20 hours ago, jgab said:
It should be compatible with v3.
No improvements - still as complicated as before :-)
This is a way to code using a "state machine", maybe I can come up with some syntax support for rules to make it easier to write. Will think about it.
Up and running with v3 now, just few changes (for and repeat)
@jgab possible to use "toggle" with huelights?
    Yes, I believe toggle should work. Do you get an error?
    Did not try yet, did rewrite my alarm scene a bit and was thinking of using :toggle on my huelights when door opens when it is armed.
    New version V3, B34
    - Queueing up Hue commands so we don't overload the Hue bridge.
    Guest kallecux
    Hello!
    I became a real HR3 fan! Thanks for that great work!
    Is there a way to get something like a .cargo property on the HT elements?
    Then i could save on the HT element properties that i need at a later time again.
    For example: a lamp lights up in the intensity 35, as soon as a movement is detected, the lamp in the brightness 100 will light up. After x minutes the lamp switches back to 35.
    At the moment I solve this with a separate variable per lamp to store the :value.
    It would be elegant if you could save the 35 "at the lamp" to use this value later:
    Thanks - Karl Heinz
    Edited by kallecux
    1 minute ago, kallecux said:
    Hello!
    Thanks!
    Tanks - Karl Heinz
    In general you don't need to store things in fibaro globals like where you store the HT. Because ER is running all the time you can use temporary ER/Lua variables.
    The HT is read in and you can use that structure to store additional elements. However, if you restart the scene the value will be lost.
    You could write out the HT once in a while to persist it but usually you don't need that.
    The save the value of a dimmer value before lightning it up to 100% and then restoring it back to the old value could look like below (we use the HT for temporary storage).
    Be aware that wohnzimmer.lampe is a "leaf" with a deviceID number as a value. To add something it needs to be a non-leaf node.
    Here we use wohnzimmer.lampeV (as in lampe Value)
    P.S If you have access to a PC or Mac I highly recommend setting up the off-line environment for developing and testing ER scenes.
    Guest kallecux
    Is there a way to monitor a hue lamp only one time?
    Like: Hue.monitor(Schreibtisch,0)
    because the :value is wrong, when changed in background.
    Karl Heinz
    Karl Heinz
    How does you rule look like?
    Do you turn off the lamp with a physical button?
    If you turn on/off the lamp with a rule
    "Schreibtisch:on" then the local database is instantly updated with the value.
    If you turn on/off the lamp with the Hue app or physical button you need to monitor it in the background to get the state change.
    Hue.monitor(Schreibtisch,1000) polls the lamp every second and you get a trigger when it changes vaue so the rules like
    "Schreibtisch:isOn => log('Hipp')" will work.
    Hue.monitor(Schreibtisch,0) turns off the monitoring of the lamp.
    If you have a sensor in a room you can turn on the monitoring of Hue lamps when someone enters the room and turn it off when it's not needed.
    "motion:breached => Hue.monitor(Schreibtisch,1000)"
    "trueFor(00:10,motion:safe) => Hue.monitor(Schreibtisch,0)"
    thus saving some resources.
    However, it doesn't cost that much to let monitoring run constantly (poll every 1-2 s)
    Guest kallecux
    This is my rule:
    If i change the Hue-Lamp via Hue-App then value in the first rule is wrong.
    Karl Heinz
    36 minutes ago, kallecux said:
    This is my rule:
    Karl Heinz
    If you add
    it works?
    @jgab need some help with an more advance rule that i do not now how to handle.
    want to add delay of post(#arm) so it will not start count before i have closed front door.
    This is what i have today
    I think it looks ok. When you lock the door it will post an #arm in 2min. and cancel it of you unlock.
    Does it misbehave?
    Does it misbehave?
    device 812 is my zipate keypad.
    Ok, I'm coming out with V3, B40
    and there are some incompatible changes that will require you to update your scripts (for Hue and if you have started to use nodered())
    -Nodered()
    A new function Nodered() that replaces the nodered() with lowercase that came with V3.
    Instead of relying on a global _defaultNodeRed or _myNodeRed you make a connect(url) to the url you want inside main().
    You need to do a connect to setup the connection before you can do Nodered.post()
    Ex.
    -Hue()
    Hue is almost the same. The difference is that we don't rely on a global _HueHubs variable to initialise. Instead we have a dedicated connect() function that we call inside main  (like Nodered)
    Ex.
    The other difference is that Hue.define only takes 2 arguments now. Hue name and deviceID. deviceID is optional and if left out will be assigned to numbers starting at 10000...
    Hue.connect() still supports connecting to several Hue bridges. Just make several connects()...
    -Telegram()
    New function Telegram().
    The Telegram.bot command takes a bot_key and an optional tag (defaults to "Telegram") and will post incoming messages as
    {type=<tag>, user=<userid>, text=<text>,id=<chatID>, info=<info>}
    Telegram bot will also persist chatIDs, user names and bot_key in a fibaro global "TelegramUsers"
    If users are persisted, username or chatID can be used as <id> to Telegram.msg()
    If no users are persisted, {chatID,bot_key} can be used as <id>. Useful if you want to push a message without having started a bot.
    Ex.
    In this way we have a model for harmonising functions for integration with external systems and we don't need a lot of "global" initialisation variables spread across the code.
    Because we initialise them inside main() we can fetch configuration data from our HT or from user defined variables in the scene - whichever you prefer.
    I will push this version later today.
    Good morning Jan,
    Looks very good to be all combined in main!
    Another big step forwards.
    sorry for the picture where that is coming from?
    Does it misbehave?
    Ok, I haven't tested this but try it....
    22 minutes ago, Sjakie said:
    Good morning Jan,
    Good, the picture with the "Couldn't post event" scared me. Are you still getting those messages?
    4 minutes ago, jgab said:
    Ok, I haven't tested this but try it.... It may post #disarm even if it didn't post #arm, is that a problem?
    Will do, thanks :D
    Hello Jan,
    What is better to do system wise?
    Using same device in two scenes >>>triggers often?
    as trigger or work with remote(111,#example)>>>>triggers once?
    Please advice
    26 minutes ago, Sjakie said:
    Hello Jan,
    Please advice
    It's better  to let device trigger in both scenes.
    The remote thing is best for user defined events or if you add some extra info to a trigger.
    Jan,
    the picture came from??????
    When I pushed submit this picture came with it, its a pic from the old arm scene, dont worry.
    //Sjakie
