :manual==0 => _roomManual=1; log('Manual lights in room')]","err":"./quickApp.lua:2677: attempt to call a nil value (field'lastManual')", "ERR":true}
    Good morning Jan,
    What is the proper notation for:
    cd=osdate('%m/%d') for 08:00  cd=ostime('h/%s')  doest work.
    //Sjakie
    On 6/12/2020 at 11:19 AM, minsad79 said:
    Hi jgab
    My rules
    under
    Debug
    Hi, short answer. 'manual' is not supported in ER4 yet. It's on my todo list.
    6 hours ago, Sjakie said:
    Good morning Jan,
    //Sjakie
    Rule.eval("cd = os.date('%H:%M')")
