              Rule.eval("@23:10 & day('sat') & hal.locatiegezin:isOff => post(#flaglightOff);  lightsHal:on ; wait(00:00:05) ; lightsHouse:off ;  wait(00:00:10) ; lightsHfdslpkmr:on ; wait(00:00:20) ; lightsHal:on ;wait(00:04:30) ; lightsHfdslpkmr:off; log('Avond verlichting op tijd uit als wij afwezig zijn')")
What should be in header?
    58 minutes ago, Sjakie said:
    Hi Jan,
    Is one mailbox message not enough?
    It's only one. set _debugFlags.fglobal=false so you don't have to see it. I will set it to false as the default in next version.
    1 hour ago, Sjakie said:
    Okay will update.
    Jan ready for the next one?
    Rule.eval("$StookSeizoen=='Ja' & hal.locatiegezin:isOn & once(trueFor(00:05,eetkamer.deur:breached)=> remote(_myNodeRed,#speak{data='de deur naar de serre is open en de thermostaat wordt ingesteld op 17 graden'})  ; httpGet('http://192.168.1.101/data.json?heater=0&setpoint=120&thermostat=0'); log('Verwarming uit serre op temperatuur')")
    You are missing a ')' for the 'once' command. However, I'm not sure this works anyway (combining for and once this way - I removed the once in the version below)
    The rule i is complaining about is something that looks like
    Rule.eval("post(#flaglightOff) => remote(1627,...
    which is wrong. You need to start with a trigger like an event. Do you mean Rule.eval("#flaglightOff => remote... ?
    56 minutes ago, Sjakie said:
    Jan,
      Rule.eval("achtertuin.fontein:isOn =>  remote(_myNodeRed,#speak{data='de fontein wordt gestart'}) ,10*repeat(0)")
    Here I am clue less!
    You have ",10*repeat(0)")" at the end of the rule that doesn't make sense. Is it a trueFor-again missing ?
    Jan,
    To be honest I have no idea.
    Can it be the fountain start >>message if starts within 10 minutes no annoucement or something like that?
    54 minutes ago, FrankT said:
    @jgab
    Hm, testing. Got error 'Error loading rules:NR3TEST.lua:1814: NR3TEST.lua:1650: attempt to index local 'res' (a nil value)'
    Ok this seems to be the same problem as @jompa68 has. The solution for now is to set the interpreter in ZBS to Lua 5.2. I will investigate to understand what is going on with the different versions of Lua.
    OK, now working with 5.2.
    Hello Jan
    /monthly_2019_07/image.png.bc5deda6724f4dfcff12555f9e2ac340.png" />
    @jgab Hi, Jan
    more problems
     rule([[screen:scene >= 21 | screen:scene <= 16 => log('screen:scene = %s',screen:scene)]])
     rule("sensors={13,370,84,92,34,230,386,439}")
     --rule("sensors:breached => d=env.event.deviceID; processOne(d)")
     rule("nodered(#echo{test='Hello'})")
     Error in 'nodered(#echo{test='Hello'})': NR3TEST.lua:337: bad argument #1 to 'abs' (number expected, got nil)
    Tue/Jul/30,17:26:05:[10:1]
    Line 335:      else fibaro:startScene(sceneID,payload) end -- call other scene on HC2
    Line 336:    else -- on emulator
    Line 337:>>>      fibaro:startScene(math.abs(sceneID),payload)
    Line 338:    end
    Line 339:  end
    Tue/Jul/30,17:26:05:[10:1] Error loading rules:NR3TEST.lua:1903: NR3TEST.lua:337: bad argument #1 to 'abs' (number expected, got nil)
    Hello Jan,
    Can you give me line to get every hour a log?
    You sure that your position changed (enough?). You could log every time you get a new position to see if it works.
    Thanks for your effort and support
    Ok, pushed new version of HC2.lua that fixes the problem (was a "bug" in Lua 5.1 version of table.unpack)
    However, I would recommend to run under v5,2 as that is the same as on the HC2.
    49 minutes ago, FrankT said:
    @jgab Hi, Jan
    more problems
    Line 338:    end
    Line 339:  end
    It changed from _myNodeRed to _defaultNodeRed
    The reason is that nodered() can take an extra argument to talk to another nodered node.
    (But I will fix a better error message)
    Yes I noticed and changed _defaultNodeRed to _myNodeRed. Can't do?
    local _sceneName   = "NR3"      -- Set to scene/script name
    local _homeTable   = "HomeTable" -- Name of your HomeTable variable (fibaro global)
    local _HueHubs     = {}          -- Hue bridges, Ex. {{name='Hue',user=_HueUserName,ip=_HueIP}}
    local _myNodeRed   = "http://192.168.1.158:1880/eventrunner" --
    31 minutes ago, Sjakie said:
    Hello Jan,
    This should work. No use to poll every hour as the iosLocator will send as soon as it gets a new position for a user.
    No the other way around. _myNodeRed should change to _defaultNodeRed
    If you have old code using _myNodeRed define both to the same value.
    Hello Jan,
    its not ER?
    /monthly_2019_07/image.png.c990f55d522ecd097446ec8811a70ac6.png" />
    Nodered adapted as you described, rule added on ESceneID
    In nodered payload with message
    Please advice,
    7 hours ago, jgab said:
    You run the latest version of HC2.lua? "0.11","fix6"
    If you run the latest, post me you pub/sub scenes so I can try them out.
    Looking good now @jgab
    Will continue the migrate now, i might find something more to ask about later ?
    sorry solved same as FrankT
    ok first "for" rule gives error. I now the logic have been changed but i need a push into right direction.
    for -> trueFor
    Hello Jan,
    Please can you explain??
    This rule gave error index field
    I was checking the rule the debug window refreshed(full) and error gone, without edit anything.
    Is it your magic hand?
    /monthly_2019_07/image.png.acd2cfab94557c6e0f0c14d2d54de677.png" />
