Hello Jan,
I need again your expertise.
I implemented your proposal for coming from out side to the inside, works excellent
The bath room is having motion sensor and window sensor
The bed room is only having window and door sensor works good also, my rule was giving alarm when the door position changed, yours not!
My question is both rules are in the same ER scene so I added "2" behind those items who are in both rules to avoid any mistake.
Is that necessary?
Util.defTriggerVar("openedFromOutside2",true)
rule([[alarmapp.ringbeveiliging:isOn & hoofdslaapkamer.raamB:breached =>
    || hoofdslaapkamer.deur:safe >> openedFromOutside2=true
    || hoofdslaapkamer.deur:breached >> openedFromOutside2=false
    ]])--alarmapp.ringbeveiliging:isOn &
rule("openedFromOutside2==true => post(#RingAlarmState); log('TRIGGER:%s',tjson(env.event)); log('RingAlarmState Slaapkamer raam geopend'); Telegram.msg(TID,'Ring alarm slaapkamer raam volgens rule Jan - geopend')")
rule("openedFromOutside2==false => log('TRIGGER:%s',tjson(env.event)); log('Slaapkamer raam geopend VAN BINNEN UIT rule Jgab')")
//Sjakie
    Is that necessary?
    The particular name of the trigger variable is not important.
    The important thing is that there is a unique variable for each door you are monitoring. Ex. "SlaapkamerOpenedFromOutside" - or something in Dutch...
    Jan I have this error:
    /monthly_2019_10/image.png.68a5e5659f1a54e218a335ff775aabea.png" />
    Rule.eval("@@03:00 => if max(hums:value) > max(91.2-1.184*max(temps:value),65) then fans:on else fans:off            ") -- recheck every 3 hours
    If I do this error is gone
    //Sjakie
    Yes, I forgot an ‘end’
    - You are getting good at this ?
    Jan,
    Dont be surprised with such a excellent teacher/ coach!!
    Btw I am learning a lot with the error explanation if I do something wrong. Somtimes it will take a day but I can solve a few of them.
    To update you:
    Ring alarm does still have errors or a wrong thought to create a rule but I am finalizing it now.
    Bath room in process of full automation.
    Loft automatically light on/off finished today.
    All scenes in the same format almost finished
    ER scenes more logical distrubution of the house
    Combi oven in progress
    Dead nodes solved
    Guest room 1 presence to developed.
    Guest room 2 presence to developed.
    ICal stil doest work
    IOS location doest work
    Harmony hub doest work.
    And what else is popping up on the wish list
    Thanks and have a nice weekend
    Hello Jan,
    Can I use sat or hue as trigger? If yes how?
        Rule.eval([[voortuin.spotbeeldbuiten:value=={sat=125} =>
    Thnaksin advice
    //Sjakie
    21 hours ago, Sjakie said:
    Hello Jan,
    Thnaksin advice
    //Sjakie
    It's possible but requires some additional lines of code. At the moment, only 'on' and 'buttonevent' is filtered out to generate events.
    I'm fighting with my development environment (Zerobrane) after upgrading my laptop os, so I can't test code at the moment. Hope to fix it soon and I'll show how it can be done.
    Hello Jan,
    No problem at all.
    Dont fight to hard!
    What os are you using, Linux flavor or ordinary Windows?
    //Sjakie
    13 minutes ago, Sjakie said:
    Hello Jan,
    No problem at all.
    Dont fight to hard!
    //Sjakie
    I'm a Mac user...
    On 10/31/2019 at 7:49 AM, jgab said:
    I'm a Mac user...
    Ok, I'm up and running again! :-)
    If you run ZeroBrane studio and want to try the latest, it seems like
    is pretty ok. It works on MacOS Catalina  (and Windows and Linux I presume)
    EventRunner works ok, but there may be an issue with HC2.lua (I need to exclude a file, and need to find a way to be backward compatible with ZeroBrane 1.18)
    Good morning Jan,
    Great you are back in businesses!!
    I tried the Zerobrane a while ago but with a lot of errors, perhaps you can remember. Something to pick up in the near future.
    At this moment I am trying to finish and smooth things out in HC2.
    Reporting I need to extend a bit to have a better view of whats happening.
    Calendar , Logitech hub and position is that part what has my priority.
    I have the calendar from jcichon01 working( at last was an error in the GV) and have asked Jonny for the rule for Alexa to read the agenda.
    //Sjakie
    Hello Jan,
    Perhaps you forgot but can there be a link in the fact that as well Calendar and IOS not are functioning on my end?
    //Sjakie
    Hi Jan,
    I dont think this is working?
    Rule.eval("@month('jan') => $Month ='January';  log('Set GV into January')")
    //Sjakie
    13 hours ago, Sjakie said:
    Hi Jan,
    //Sjakie
    No it doesn't. month() is just a test and can not be used to specify time intervals for '@'
    You need to run the rule every midnight and update the variable. A GV will only trigger other rules (or scenes) if it actually changes value.
    Thanks Jan,
    Suddenly Telegram is giving error and stops the scene!
    If I restore an older version of the scene same error.
    /monthly_2019_11/image.png.02e6b6f770c44f3d9fd2751b90c90b9f.png" />
    Please advice
    //Sjakie
    5 hours ago, Sjakie said:
    Thanks Jan,
    Please advice
    //Sjakie
    What are the lines around line 3077 in that scene file?
      function Telegram.bot(key,tag)
        tag = tag or "Telegram"
        Telegram._botkey = key
        if not Telegram._users then Telegram._loadUsers() end
        local url,lastID,msg = "https://api.telegram.org/bot"..key.."/",1,nil
        local function loop()
          Telegram._request(url,"getUpdates",{offset=lastID+1},
            function(messages)
              for _,m in ipairs(messages.result) do
                lastID,msg=m.update_id,m.message
                Telegram._recordUser(msg.from.username,msg.chat.id,key)
                Event.post({type=tag,user=msg.from.username,text=msg.text,id={msg.chat.id,key},info=msg.chat,_sh=true})
     If I send at  a certain time a Telegram Msg with the Telegram Scene it does not give any error!
    The
    Jan, I was using spoken language by Krikrof Sonos scene but it crashed due to an update.
    Now I like to convert my messages in NodeRed but it worked in ER Version 2 in Version 3 I did not used it.
    If I push the test button in NR Sonos will sounds the message.
    In my Escene I have:
    _NodeRed     = "http://192.168.1.89:1880/eventrunner"
      Nodered.connect(_NodeRed)
    rule("@21:43 => Nodered.post(#speak{data='test if this message is coming trough by Sonos?'})")
    This doest work
    If I use the telegram it will work, shall I use this one instead off;
    Telegram.msg(TID,'Alle binnen verlichting - aan') >>>stopped working yesterday in all scenes due to an update of Telebot????
     rule("@21:44 => Nodered.post(#telegram{msg={content='hello this is a test telegram',chatId='-xxxxxxxxxxxxx',type='message'}})") >>>is functioning
    Can you please push me in the right direction?
    //Sjakie
            function(messages)
    The
    So, it still works for me, both receiving messages from the bot and sending messages.
    I suspect that there is something with the botID or chatID - have you changed them recently?
    Anyway, I have pushed a V3, B79 that has a better error message if it receives a unexpected result from Telegram. Please try and see what error message you get?
    This doest work
    //Sjakie
    If you do
    rule("Nodered.post(#speak{data='test if this message is coming trough by Sonos?'})")
    -do you get any log in NR debug window? That it receives the message?
    -do you use other NR functions from ER that works?
    @jgab
    error in latest update. Did update this lunch and now it refuse to start
