    12 hours ago, Sjakie said:
    Hello Jan,
    Thanks its looking good!!!
    Is it possible to read the temperature value of a sensor and let Alexa set it in voice?
    First part seems easy
    Rule.eval("#alexa{device='Temperature',cmd='On'} =>
    For second part I need your experience.
    Thanks in advance
    //Sjakie
    So you want to speak the temperature when asked?
    Good morning Jan,
    Thanks gonna try it.
    I have this error for a while but now it stops sending the message what is very annoying.
    Please advice,
    //Sjakie
    /monthly_2019_10/image.png.5293f4c4f761242de18e89d4f4bef35d.png" />
    On 10/4/2019 at 7:05 AM, Sjakie said:
    Good morning Jan,
    Please advice,
    //Sjakie
    It's typically something  wrong with the Telegram CID or BOT ID. Have you double checked that it works with the phone client?
    There is the possibility to create a VD from within ER. That is useful if one needs a VD interface to a particular ER scene.
    An example.
    Here we define a setUpTimerVD() function. Inside the function we call VDev.define that takes as arguments a table structure with VD labels and buttons. The function creates the VD and then we set up Event handlers that process button clicks and updates VD labels.
    This way, VD are very simple that delegates all processing back to the scene.
    In this case our VD creates and updates fibaro globals defined in the argument to setUpTimerVD.
    Ex.
    bedtime = {time=<time since midnight>, descr=<description>; activated=<bool>, days=<string with days>}
    The VD that is created will look like this (Oops, days and names are in Swedish in the picture, it's changed to English in the code above)
    We can flip through variables and set time, days, and active/deactive - and when we are finished we press update to update the fibaro global.
    Those globals can then be used in ER and allow us to write simple rules in ER that trigger on their values:
    Here we check the bedtime fibaro global. It's time field is the timer, we check that it is active, and we check that we have the correct days.
    And if we update the variables with the VD, the rules are automatically rescheduled.
    Good morning Jan,
    If my HUE light is switched on (value 1) ER notice it in debug as Off
    /monthly_2019_10/image.png.0f7a5f87465460f171dcbd9b12c0bedb.png" />
    Rule.eval("woonkamer.lampplafondklokzijde:isOn => log('woonkamer lampplafondklokzijde - aan')")
                    Rule.eval("woonkamer.lampplafondklokzijde:isOff => log('woonkamer lampplafondklokzijde - uit')")
                         Rule.eval("woonkamer.ambitvlight:isOn => log('woonkamer ambitvlight - aan')")
                              Rule.eval("woonkamer.ambitvlight:isOff => log('woonkamer ambitvlight - uit')")
                                    Rule.eval("woonkamer.lampplafondtvzijde:isOn =>  log('woonkamer lampplafondtvzijde - aan')")
                                     Rule.eval("woonkamer.lampplafondtvzijde:isOff => log('woonkamer lampplafondtvzijde - uit')")
    //Sjakie
    Sometimes switch off Hue gives value 1 instead of zero
    Good morning Jan,
    //Sjakie
    If it's 1 it's just dimmed to a very low value but not off. ER will only know if it's off if the value is 0 or the status is off-line.
    Can it be something with the VD you use that's not setting the value to 0?
    Good morning Jan,
    Yes  its shut of with VD but hangs sometimes on 1 and then ER shows as shown in the picture >>> woonkamer.ambitvlight - uit (off)
    I use the VD sometimes to set or switch manually the HUE
    //Sjakie
    New version v3. B67 uploaded.
    New feature, dimming of lights. The algorithm is from @Krikroff dawn simulator. Credits due,
    See original post for concept and available curve types
    With EventScript it becomes
    The dimming will stop if the lights value changes while it is dimmed due to someone turning on or off the light.
    Hello Jan,
    I see this error for the first time.
    Router, HC2 and Hue are not has been off line as fa as I know.
    In more ER scenes I have twice the slow mailbox
    /monthly_2019_10/image.png.f6f5e09026302420226199054ab90607.png" />
    //Sjakie
    "Slow mailbox watch" can happen now and then and is just a warning. If there are a lot of them in a row you may get  a
    ""Couldn't post event (dead?), dropping.." and then it's more serious.
    Is your system very loaded? How's you CPU load?
    The error from Hue is usually when the Hue bridge is too busy. Are there other scenes talking to the bridge in parallell? (Do you have a lot of VDs that poll the Hue lights?)
    Good morning Jan,
    Slow mailbox I see several times. When I am busy edditing a scene sometimes too.
    "Couldn't post event (dead?) >>>.4 times but due to debug window not able to see the cause.
    CPU load 10-50% with sometimes a peak to 90%
    I have around 15 HUE lamps and 15 normal lamps
    Hue error occurred while nothing of hue was enabled.
    I have Sankotronics VD to add them in HC2, if manually need to switch of hue I use it sometimes.
    I have two VD's to switch lights off, one for inside and one for outside>>>>usage only after alarm trigger
    All operations goes with your ER after the finishing touch I am working on.
    There are
    If all  inside lights are switch on and off
    /monthly_2019_10/image.png.12230ed41f6676988cb96c6df20431ca.png" />
    All out side lights swithed on/ off
    //Sjakie
    15 minutes ago, Sjakie said:
    Good morning Jan,
    There are
    //Sjakie
    Have you tried to group your outside lights in Hue groups? Then you can turn on/off with one command? Or maybe you need individual control of the lights?
    Have you enabled a lot of Hue.monitor(...) in your ER code?
    Jan,
    My Hue's where grouped;
    livingroom 6x
    tv3x
    diverse 2x
    kitchen 1x
    still to install 4x ( are connected in test)
    OUT side:
    3xgarden
    In ER version 2 they where separeted
    In version 3 I used the grouped option again because of better performance.
    I just separated the groups with more as 2 lamps in single operation with 1 sec time between switching on.
    Hue.monitor(...) I dont know so I didt use.
    I use in log only if a Hue is switched on or off
    //Sjakie
    Sorry I forgot
    My VD switch on/off lights >>>>put on/off wall plug
    wall plug switch the lights on or off
    Jan,
    I was wrong with the debug off the HUE lights, they dont post.
    eetkamer.lampplafond is a normal lamp
    woonkamer.spotsjaak is HUE
    As you can see yellow is the rule with log
    Orange is the confirmation
    I tried also with HUE value>0 and thats working
    /monthly_2019_10/image.png.6a2b650aa16c01b29465497c53e995eb.png" />
    //Sjakie
    Good morning Jan,
    I removed all the old notify cmd and replace them with Telegram.
    The rule you gave me to join the notify msg doesnt work for telegram or the telegram msg are better served?
    Now I armed/diarmed a few times and I dont see the telegram error.
    //Sjakie
    Good morning Jan,
    I mentioned before that I had the idea sometimes a cmd is not executed.
    Below cmd #eveninglightOff>>> it only switch off zijkant.spotfietsenstalling (confirmation in orange)
    Remark serre debug is in another scene and was switched off.
    Checked >>
    ER Scene >>>no errors
    Hometable>> gastbeneden.spotachterdeur=151,  oprit.spotbeeld=34>>>>present
    Header>> 151 value present,  34 present
    Debug>> both present
    Rule.eval("oprit.spotbeeld:isOff => log2('orange','Oprit spot beeld - uit ')").start()
    What can be the cause for not switched off both lights??
    Thanks in advance,
    //Sjakie
    /monthly_2019_10/image.png.1f877e5126d984ffeedfc939bbd815c7.png" />
    Hello Jan,
    Sorry for the trouble I have this error
    If I copy a good ER scene in this scene gives the same error??
    If I copy to new blank scene same error.
    Restore?
    /monthly_2019_10/image.png.50ecc7a09f9628424c2ba28052f2155d.png" />
    On 10/15/2019 at 8:57 AM, Sjakie said:
    Good morning Jan,
    Checked >>
    Thanks in advance,
    //Sjakie
    If you see the log "fibaro:call(...)" that means that ER has "sent" that command to the HC2. If a fibaro:call(id,"turnOff") is not turning off a lamp I'm afraid it's something with the device, network, or the HC2.
    If they are present in the header it should trigger on :isOff and log.
    Could it be that your z-wave network is overloaded? Could you add an "wait" in-between the tunroff commands?
    21 minutes ago, Sjakie said:
    Hello Jan,
    Restore?
    If you download a new copy of the ER scene and paste it into a new scene you get the error?
    I'm suspecting that some strange character has sneaked into the source code of the ER scene.
    Jan, #eveninglightoff happens in the morning and it will switch off 2 or 3 or 4 lights depends who is in the house, so the load should not be very high.
    Since I am more "experienced" I see now what I was expecting HC2 skipp sometimes.
    I have seen in another scene (you have the rule switching on/of with wait00:00:01 it will not log all the sessions)perhaps to short after each other?
    My garden lights, 3 hue and 4 normal lights take sometimes 10 sec to switch off. 12 m away from HC2 with 2 powered devices on 6 m.
    Network around 80-100mb/sec from my laptop to the router.
    HC2 at the moment 30-55%
    //Sjakie
