Hello Jan,
A while ago you helped me with Hue lights to flicker I gues its wrong now:
/monthly_2019_08/image.png.47ff7d8a143732da1aaffac32da6e965.png" />
 --ALARM LIGHTS FLIKKERING
   colorParams2={  -- Table of color values
    {bri=245, hue=65535, sat=250, transitiontime=1, col=0},
    {bri=50, hue=65535, sat=250, transitiontime=1, col=0},
  -- Every 15s, pick a new value from colorParams, wrap around at end of table.
  colorShow2 = Rule.eval([[@@00:00:08  =>
    alarmlights:value=colorParams2[colorIndex2];
         colorIndex2=(colorIndex2 % size(colorParams2))+1
    ]]).disable() -- Start disabled, next rules enable us.
  ---- in case of alarm after sunset the light will switch on
          Rule.eval(" (sunset..@unrise) & #AlarmStateUit => wait(00:00:10); woonkamer.ambitvlight:on; wait(00:00:02) ; woonkamer.lampplafondtvzijde:on; wait(00:00:02); woonkamer.lampplafondklokzijde:on; wait(00:00:02); voortuin.spotvlag:on; wait(00:00:02); achtertuin.spotbudha:on; wait(00:00:02); achtertuin.spotfontein:on; wait(00:00:02); achtertuin.spotfontein:on; wait(00:00:02); woonkamer.spotbeeldlinks:on; wait(00:00:02); woonkamer.spotschilderijlinks:on; wait(00:00:02); woonkamer.spotkastlinks:on; colorIndex2=1; enable(colorShow2)") -- Start show
        Rule.eval("trueFor(00:15, alarmapp.alarmrelais:isOff)) => {woonkamer.spotbeeldrechts, woonkamer.spotschilderijrechts, woonkamer.spotstoelsjaak}:off")
    18 minutes ago, Sjakie said:
    Hello Jan,
    It's the "Rule.eval(" (sunset..@unrise) ..." that causes the error.
    Should probably be
    Rule.eval("#AlarmStateUit & sunset..sunrise  => ...
    Sorry for this stupid error.
    Great that in this version shows the error.
    Have a good night,
    Tonight I discovered that my door lock wouldn't lock.
    The rule is like this.
    @22:00 => frontdoor.doorlock:wake; wait(00:00:10); frontdoor.doorlock:secure.
    Error messageID
    :373 does not support action 'wakeUpDeadDevice
    Is this something that will work in the future?
    Thanks, I had missed that.
    I'll have a new version for tomorrow morning with a fix for that (and some more stuff)
    13 hours ago, jgab said:
    The #VirtualSensor event that you receive in B you re-post inside B as a #property event - this will look exactly like a fibaro trigger for the rules.
    You can then reat them like any device that have triggered B and do things like this in B:
    Was that an answer to you question?
    i have now setup like this but not 100% working solution, have i done something wrong with my logic?
    Debug(from ZBS)
    I see posting but do not turnOn lights
    Debug(from ZBS)
    You accidentally quoted the device variables (pirSensor.kallaren, dwSensor.kallardorr), you want their values.
    Because you can only get #VirtualSensor from the 2 sensors you subscribe to you can make one generic handler for incoming #VirtualSensorns
    3 minutes ago, jgab said:
    You accidentally quoted the device variables, you want their values.
    Ah! an small ' have the power to destroy everything. Thanks @jgab ?
    @jgab how can i decrease the sonos tts to only 1 time when coffee timer have stop(now it say tts 2 times)
    more debug
    Edited by jompa68
    Can you post me the rules? (I tried the coffee rule in an earlier post and I only get one notification after the timer expires)
    Can it be that you have kafferyggaren both as an VirtualDevice and also declared it as a trigger in the scene? (I guess you would get double triggers then)
    i have both power and value in header, should not be a problem, or?
    Hmm, every time you set coffeeTimer it will trigger the trueFor rule (because the left hand side contains $coffeeTimer).
    THis is normally not a problem... but my suspicion is that the loop that counts down coffeeTimer sets coffeeTimer to 0, just after the trueFor has become true. The problem is that the trueFor makes a wait (for the sonos) before it turns off kafferyggaren. During that wait, the trueFor is triggered by coffeeTimer becoming zero and runs the action again.
    When a rule makes a 'wait' there is the potential that another rule is scheduled in.
    The solution is to move turning off kafferyggaren earlier, before the wait.
    Try that and see if it works.
    Yeah, did work perfect.
    Another question, how come log say
    but i set it to 02:10 in rule
    Maybe the rule is overly complicated. Maybe this works (no need for trueFor as we can test on coffeeTimer==0)
    How does the rest of the dishwasher rules look like? Seems like HM is broken or HM is called with strange value.
    @jgab
    I have problem with hue support in v3:
    result is error in ZBS:
    [31mSat/Aug/03,11:50:18:[217:1] Error in 'HueVypinacChodbaPrizemiDvere:buttonevent => log('Hue key:%s',HueVypinacChodbaPrizemiDvere:buttonevent)': EventRunnerLights.lua:2159: attempt to index a nil value
    Line 2157:    ['%set'] = function(e,s) if isTriggerVar(e[2]) or isGlob(e[2]) then error("Can't assign variable in rule header") end end,
    Line 2158:    ['%prop'] = function(e,s)
    Line 2159:>>>      if not getFuns[e[3]][4] then return end
    Line 2160:      local pn = getFuns[e[3]][2]
    Line 2161:      local cv = ScriptCompiler.compile2(e[2])
    [0m
    [31mSat/Aug/03,11:50:18:[217:1] Error loading rules:EventRunnerLights.lua:2288: EventRunnerLights.lua:2159: attempt to index a nil value
    2 hours ago, petrkl12 said:
    @jgab
    Ok, it should work again - pushed v3, B32.
    I'm trying to come up with a smother model for "user defined" devices like Hue lights with user defined properties. It should be much easier to create them.
    Perfect! Works!
    Error messageID
    Now this works again :)
    Thank you!
    will se if i can find som more tonight ;)
    @jgab good work with the new version. I feel that it is much faster now.
    cheers m8’s
