Hello Jan,
Excellent error reporting!! This device is giving me headache!!! Yesterday I added >>error no configuration and now it disappeared??
/monthly_2019_08/image.png.38fb24b9adbaa458a2c45b3a14d2c861.png" />
    1 hour ago, jompa68 said:
    same behavior in WC
    Ok, the problem is trueFor. I have changed the execution model for ER rules but I haven't (yet) changed it for trueFor. I thought I could get away with it but it turns out that trueFor doesn't work with rules that also have 'wait' in them.
    I will spend the morning rewriting trueFor using the new model and hopefully everything will be smooth again...
    Pushed v3, B26
    -new implementation of 'trueFor', now compatible with 'wait' and much cleaner. It was something I needed to do anyway but had pushed for the future...
    (the coffee example runs for me now. There was a syntax bug in the example I gave, missing a ';' in " $coffeeTimer -= 60;". Fixed in earlier post)
    I had to rollback to version 2.0 yesterday evning, the light wouldent light up.
    i got this errorcode.
    /monthly_2019_08/image.png.4806dad12635ea7dfedbdb5de2a908d2.png" />
    rule 11 below
    Function "turnOnAllChildrenLamps" below
    rule 11 below
    _copy has changed to Util.copy
    Wow that worked :)
    Big thanks!
    3 minutes ago, sonnyboy said:
    Wow that worked :)
    Big thanks!
    Just pushed v3, B27.
    -new function HM(<time>), formats a time into "HH:MM"
    Ex. rule("log('Time is %s',HM(now))")
    -new function Util.randomizeList(list). Takes an table/list of elements and return a randomised version of the list
    @sonnyboy version of turning on lamps could thus be written
    Here is a simple Telegram integration in ER without having to rely on Node-red.
    Go to BotFather in Telegram and create a new bot - and get a bot HTTP access key
    then you can make ER rules like this
    I will probably add this as a standard function in ER when I tested it a bit more.
    Fixed support of multiple bots
    @jgab
    both this coffeTimer and dishTimer rules gives now error and i cannot see why.
    Error
    27 minutes ago, jompa68 said:
    @jgab
    Error
    Sorry, miss in my previous fix. Pushed v3 B28.
    Now there is both  HM() and HMS() - latter returns "HH:MM:SS"
    So you can remove the Lua version of HM.
    There is a variable '_MARSHALL' that if set to false will not auto convert string in fibaro globals to values. However, when one gets used to it it is quite convenient.
    Now it supports numbers, booleans and "time strings" (HH:MM[:SS])
    I was thinking to auto convert tables back and forth too - then one could do
    The criteria would be that if the string stored in the global starts with '{' or '[' it would be considered a json.table.
    Would that be a good idea? Any potential problems?
    @jgab
     can i replace physical sensors to virtual sensors from pub scene?
    11 minutes ago, jompa68 said:
    @jgab
    No, not directly.
    As I understand it, you have sensors that are triggered by scene A and A then publish them as Virtual sensors?
    Then you have a scene B that subscribe to Virtual sensors and carry out actions when it receive a Virtual sensor?
    Because they are physical devices and  you can call fibaro:call and fibaro:get on the devices from scene B, there is an easier approach.
    In scene B:
    The #VirtualSensor event that you receive in B you re-post inside B as a #property event - this will look exactly like a fibaro trigger for the rules.
    You can then reat them like any device that have triggered B and do things like this in B:
    Was that an answer to you question?
    Yeah, sounds right but not working. I can see event comes in from pub scene but then nothing happens. No post (added a log to that line)
    I assumed that they had deviceID and value. How do the VirtualSensor structure look like?
    Hello Jan,
    My telegrams are not coming by NodeRed
    ESceneID contains:
    _myNodeRed   = "http://192.168.1.89:1880/eventrunner" -- Ex. used for Event.postRemote(_myNodeRed,{type='test'})
    local _defaultNodeRed= "http://192.168.1.89:1880/eventrunner"
      function telegram(ref,msg)
        local tmsg = Util.copy(ref)
        print (json.encode(tmsg))
        tmsg.content=msg
        Event.postRemote(_defaultNodeRed,{type='telegram',msg=tmsg})
       Event.postRemote(_myNodeRed,{type='telegram',msg=tmsg})--oud
    rule I use to send telegram:
    $Telegram='basis huis is bewaakt'
    This will send to Nodered
    Event.postRemote(NodeRed,{type='echo', data='ESceneID'})
    Event.postRemote(NodeRed,{type='echo', data='1516'})
    How to solve?
    Please advice
    I think something is broken in the code, this should work.
    i see the event arrive to sub scene but nothing more
    Yes, bug! Pushed V3, B30
    @jgab in ZBS: ID:448 does not support property 'TCPPort'
    Same in HC2:
    Error loading rules:fibaro:get(Koupelnaprizemi.Vypinacuzrcadla,"TCPPort"),/opt/fibaro/scenes/228.lua:3181: ID:448 does not support property 'TCPPort'
    Thanks for adding.
    Edited by petrkl12
    Same in HC2:
    Thanks for adding.
    Will push a fix tomorrow morning
