5 minut temu, domin12 napisał:
Jan ,
there is no function called _copy any longer ?
how could i change this function to get proper working :
Jan, i copied this function from the old version, and it working
    5 minutes ago, domin12 said:
    Jan ,
    A lot of these functions are moved to Util.
    7 minutes ago, jompa68 said:
    So, _defaultNodeRed is nil when you invoke the rule. (_NR:nil)
    Do you accidentally set it in another rule or code?
    No, at least what i can see... here is my start code
    Jan, many thanks to You again for support,
    ER is up to date, and everything seems to be ok right now ......
    Edited by domin12
    @jgab it solved now, did not like local _defaultNodeRed
    Ah, of course. ER rules can only access lua globals. I have tried to  make as many variables local as possible as globals easily makes a mess...
    Instead of making _defaultNodeRed global I will add Util.definevar("_defaultNodeRed",_defaultNodeRed) in the next version (I wait an hour before pushing next version as there may be more bugs to fix)
    Pushed v3 B16.
    _defaultNodeRed is available inside ER rules now. (but you should start to use the nodered() function instead)
    Also, now if you have a rule of type
    Because dailys/@ was only rescheduled every midnight, if you changed Test during the day it would not take effect until next day which sometimes was a problem. E.g if you have a VD that allows people to set alarms by setting a fibaro global. Now these rules will automatically reschedule if any globals used in the time expression changes.
    There is an ER command  ''redaily'(<rule>)' to force a reschedule that I may remove in a future release.
    But you should be able to use the nodered() function that uses the global _defaultNodeRed variable
    No Echo from NR (there is nothing changed in NR) and another error
    the rules:
      rule([[trigg1=0;trigg2=0;trigg3=0;trigg4=0;trigg5=0;m1=tonumber(screen:value); m2=tonumber(sovm:value);m3=tonumber(tvm:value); m4=tonumber(extram:value);m5=tonumber(altanm:value); yttertemp=tonumber($yttertemperatur); vindstyrka= tonumber($windhastighet); moln=0;lb = tonumber(luxb:value); lf = tonumber(luxf:value)]])
     rule([[screen:scene >= 21 | screen:scene <= 16 => trigg1 = screen; log('screen:scene = %s',screen:scene)]])
     rule([[sovm:scene >= 21 | sovm:scene <= 16 => trigg2 = sovm; log('sovm:scene = %s',sovm:scene)]])
     rule([[tvm:scene >= 21 | tvm:scene <= 16 => trigg3 = tvm; log('tvm:scene = %s',tvm:scene)]])
     rule([[extram:scene >= 21 | extram:scene <= 16 => trigg4 = extram; log('extram:scene = %s',extram:scene)]])
     rule("sensors={13,370,84,92,34,230,386,439}")
     rule("sensors:breached => d=env.event.deviceID")  --; processOne(d)")
     rule("log('Echo returns %s',nodered(#echo{test='Hello'},true).data.test)")
      rule("@@00:01 => nodered(#wetter{}); yttertemp=tonumber($yttertemperatur); vindstyrka= tonumber($windhastighet); vindriktning= $windriktning; regn=tonumber($regn)")
     -- rule("@@00:01 => nodered(#egetwetter{data='yttertemp, vindstyrka, vindriktning, regn'})")
      rule("#wetter => moln=env.event.data.clouds; lb = tonumber(luxb:value); lf = tonumber(luxf:value); m1=tonumber(screen:value); m2=tonumber(sovm:value); m3=tonumber(tvm:value); m4=tonumber(extram:value); m5=tonumber(altanm:value);log('moln= %s',moln)")
    Output:
    ed/Jul/31,16:06:32:[10:1] Scene running
    Wed/Jul/31,16:06:32:[10:1] fibaro:get(arbetsrum.ljus_arbetsrum,"value")="7143.00",1563875101
    Wed/Jul/31,16:06:32:[10:1] fibaro:get(lillasovrum.ljus_lilla_sovrum,"value")="13178.00",1563875102
    Wed/Jul/31,16:06:32:[10:1] fibaro:get(markiser.screen,"value")="98",1563958669
    Wed/Jul/31,16:06:32:[10:1] fibaro:get(markiser.markis_sovrum,"value")="99",1563875101
    Wed/Jul/31,16:06:33:[10:1] fibaro:get(markiser.markis_tv,"value")="99",1563875100
    Wed/Jul/31,16:06:33:[10:1] fibaro:get(markiser.markis_lilla_sov,"value")="99",1563875100
    Wed/Jul/31,16:06:33:[10:1] fibaro:get(markiser.Altanscreen,"value")="98",1563875105
    Wed/Jul/31,16:06:33:[10:1] moln= 75
    Wed/Jul/31,16:06:37:[HC2 ] Error in Scene:10 "NR3TEST.lua:2062: bad argument #2 to 'error' (number expected, got string)"
    stack traceback:
        HC2.lua:1481: in function 'runTimers'
        HC2.lua:227: in function 'startup'
        HC2.lua:3493: in main chunk
        [C]: in function 'dofile'
        NR3TEST.lua:23: in main chunk
    the rules:
    Output:
    stack traceback:
    Have you updated to the latest version, it was a bug in earlier version of v3.0.
    Latest is "3.0","B16"
    Did you update the NR flow (it's the encodeEvent node that have changed for v3.0)
    Jan sorry did you have any idea?
    IOSLocator:
    rule("phoneID=447")
    error>>call global nil value
    447 and 470 are listed in IOS Fibaro both have error
    Please advice.
    IOSLocator:
    rule("phoneID=447")
    Please advice.
    Sorry, spelling error.
    Updated now to 3.0,B16, but in your post from yesterday you didn't show the encodeEvent node but the PollySonos node. How should the encodeEvent node be changed?
    Sorry Jan, same error
    /monthly_2019_07/image.png.3f701437d489b5229fe7a368e1eb7ef7.png" />
    change 'rule' to 'Rule.eval'
    The javascript in the encodeEvent node should be
    Jan,
    /monthly_2019_07/image.png.e111f7370a8170fafc6d2f97997c92aa.png" />
    Jan,
    Are you inside main() ?
    nope!!! You are great!!!
    /monthly_2019_07/image.png.5a1460a5b876c0b0e600bfadb6cb4cf9.png" />
    Thank you Jan, now all my flows are working in V3. GREAT!  I have no experience in JavaScript, but better in ancient Fortran
    /F
    Pushed V3 B17.
    Nasty bug that effected ER rule with a 'wait' as last command (or any other command that did a coroutine 'suspend' as last instruction).
    @jgab One more question
    i have rule :
    rule([[{945,1057}:breached & 20:00..23:58 =>||744:isOff >> log('..lights on...'); 744:on]])
    which does not work because of the range of hours, how to improve it to work properly?
