Guest kallecux
Hello!
I read with great interest some posts and the wiki on GitHub, but I do not find the perfect entry yet.
I think the system is very good - I think I can compress some scenes considerably!
I have the following beginner questions:
1. How can I turn on a lamp for a certain amount of time when move ist detected?
2. Why is there a difference between Rule and Rule.eval?
Thank you in advance!
Karl Heinz
8 minutes ago, kallecux said:
Hello!
Karl Heinz
Hello Karl Heinz,
here is an example how you can do it.
Remember to add 111 and 222 to header in scene.
Your second question is simple, rule is short name for rule.eval. You set this value in the beginning of function main and then you can user rule instead of rule.eval
    3 hours ago, kallecux said:
    Hello!
    Karl Heinz
    Hi @kallecux
    The EventRunner framework provides a lot of options and most tasks can be solved many ways.
    You are right that one can often combine many scenes into one ER (EventRunner) scene. I have one main scene and a few helper scenes.
    So, there are 2 things going on. One is to write scenes with Lua that adhere to the event model provided by the EventRunner framework.
    The other approach is to write "rules" in something we call EventScript - and that is what people mostly discuss in this forum thread.
     EventScript is a "programming" language made up by me to make it easy to support many typical home automation tasks.
    EventScripts are strings given to the function Rule.eval(<string>) that compile the string to an efficient representation iof the rule for later execution when the rule is triggered by devices or other events.
    2. Rule.eval() is a function belonging to a class of functions available under Rule.*. To make it easier to write functions we often define a shorthand for Rule.eval, called 'rule'
    1.  To turn on a lamp for a certain amount of time when a motion sensor is detected we can write like this
    (I just saw that @jompa68 answered you question with a bit more advanced example with many sensors and lights)
    when the lamp is breached we turn on the lamp, wait 5min and then  turn off the lamp.
    More clever is that we would like to turn off the lamp when the sensor has been "safe" for 5min
    Here we have 2 rules. One that turns the lamp on if sensor is breached.
    The other that monitors the expression "motion:safe", and if it is true for 5min executes the action "lamp:off"
    These rules can be much more complex and if you have use-cases you want to solve but can't figure out how, please post in this thread and ask.
    The documentation on Github is ok but not completely up to date as the evolution of the framework is quite rapid and most of the discussions and announcements are here in the Fibaro forum.
    Regards /JanG
    @jgab
    it looks that this rule doesn't work:
    5 hours ago, petrkl12 said:
    @jgab
    Oops, when I rewrote the engine I forgot to add it. And I realised that I don't use any trigger variables in my scenes now so I didn't miss it.
    I have pushed v3, B33 with a fix for it.
    However, it's a bit differently expressed now. I did not like the '_' underscore notation as it reminds more of variables that should be ignored according to Lua practices.
    Now instead you have to explicitly declare the variable as a "trigger variable" and it can have any name. Of course they can still start with '_' if you like it...
    Util.defTriggerVar(<var name>[,<expression>]) takes an optional initialisation value that doesn't cause a trigger at declaration time. In any rule executed later that the declared trigger variable is assigned a new value it will create a trigger event of typ #variable{name=<name>, value=<value>}
    I realised that I just checked in a version with more extensive automatic conversion of values for fibaro globals inside ER rules.
    Values are always stored as strings in fibaro globals, but when we access them from ER rules we automatically convert them back to bools/numbers/tables..
    The last one can trip up your code. If you have json tables stored in fibaro globals (like HomeTables) they will be automatically json.decoded when you access them. If you now call json.decode on them you will get an error as they are already decoded for you.
    However, this is only inside ER rules and does not affect calls to fibaro:getGlobal.
    At the moment rule("$myVar[2] == 4") is a bit expensive as the value in $myVar is converted from string to table at every access. However, it is possible in some cases to cache that value and I will implement it in a future release. (on the other hand, json.decode is surprisingly fast on the HC2, at least for moderately sized tables)
    OK, Thanks.
    Is it possible to use mass definition? i.e.
    Just now, petrkl12 said:
    OK, Thanks.
    Next release maybe ;-)
    Problem is the initialisation value. Same for all vars? or list of value per variable?
    For now you can do
    Util.map(Util.defTriggerVar,{roomMotion1,roomMotion2,roomMotion3}) to declare and set all to nil
    Util.map(function(n) Util.defTriggerVar(n,0) end,{roomMotion1,roomMotion2,roomMotion3}) to declare and set all to 0
    Util.mapkl(function(n,v) Util.defTriggerVar(n,v) end,{roomMotion1=0,roomMotion2=1,roomMotion3=0}) to declare and set all to individual values
    For now you can do
    Thanks, only same value for all could be OK
    @jgab
    error in :
    table index is nil
    here:
     function self.defTriggerVar(var,expr) _triggerVars[var]=true; self.defvar(var,expr) end
    and this also doesn't work:
    Sorry, too early in the morning. Need name strings of variables.
    and
    13 hours ago, jompa68 said:
    Hello Karl Heinz,
    and it should be
    @jgab Thanks!
    Now all my ER scenes are converted to version 3. Thanks a lot!
    Your framework is number one!
    And Fibaro should hire you to help them create the best system for home automation !
    Guest kallecux
    I have many Hue-Lamps and i tried the sample above. (Light on for x minutes when movement is detected).
    Whe i use a Hue-Lamp i get the error:
    [DEBUG] 14:08:08: Error in 'Rule:4[trueFor(00:01,Bewegung_Wohnzimmer:safe & Schreibtisch:isOn) => Schreibtisch:off;...]': /opt/fibaro/scenes/69.lua:1581: fibaro:get(83,"value"),/opt/fibaro/scenes/69.lua:533: ID:83 does not support property 'value'
    I think this is because the Hue-Lamp has no property "value". Is there an other way to control the hue lamp?
    There is an experimental hue-support....ist ER3.
    There is another question:
    Why are in this rule two brackets "[[   ]]" at the begin and the end?
    rule([[trueFor(00:10,basement_move:safe & lights:isOn) => lights:off; log('Turning off lights after 10min of inactivity basement')]])
    When i read other examples there are no brackets...
    Sunny greetings!
    Karl Heinz
    Sunny greetings!
    Karl Heinz
    The two brackets "[[   ]]" is used for Lua strings that can span over multiple lines. Makes formatting of long rules nicer.
    Yes, ER has it's own support for Hue lamps and you need to set them up.
    In the beginning of the scene do
    <HueUserName> is the Hue key  and <IP> id the ip address to the Hue hub "192.18.1.xx"
    Then you need to assign them deviceID, i.e. numbers. To do that you need to know the name of the lamp in the Hue app.
    If you have setup _HueHubs you can do Hue.dump() to get a list of all the devices registered with the Hue hub.
    So, if you have a Hue lamp with the name "Schreibtisch" you do
    By doing that you have access to the light with fibaro:call/fibaro:get and can do things like
    and they behave almost like any other fibaro light, in a nicer and more compatible way then Fibaro's own implementation (that's what I think at least).
    You can also use them inside ER rules like ordinary lights. However, it's good to have a variable defined as 12000 in this case or have {Schreibtisch=12000} in a "hometable".
    One issue is that we would like to get events if the light changes state - like we get triggers when Z-wave device changes state. Unfortunately Hue doesn't support that so we need to poll the light with regular intervals to see if it changed state. We can do that with the Hue.monitor command. It will monitor the Hue light in the background and if it changes state it will post a trigger that we react to.
    In this case it allows us to have an up to date state of the Schreibtisch lamp so that the :isOn command returns a correct value.
    ER rules can access Lua global variables so we can do "Schreibtisch=12000" instead of "rule('Schreibtisch=12000')" and still access 'Schreibtisch' inside ER rules. However, it's usually better to keep them in a "hometable" if you have many identifiers.
    Here 'Bewegung_Wohnzimmer' is assumed to be a normal Z-Wave sensor otherwise we need to monitor that sensor too.
    In general, if you don't need triggers from the Hue device you don't need to monitor it (it takes some resources and generates traffic towards the Hue hub).
    Do you have many Hue hubs? In that case you can add them to the _HueHubs list.
    Here are some more info
    Guest kallecux
    @jgab
    Thank you for the fast response!
    Now im "playing" with the Hometable and i read this topic from AutoFrank
    Tutorial - Using a Hometable to store device and scene ID's
    but i get this error in ER3
    [DEBUG] 16:53:37: Demo - EventRunner v3.0 B33
    [DEBUG] 16:53:37: Fibaro software version: 4.550
    [DEBUG] 16:53:37: HC2 uptime: 0 hours
    [DEBUG] 16:53:37: fibaro:getValue(1,"sunriseHour")="05:43"
    [DEBUG] 16:53:37: fibaro:getValue(1,"sunsetHour")="21:18"
    [DEBUG] 16:53:37: Sunrise 05:43, Sunset 21:18
    [DEBUG] 16:53:37: Hue system inited (experimental)
    [DEBUG] 16:53:37:
    [DEBUG] 16:53:37: Loading rules
    [DEBUG] 16:53:37: Error loading rules:/opt/fibaro/scenes/69.lua:915: bad argument #1 to 'pairs' (table expected, got nil)
    Is there an other tutorial to create the right HomeTable?
    Karl Heinz
    @jgab
    [DEBUG] 16:53:37:
    Karl Heinz
    I have done like this,.
    @jgab
    [DEBUG] 16:53:37:
    Karl Heinz
    Well, what you can start with is to define a hometable in the ER scene, like the example table that is provided.
    The advantage with storing it in a fibaro global variable is that other scenes can also use it. However, start by defining on by hand in the main() of the ER scene and you can later save it to a fibaro global if you need it. Something like below. I don't know how you want to structure it but rooms and devices are usually ok.
    This also allows easier names per device as you can have both bedroom.lamp and kitchen.lamp.
    Guest kallecux
    Thank you for the hint, but i am looking for the LUA-Script which fills a global to read it in ER3 for that:
    --or read in "HomeTable" from a fibaro global variable (or scene)
    local HT = type(_homeTable)=='number' and apiget("/scenes/".._homeTable).lua or fibaro:getGlobalValue(_homeTable)
    HT = type(HT) == 'string' and json.decode(HT) or HT
    Greetings!
    any improvments on this code @jgab? Possible to use in v3?
    It should be compatible with v3.
    No improvements - still as complicated as before :-)
    This is a way to code using a "state machine", maybe I can come up with some syntax support for rules to make it easier to write. Will think about it.
