    Ok, pushed V3 B40
    Be aware you need to fix your Hue setup.
    Hue.connect(<hue name>,<ip>)
    Hue.define(name, nil,id) -> Hue.define(name,id)
    Change nodered() to Nodered() if you used it.
    I encourage you to start using Nodered.post() instead of remote(...)
    /monthly_2019_08/image.png.b4c195d67af7e442e454ca25127a5653.png" />
    should it not be user on line 2562 instead of username?
    Yes, you can remove _HueHubs and just do
    Hue.connect(_HueUserName,_HueIP)
    The third optional argument to Hue.connect is to name the Hub if you connect to many bridges.
    Ex. Hue.connect(_HueUserName1,_HueIP1,"Hub1"); Hue.connect(_HueUserName2,_HueIP2,"Hub2")
    and while you are at it do
    Nodered.connect(_defaultNodeRed)
    too.
    and start using Nodered.post(<event>) instead of remote(_myNodeRed,<event>)
    i have this line for define and does not work,
    /monthly_2019_08/image.png.512386c5ed4a73952dcda7a8b903aa81.png" />
    my hometable looks like this for hue
    No, I just discovered that... I'm working on a fix - soon back...
    Hmm, Hue is broken now.
    The problem I have is that all calls to Hue is asynchronous. It means that when we do a call to Hue it takes a while and then we get a result. Meanwhile the rest of the code is executing,
    When we do a Hue.connect() it will take a while before we get the answer that among other things updates what devices are available in the Hue hub.
    If we directly afterward do a Hue.define it will not find the device as the previous connect has not completed yet.
    Previously I did the Hue setup and waited for it to complete before we called main() so then it worked. Now we call Hue.connect() in main() and it doesn't...
    One way is to move it back like it was before but it was a bit complicated too and I kinda liked to have a uniform model for Hue, Nodered, and Telegram...
    Ok, a fix. I pushed V3, B42.
    So, the way I have solved it for now is to have an extra function before main where you add your Hue.connect() commands.
    Only the Hue.connect(), Hue.define etc you do in main() as usual. I make sure that the connect() done in HueSetup() will finish before calling main()
    Ex.
    I will try to slow down with changes that break your scenes now :-)
    You are allowed to break a few of my scenes!!
    Working again, thanks @jgab
    OH NO! please don't slow down your excellent work and support on ER
    On 8/8/2019 at 8:18 AM, jgab said:
    function main() Nodered.connect("http://192.168.1.50:1880/eventrunner") -- or Nodered.connect(myNodeRedVar) rule("Nodered.post(#echo{value=9})") -- post asynchronous rule("Nodered.post(#echo{value=9},true).value") -- post synchronous
    updated your example
    Edited by jompa68
    Guest kallecux
    Hi there,
    i have an simple question in the "ER-community".
    How do you update the ER-Lua-Scripts in a smart way?
    It is not enough to replace the code after the end of
    main().....end
    Greetings
    Karl Heinz
    Just now, kallecux said:
    Hi there,
    main().....end
    Greetings
    Karl Heinz
    Normally it is. You also need to change the _version number.
    ..and there is an even simpler way.
    If you uncomment these lines in the ER scene' main() function
    It will check every morning at 06:00 if there is a new version of ER (look at my Github) and if so log a message to make you aware that there is.
    Then you can add another rule
    ...and it will download the latest version and patch the scene and restart.
    The two first rules are harmless to have enabled. The third should only be enabled when you decide to upgrade. Especially for V3 that is rapidly
    updated these days and sometimes (in the Fibaro tradition :-) ) comes with new bugs.
    However, I have the feeling that V3 is starting to stabilise...
    posted V3, B44.
    The structure for ER now looks like
    Define your Hue, Nodered, and Telegram data in the beginning if you need them
    In HueSetup() you make the Hue.connect(_HueUserName,_HueIP) if they are defined. If you have many Hue bridges you can add mode Hue.connects here.
    (don't forget that Hue.define(name, var,id) has changed to Hue.define(name,id) )
    In main() do Nodered.connect(_NodeRed) if you need nodered functionality.
    Change your "remote(<nodered URL>,<event>)" to "Nodered.post(<event>).
    I will soon remove the possibility to do remote(<url>,<event>) and remote() will only be for sending events to other scenes and will only accept a SceneID (number) as first argument.
    I will soon also add (synchronous) http request if you need to call other urls.
    Telegram setup is a bit more involved.
    You can only do one Telegram.bot(_TelegBOT) as Telegram don't like that a bot is polled from multiple instances.
    However, you can still send Telegram messages without needing to do Telegram.bot(TelegBOT)
    It requires that you have the chat id and the bot key.
    Telegram.msg({_TelegCID,_TelegBOT},<message>)
    If you need to do that in a rule I recommend that you define a telegram ID variable. _TelegCID,_TelegBOT are local and not accessible inside rules.
    Util.defvar("TID",{_TelegCID,_TelegBOT}) -- define ER script variable with Telegram ID
    then you ca do
    rule("@sunset => Telegram.msg(TID, 'Time to wakeup!')")
    Because Telegram is setup in main() after HT is read in you can store telegram credentials in you HT table if you want.
    Jan, perhaps an automatic backup before the update to a newer version?
    6 hours ago, jgab said:
    rule("#ER_version => log('Will update and restart...'); Util.patchEventRunner()")
    Wow thait is just wonderful. Your work is Awesome  ?
    @jgab is my dwSensor:armed=false right?  this means setArmed=0?
    When i check the logs i see that it do setArmed=1
    That's very strange. I test the same kind of code and it sets it to '0'.
    You run an old version of ER?
    B44
    B44
    If you just do
    rule(“55:armed=false”)
    change 55 for a real device? Still wrong?
    14 hours ago, jgab said:
    Still wrong?
    I got this working now, was a mistype of logic at my end.
    Another issue with this rule, seems to work but nothing in NR
    AH! Sorry, my node-red is running on default port 1880. Copy&paste from your example was 8080 ?
    Edited by jompa68
