@jgab
I think there is incorrect working of :manual
Hello Jan,
What I am, doing wrong?
This is the rule
    Rule.eval([[(bijkeuken.rookmeldertemp:value - keuken.temperatuur:value) > 3 =>
           bijkeuken.afzuigventilator:on;
        log('TRIGGER:%s',tjson(env.event)); log('Afzuigventilator op delta t - aan')
trigger  in header:
489 value
811 value
Please advice.//Sjkaie
/monthly_2019_12/image.png.04cc53040152cd937bfd081e31ff22c3.png" />
sorry forgot to state fan does not start
anyone doing a post (remote) to an ER from a none ER scene?
My guess is it will not work.
but whi am I
Happy new year
To all ER users and the of course also to the father of ER:
the best wishes a good health and happiness !
may it become a prosper year for our home automation
@jgab suddenly i get node-red error in ER
    On 12/31/2019 at 12:18 AM, petrkl12 said:
    @jgab
    So, the code for detecting manual is measuring the time between the script changing a device (RoomLight:on) and the trigger coming back to the script. If it's more than 1s it assumes it's a manual operation that generated the trigger.
    The code is around line 530 and looks like this
    You could change to "os.time()-lastID[id].time>2" and see if it improves.
    It looks very strange. You get "NR9c79c68" back at 09:39:54 but the event handler times out at 09:39:57 complaining it didn't get "NR9c79c68" back...
    Can you post the rules that send and receive the data from Nodered?
    Do you get it on the HC2 emulator too?
    Could you add debug statement to this code (around line ~2340 in ER) and see what you get?
    Think i found why now.
    I want to have only "data" but when i add that to "lastSonosStatus" like this "lastSonosStatus.data" i get the error
    Ah, it's the rule that crashes.
    You have to figure out what to do when you have set lastSonosStatus to nil in the rule (I added a check that it's not nil before comparing, I guess you set lastSonosStatus in some other rule?)
    Thanks @jgab all working ok now.
    lastSonosStatus i set in another rule, with different message i sent to my Sonos player.
    4 minutes ago, jgab said:
    Great, thanks again.
    On 12/31/2019 at 2:57 PM, Sjakie said:
    Hello Jan,
    This is the rule
    trigger  in header:
    489 value
    811 value
    So, it's "(bijkeuken.rookmeldertemp:value - keuken.temperatuur:value) > 3" that doesn't trigger?
    Is bijkeuken.rookmeldertemp:value always larger? or is it the absolute/unsigned value you need to test?
    On 12/29/2019 at 6:39 PM, domin12 said:
    Hi all,
    Solved, changed 1 function and added the old one ..................
    just realized that my telegram stop working , anyone can help
    version (probably upgraded automatically):
    (local _version,_fix = "3.0","B83"  -- Nov 17, 2019 )?
    the error :
    [DEBUG] 18:30:38: Error in 'Rule:6[#telegram{msg='$msg'} =>cmd=msg.content; log('Telegram command:%s',cmd); ...]': /opt/fibaro/scenes/392.lua:298: sceneID is not a number to postRemote:http://192.168.1.10:1880/eventrunner
    here is the function:
    function telegram(ref,msg)
    local tmsg = Util.copy(ref)
    print (json.encode(tmsg))
    tmsg.content=msg
    Event.postRemote(_defaultNodeRed,{type='telegram',msg=tmsg})
    Well, Nodered handling has changed and now uses Nodered.post to send messages (and the Nodered flow has changed too)
    See
    Hello Jan,
    Depends;
    Summer I guess it will be lower I did not track that because no adequate devices present
    The other 3 seasons it will be always the highest value
    //Sjakie
    It doesn't help :( Could you try my code in your enviroment?
    Ok, found a bug...
    Pushed "3.0","B85" that should fix it.
    trackManual/lastManual needs to make sure that id is a number.
    thanks, but there has to be some other bug. I have added some tracking points to your code:
    here is result - without press any button only trigged by sensor in room:
    result is Manual switch on/off of light but it was triggered by sensor based on rule "RoomSensor:breached & RoomLight:isOff => RoomLight:on"
    So, RoomLight:on sets lastID[322]={script=true,time=1577983180}
    The RoomLight:on also generates a fibaro trigger that calls trackManual.
    When we enter trackManual the time is 1577983185, 5s later...?
    Do you have that kind of delays?
    If we knew that we would get the trigger back (e.g. it was declared in the header) we could wait longer and assume it is from the script...
    Try this, if it works for you then I will add it to next version.
    got trouble to connect to NR from ZBS
    I have checked everything but cannot find out what is causing that, @jgab you have a clue?
