1 hour ago, jgab said:
So, RoomLight:on sets lastID[322]={script=true,time=1577983180}
The RoomLight:on also generates a fibaro trigger that calls trackManual.
When we enter trackManual the time is 1577983185, 5s later...?
Do you have that kind of delays?
If we knew that we would get the trigger back (e.g. it was declared in the header) we could wait longer and assume it is from the script...
Try this, if it works for you then I will add it to next version.
 it works! Thanks
@petrkl12 in what cases are you using "ID:manual" ?
    50 minutes ago, jompa68 said:
    got trouble to connect to NR from ZBS
    Check ZBS
    Have your PC changed IP address?
    Right port? 6872
    Log the whole message in NodeRed and see if address (-413) is correct.
    ie. when I want to stop  "automatic light on/off" in rooms
    Edited by petrkl12
    30 minutes ago, jgab said:
    Check ZBS
    Right port? 6872
    mac ip is the same as earlier, have not changed.
    Port is right, 6872
    Result from ZBS in NR
    i guess the response function for my sonosStatus missing something. Have tried different setup without success.
    I would check RoomLight:manual>=0 as it :manual returns seconds since last changed manual - It works if you check with a rule trigger, as the rule is triggered the same second as you flip the switch - but just to be sure if there is a delay...
     OK, Thanks
    I have corrected in my previous post.
    @jgab
    the iCal scene have some error in the code. Show scheduled entry every week even when it is set to every 2 weeks. See my picture.
    Edited by jompa68
    Good morning Jan,
    v3.0 b86
    uptime 13 hours due to kitchen renovation
    version 4.570
    Something weird happens last night>> alarm!
    Since a few weeks we dont close "tussendeur"
    I saw that if complex is being armed the "tussendeur" is armed also since a few days  it didt do that before.
    So far no problem (in my opinion it should not being armed).
    At 4:50 HC2 discover the "tussendeur" is open>>>alarm, why it discover so late that the door is open?
    Why only last night alarm something changed?
    Jan please can you check?
    I will send the scene ,
    Thanks in advance,
    //Sjakie
    Hello Jan,
    I am still obsessed by the alarm at night.
    I tried several ways to arm the complex with an open "tussendeur" and I cant reproduce the arming of that open door.
    If door is open it will tell me door disarmed and breached
    the others are armed and safe.
    If I may conclude your proposals for arming my complex and ER are functioning well!
    But question stays what is changed?
    Morning Jan,
    I got this error:
    /monthly_2020_01/image.png.a58e59b6e78bae3afae918f6892df684.png" />
    Rule.eval([[trueFor(01:00,$HumidityBadStart ~= nil) =>
            $HumidityBadStart=nil]]).start() -- Reset after  n-hour
    please advice,
    //Sjakie
    23 hours ago, Sjakie said:
    Morning Jan,
    I got this error:
    please advice,
    //Sjakie
    Ok, it's a bug - I have problem compiling expressions with nil constant in them...
    For now, just do
    A small tip.
    We know that editing global variables in the variable-panel will destroy values sometime.
    You can create and delete variables in ER that will not destroy other variables.
    You can also check if the value has been destroyed (e.g set to 'NaN')
    When variables are destroyed there is no trigger generated so we can't make a rule that triggers on it e.g. $Temperature == 'NaN' => $Temperature = 20
    Good morning Jan,
    Thanks! for the nil fix.
    If I implement the GV check
    /monthly_2020_01/image.png.0802bf667284516923b99b7c78733a64.png" />
    -- Check if variable is "destroyed" at startup and set it back to some default value, here '20'...
    Rule.eval("$Wasdroger == 'NaN' & $Wasdroger = Aan")
    -- Create variable - if it doesn't already exists
    Rule.eval("global(Wasdroger); true")
    -- Delete variable -- if it exists
    Rule.eval("deleteglobal(Wasdroger); true")
    Please advice,
    //Sjakie
    Hello Jan,
    UPDATE:
    "tussendeur" is open but in HC2 its reported as closed???
    I did a Telegram message on the status of the door and this morning bingo got  no  message and status changed.
    Should replace it.
    //Sjakie
    14 minutes ago, Sjakie said:
    Good morning Jan,
    Please advice,
    //Sjakie
    You need to quote the variable names to global and deleteglobal
    global('Wasdroger')
    For now, just do
    Ok, pushed vB87 with a fix so nil constants can be used again.
    Hello Jan,
    I am a bit lost.
    Today the house got armed at 23:00 hour, the last months it was arming when I pushed ladertelefoonsjaak. Something different with the new build?
        Rule.eval([[once(23:00..02:00,n/03:00 & hoofdslaapkamer.ladertelefoonsjaak:isOn) =>
    Please advice,
    //Sjakie
    6 hours ago, Sjakie said:
    Hello Jan,
    I am a bit lost.
    Please advice,
    //Sjakie
    no last build only affected nil constant in rules.
    Be aware that the rule will execute at 23:00 if ladertelefoonsjaak has been set to on earlier during the evening.It’s the only explanation I have why it would run at 23:00
    Jan,
    thanks
    I checked it also sorry I forget to mention it " telefoonlader sjaak" was off.
    For in case I forget to switch off I get a telegram and a repeated voice message.
    Thats why its so strange.
    //Sjakie
