    4 minutes ago, minsad79 said:
    Hi gap
    I got it from er3
    under
    function httpGet(url)
      local http = net.HTTPClient()
      http:request(url, {
          options = { method = 'GET' },
          success =function() fibaro:debug(url.." ,done."end,
          error = function(errorcode) fibaro:debug("error=" .. errorcode) end
    It's the old style call to fibaro:debug not available in HC3's QAs
    Try the ER Log function instead.
    18 minutes ago, jgab said:
    HC3의 QA에서는 사용할 수없는 fibaro : debug에 대한 오래된 스타일의 호출입니다.
    대신 ER Log 기능을 사용해보십시오.
    Thanks for your advice
    I'll test it tonight
    you advised works well
    Another problem
    Status of lighting
    rule ("@ 04:00 & officedeskLight: isOn => officedeskLight: off")
    rule ("@ 05:00 & officedeskLight: isOff => officedeskLight: on")
    I don't think the isOn status value is reflected
    Edited by minsad79
    1 minute ago, minsad79 said:
    Another problem
    What type is officedeskLight? com.fibaro.binarySwitch or com.fibaro.multilevelSwitch or something else?
    Dimmer 2 & rgbw relay 2
    Two devices
    My rules
    rule("bedmotion:breached & 22:00..02:00  =>  Bedlamp:value=50")
    rule("bedmotion:breached & 02:10..03:30  =>  Bedlamp:value=30")
    rule("$PresentState=='Home' & trueFor(bednight,bedmotion:safe) & 22:00..03:30 => Bedlamp:value=5")
    rule("@04:00 & Bedlamp:isOn   =>  Bedlamp:off")
    The last rule doesn't work
    Bedlamp:isOn
    Dimmer & rgbw both
    It doesn't seem to reflect on the state
    3 minutes ago, minsad79 said:
    My rules
    Bedlamp:isOn
    Dimmer & rgbw both
    Can you see what kind of triggers you get when bedlam is turned on/off?
    No error text is displayed
    Another light
    triggers
    [DEBUG] 2020-03-20 12:15:06 am: [D] Incoming event:{"type":"property","deviceID":1045,"value":460,"propertyName":"value","old":520.0}
    [DEBUG] 2020-03-20 12:15:06 am: [D] Incoming event:{"type":"property","deviceID":1045,"value":503,"propertyName":"value","old":460.0}
    [DEBUG] 2020-03-20 12:15:13 am: [D] Incoming event:{"type":"property","deviceID":1164,"value":5,"propertyName":"value","old":0}
    [DEBUG] 2020-03-20 12:15:13 am: [D] Incoming event:{"type":"property","deviceID":1164,"value":true,"propertyName":"state","old":false}
    Guest kallecux
    Hi @jgab, you wrote something about it in the past, but I would like to ask you specifically (HC3 and ER4)
    I want to take a picture every minute when moving in the garage as long as the motion detector detects motion.
    This is relatively easy with a while loop.
    Now I am concerned that the while loop blocks the entire ER4 and that other events cannot be processed. Is that so?
    If so, how can I start a single task from ER4 that does not block ER4.
    1. A scene?
    2. An own method of ER4?  (QuickApp:takePhotos()....end)
    What do you think about that?
    Best regards
    Edited by kallecux
    rule("Kitchenmotion=kt.Kitchenmotion; Kitchenlamp=kt.Kitchenrgbw"
    rule([[$PresentState=='Home'  & Kitchenlamp:isOn =>
        || @22:00..04:00  >> Kitchenlamp:color={129,42,3,0}]])
    rule("Kitchenmotion:breached & 22:00..02:00-1  =>  Kitchenlamp:value=50")
    rule("Kitchenmotion:breached & 02:00..04:00-1  =>  Kitchenlamp:value=30")
    rule("trueFor(00:05,Kitchenmotion:safe) & 22:00..04:00-1 => Kitchenlamp:value=5")
    rule("@04:00 & Kitchenlamp:isOn =>  Kitchenlamp:off")    <======Not going off
    rule("bedmotion=br.Bedroommotion; Bedlamp={br.Bedstrip,br.BedroomBulb}"
     rule("bednight = 00:05")
    rule([[$PresentState=='Home'  & Bedlamp:isOn =>
        || @22:00..04:00  >> Bedlamp:color={129,42,3,0}]])
    rule("bedmotion:breached & 22:00..02:00-1  =>  Bedlamp:value=50")
    rule("bedmotion:breached & 02:00..04:00-1  =>  Bedlamp:value=30")
    rule([[$PresentState=='Home' & trueFor(bednight,bedmotion:safe) & 22:00..04:00-1 => Bedlamp:value=5]])
    rule("@04:00  & Bedlamp:isOn =>  Bedlamp:off")    <======Not going off
    Hi gap
    Some of the rules aren't working
    This is the rule used in er3
    But in er4 it doesn't work
    I'm looking for your advice
    Thanks in advance
    Lighting is fibaro rgbw2
    Edited by minsad79
    Hi gap
    Thanks in advance
    Try this
    2 hours ago, jgab said:
    보십시오.
    [DEBUG] 2020-03-21 06:21:50 pm: [ERROR] in 'Rule:77[16:00..02:00-1 & exitlamp:isOn => exitlamp:color={129,42,3,0}]': {"msg":"Error executing instruction:'["%prop",1,"isOn"]'","src":"Rule:77[16:00..02:00-1 & exitlamp:isOn => exitlamp:color={129,42,3,0}]","ERR":true,"err":"./quickApp.lua:2096: attempt to compare string with number"}
    Applying the quick app you sent causes another error
    rule("exitmotion=et.EntranceMotion; exitlamp={et.EntranceBulb1,et.Entrancestrip2}"
    rule("06:00..16:00-1 & exitlamp:isOn => exitlamp:color={255,255,255,255}")
    rule("16:00..06:00-1 & exitlamp:isOn => exitlamp:color={129,42,3,0}")
    rule("exitmotion:breached  =>  exitlamp:value=100")
    rule("trueFor(00:01,exitmotion:safe) => exitlamp:off")
    Edited by minsad79
    New attempt:
    The HC3 has changed the type of the values that are returned (it used to be strings). I have been a bit reluctant to change it in ER4 as it may affect parts of  my code that I haven't anticipated... Anyway, I did an attempt - let me know how it works out.
    /J
    4 minutes ago, jgab said:
    새로운 시도 :
    HC3가 리턴 된 값의 유형을 변경했습니다 (문자열 이었음). 예상치 못한 코드 부분에 영향을 줄 수 있으므로 ER4에서 변경하기를 꺼려했습니다 ... 어쨌든, 시도했습니다-어떻게 작동하는지 알려주세요.
    /제이
    [DEBUG] 2020-03-21 06:39:18 pm: [D] fibaro.call(1227,"setValue",100) => nil
    [DEBUG] 2020-03-21 06:39:18 pm: [D] fibaro.call(1232,"setValue",100) => nil
    [DEBUG] 2020-03-21 06:39:19 pm: [D] fibaro.call(1227,"setColor",129,42,3,0) => nil
    [DEBUG] 2020-03-21 06:39:19 pm: [D] fibaro.call(1232,"setColor",129,42,3,0) => nil
    J gap
    Thank you for your kind advice
    Works fine
    Your ER is the best
    Hi gap
    Your Event Runner 4
    Can I use the full version?
    Useful functions in er3
    I want to use it again at Home Center 3
    51 minutes ago, minsad79 said:
    Hi gap
    Your Event Runner 4
    The main difference between ER# and ER4 is that Hue light support is. missing.
    Is it Hue you are thinking on when you refer to the "full version"?
    31 minutes ago, jgab said:
    ER #과 ER4의 주요 차이점은 Hue light 지원입니다. 잃어버린.
    "정식 버전"을 참조 할 때 생각하고있는 색조입니까?
    no
    The difference I feel
    Rules sometimes slow when running continuously
    rule ("# ArrivalHouse => $ PresentState = 'Home'; wait (00:00:10); post (#familyInhouse)")
    Rule wait (00:00:10); Applied unspecified late
    On 4/1/2020 at 11:16 AM, minsad79 said:
    no
    Do you have other rules that could cause the delay?
    If I try this
    It will start 10000 parallell loops that each wait 5s before looping again (with a 1s delay). Each loop measures the actual 'wait' time and if it deviates with more than 1s it prints a message.
    These rules, alone in a ER4 QA, will work for 5min before starting to log warnings - so it can't really cope with that amount in the long run. If I reduce it to 8000 I waited for 10min without any warnings,.
    This tells us that it seems to be able to schedule around ~5000-8000 rules with setTimeouts and still keep up. That is good news. (It seems to be similar values for ER3 on the HC2)
    Even though these rules are simple, (an event match, a wait and a if-then and a post) it works.
    In reality rules are more complex, and other things can "disturb" running rules.
    -Do you have many rules? 10, 50, 100?
    -Do you send events between scenes? like remote(...) ?
    -Do you use any QuickApp:<functions> in your ER scene (like for UI buttons or other fibaro.calls ?)
    -Do you have any rules that you suspect could take time?
    I would like to find rules that causes this delay - I haven't found any myself yet but I will do some more experiments
    Sometimes the HC3 box also decides to do other things and can delay scenes/quickapps. Do you always see a random delay longer than 10s when you use wait(00:00:10) ?
    You could add this
    To get a warning if the wait is too long (we check against 11s as it could be on the border of 10-11s).
    I have a new version here where I tried to optimise the polling of triggers a bit, you could try it:
    3 hours ago, jgab said:
    지연을 유발할 수있는 다른 규칙이 있습니까?
    내가 이것을 시도하면
    10000 개의 병렬 루프를 시작하여 각 루프가 다시 5 초 동안 기다린 후 (1 초 지연) 시작합니다. 각 루프는 실제 '대기'시간을 측정하고 1 초 이상 벗어나면 메시지를 인쇄합니다.
    이 규칙은 ER4 QA에서만 경고를 기록하기 전에 5 분 동안 작동하므로 장기적으로 그 양에 대처할 수 없습니다. 8000으로 줄이면 아무런 경고없이 10 분 동안 기다렸습니다.
    이것은 setTimeouts로 ~ 5000-8000 개의 규칙을 예약하고 계속 유지할 수있는 것으로 보입니다. 좋은 소식입니다. (HC2의 ER3과 비슷한 값인 것 같습니다)
    이러한 규칙은 간단하지만 (이벤트 일치, 대기 및 if-then 및 게시물) 작동합니다.
    실제로 규칙은 더 복잡하며 다른 규칙은 실행 규칙을 "방해"할 수 있습니다.
    -규칙이 많습니까? 10, 50, 100?
    -당신은 장면 사이에 이벤트를 보내십니까? 같은 원격 (...)?
    -ER 버튼에 QuickApp : <기능>을 사용하십니까 (UI 버튼 또는 다른 fibaro.calls와 같은)?
    시간이 걸릴 것으로 의심되는 규칙이 있습니까?
    이 지연을 유발하는 규칙을 찾고 싶습니다. 아직 자신을 찾지 못했지만 더 많은 실험을 수행 할 것입니다
    때때로 HC3 박스는 다른 일을하기로 결정하고 장면 / 퀵앱을 지연시킬 수 있습니다. wait (00:00:10)을 사용할 때 항상 10 초보다 긴 임의 지연이 보입니까?
    이것을 추가 할 수 있습니다
    대기 시간이 너무 길면 경고 메시지가 표시됩니다 (10-11 초 경계에있을 수 있으므로 11 초와 비교).
    트리거의 폴링을 약간 최적화하려고 시도한 새 버전이 있습니다.
    Delay not seen in er3
    In er4, some rules delayed
    My rules 140
    There were no interlocking and suspected rules of other scenes.
    Your optimized er4 hasn't been delayed yet.
    Thank you for your advice and passion
