    1 hour ago, Sjakie said:
    Good morning Jan,
    Old error back?
    In Supervisor its not mentioned!
    It means that the ER scene has stopped or the ER scene has crashed  (the main event-loop in ER). The reason could be that something has stopped the scene.
    If it has crashed I can't see from your log. I would need the log prints from when the "bad logs" started.
    Jan,
    the beginning of the log was aborting server thats why I could not post it or is there anotherway to get that info?
    //Sjakie
    2 minutes ago, Sjakie said:
    Jan,
    mmh probally you are right because in NR there was nothing listed at all. This scene is my arming scene.
    I will convert all Sonos into usage of VD so I dont need NR in this scene and avoid errors..
    I use Sonos here to change volume, play and stop in case of alarm
    Can you refresh my mind cmd in ER to set slider in %?
    445:btn=3 is stop
    Thanks in advance
    Rule.eval("slider(445,'slVolume')=50") -- set slider to 50%
    Jan,
    This does not work,
    20 minutes ago, Sjakie said:
    Jan,
    This does not work,
    Sorry, don't understand why that fell off my code...
    Pushed v3,B63 that fixes it.
    Jan,
    Thanks will try your fix later, all NR Sonos messages are now with VD.
    If you have time can you help me with the following:
    I like to accomplish if alarm is triggered;
    hue lights in red on/off
    if hue light is off the white lights on
    So the view will be red/white
    the time on/off to be set separately.
    Hue red lights will not be used for the white color
    HUe color lights 6x,  Hue white lights 7x, normal lights 12x
    I tried with some lua available on the forum but that is not what I like.
    Your color show is great, I receive many positive reactions, that is why I want to ask you.
    Thank you very much in advance,
    //Sjakie
    39 minutes ago, Sjakie said:
    Jan,
    //Sjakie
    Sorry, I'm not sure I understand fully.
    1. Your 6 hue color lights you want to blink red-off-red-off-red-off-...
    2. Your 7 hue white lights. What should they do? All turned on?
    3. Your 12 normal lights (I assume they are not Hue). What should they do?
    Hello Jan,
    Thanks,  error slider disappeared must test if volume act as slider order.
    IOS locator disabled today de-arming the house (out of the blue!) I hope it will stay on working.
    Normal light is not Hue
    Cycle: All normal lights, all Hue red, all Hue white >>>starting again
    endless till stop cmd
    Brightness max
    Color Hue>> red
    Hue white>>white
    I hope its clear
    //Sjakie
    /monthly_2019_09/image.png.91537f411fa41ff06253e04413524901.png" />
    Good morning Jan,
    /monthly_2019_09/image.png.6d9436744305b174828684b21823aaa4.png" />
    15 minutes ago, Sjakie said:
    Good morning Jan,
    Seems like that scene is not updated to v3.B63
    Jan,
    I am fully lost:
    Sonos player Krikrof slider goes to 50 but volume stay where it was
    Sonos player  no effect at all
    Sonos min controller slider goes to 50 but volume stay where it was
    Any idea?
    2 hours ago, Sjakie said:
    Jan,
    I am fully lost:
    Any idea?
    I'm not familiar with Krikrof's Sonos player. (I'm using NR you know :-) )
    Is the problem you can't set the slider value from ER?
      rule("slider(35,'Slider1')=45")
    35 is the id of the VD, '"Slider1" is the "ID:" of the slider control in the VD.
    @jgab where to start looking for error?
    [DEBUG] 11:30:36: NodeRedER3 - EventRunner v3.0 B64[DEBUG] 11:30:36: Fibaro software version: 4.550
    [DEBUG] 11:30:36: HC2 uptime: 660 hours
    [DEBUG] 11:30:36: Sunrise 06:37, Sunset 19:32
    [DEBUG] 11:30:36:
    [DEBUG] 11:30:36: Loading rules
    [DEBUG] 11:30:36: Error loading rules:/usr/share/lua/5.2/json/decode/util.lua:35: unexpected character @ character: 1 0:1 [V] line:
    [DEBUG] 11:30:36: V
    [DEBUG] 11:30:52: Aborting: Server not started yet
    Kopiera sc
    Edited by FrankT
    Solved - error in HomeTable?
    [DEBUG] 11:30:36:
    [DEBUG] 11:30:36: V
    Kopiera sc
    It's in the built-in json decoder. I would suspect it's when decoding something coming in from an external service, like Nodered.
    Do you make any external calls?
    You can try to patch json.decode just before 'main()' to see if you can get a better error message.
    The 'level' may need to be adjusted for error to report the interesting line number.
    Yes I make a lot of calls to NR but I think it was my HomeTable which got corrupted. I regenerated HT and now it's working again.
    Hello Jan
    I bought recently some smoke sensors.
    In my scene I am using those two rules but I doubt if this is okay? Must it be armed first? Am I covering all possibilities with this, please advice.
    --smoke
              Rule.eval("woonkamer.rookmelder:breached => post(#smokeAlarm); Telegram.msg(TID,'woonkamer rookmelder - rook'); notify('woonkamer rookmelder - rook')")
    --tamper
               Rule.eval("woonkamer.rookmelder:tamper => post(#sabotageAlarm); Telegram.msg(TID,'woonkamer rookmelder losgemaakt - sabotage'); notify('woonkamer rookmelder losgemaakt - sabotage')")
    Thanks in advance,
    //Sjakie
    Good morning Jan,
    I saw that one of my sceness had the message  Aborted not started yet (full debug window)
    Supervisor shows nothing only when restarted the scene.
    Is it possible Supervisor sends telegram if a scene stops?
    Please advice,
    //Sjakie
    6 hours ago, Sjakie said:
    Good morning Jan,
    Please advice,
    //Sjakie
    At the moment only push messages (fibaro:call(<phoneID>, "sendPush",<msg>) )
    You can add your phone ID in the beginning of Supervisor.lua's main() and it will notify you of restarts of scenes.
    local phonesToNotify = {<phoneID>}
    Hello Jan,
    When I was away today Telegram dit not send any message to my phone or computer?>> wierd
    Can I send from ER an email in case we have an alarm?
    If yes please give me an example.
    Thanks in advance
    //Sjakie
    Hello Jan,
    Sometimes when I want to see what happens in a scene  I cant because the scene renenwed the debug window and started with the next event.
    Is it possible to keep the last listed lines instead(lets say half of the debug window) off blank?
    Thanks in advance,
    //Sjakie
    /monthly_2019_09/image.png.a9c4fe6e8437c9a6515443f096161fa8.png" />
