    7 minutes ago, Sjakie said:
    Rule.eval("log('%s',tostring(woonkamer.raam:armed))")
    Ok, it seems like it is the "hoofdslaapkamer.bbeveiliging:isOn" or "woonkamer.raam:breached" that is the issue. (:breached is a synonym for :isOn)
    and the problem seems to be that either hoofdslaapkamer.bbeveiliging or woonkamer.raam:breached is nil.
    Sorry the test should be Rule.eval("log('%s',woonkamer.raam:armed | 'no value')")
    To see their values try:
    Rule.eval("log('%s',woonkamer.raam | 'no value')")
    Rule.eval("log('%s',hoofdslaapkamer.bbeveiliging | 'no value')")
    However, it can be that for some reason the variables are reset later in the script. You could add log statements to your existing rule to get the values when the rule executes
    hoofdslaapkamer.bbeveiliging   >>>> set house armed/disarmed
    Sorry, log commands ended wrong - should have ; and not ")
    Jan I am verry sorry,
     I checked the woonkamer.raam it is gone!!!! Only the temp device is present.
    That has something to do with device not configured???
    Wierd I did do nothing the only job to do was test arm switch of when I awake in the morning>> was going wrong.
    I implemented your proposal cancel Alarmref on a wrong way.
    Let me add the window again.
    Same sort of thing happens also with the front door.
    Is it the actual device that is gone? If it's just the hometable value then it can happen if you accidentally write "woonkamer.raam=..." (an assignment) when you should have written a test "woonkamer.raam==...".  The former overwrites the woonkamer.raam value.
    The window is closed
    My motion sensors are dead I have no clue what is going on now
    House is not in arm scene
    The device is gone! Only temp is still present>>> removed device and added
    Let me restart HC2
    HC2 is restrated
    It does not make any difference if window is open or closed>>>same error in debug
    5 minutes ago, Sjakie said:
    HC2 is restrated
    There was an error in the log statement that I corrected in
    okay corrected.
    No error in debug so far so good but its now going strait in alarm.
    There are people in the house so if I start arm now it arms at once instead of waiting 40m sec, now I am confused.
    Is just by adding your rule if I take it out it is as usual 40 sec delay.
    sorry screen shot should not be there
    1 minute ago, Sjakie said:
    okay corrected.
    Sorry, my stupidity. Didn't realise that we were writing the log commands in the left-hand side of the rule. It should be like this (change ; to &)
    np Jan it proves you are still human!!!
    As you can see it get the signal to arm10:50:40
    the log comes on wrong time (the device is still safe)
    10:51:21 starts to arm log should come?
    Let me send my scene in pm so you will see how it is build
    Thanks for your support
    It is probably correct. The post(#bewakenHuis,+/00:00:40) will post after 40s, but the next command will execute immediately. Therefore you see the log "start bewaken huis"  directly. However the event is posted at 10:51:21 the [{"type":"bewakenHuis"}]>>...
    A more correct log message would be:
    Hi Jan,
    With this rule it willl waith to arm the 40 sec
    rule("hoofdslaapkamer.bbeveiliging:isOn => cancel(alarmRef); alarmRef=post(#bewakenHuis,+/00:00:40); log('start bewaken huis in 40s')")
    Followed by devices separate and in case a door is open it will give no alarm
     Rule.eval("#bewakenHuis & woonkamer.raam:safe => woonkamer.raam:armed=1")XXXXXXX
    If I use your advice it will arm directly and it will go into alarmstate if a door is open.
    XXXXX here I want a log logging if the device state is armed or not. Is this possible?
    Please advice with an example.
    Hello Jan,
    Sorry to bother but I cant solve this error:
    What did I do, I moved 2 Hue spots and renamed them according the section where they are placed.
    The HUE app is modified.
    I modified HT and two scenes where they are used. Those 3 scenes I checked also in notepad with search and find.
    What I do overlook?
    Please advice
    Hello Jan,
    What I do overlook?
    Please advice
    ER can't find the name 'spotres2' in your Hue hub.
    Do you have more than one Hue hub?
    Try to do Hue.dump(), it will list all the names it can find in the Hue hub.
    Jan a restart of HC2 solved the error. Something hangs it happens more.
    The HUE dump was already on
    Thanks for the advice
    @jgab may be it's the heat giving me headache but my scene for blinds does not receive answer from NodeRed anymore. Now I have tested this
      rule("remote(_myNodeRed,#echo{data='test'})")
      rule("#response{data='$d'} => log('Got back:%s',d.data)")
      rule([[remote(_myNodeRed,#wetter{})]])
      rule([[#wetter => moln=env.event.data.clouds;  log('moln= %s',moln)]])
    Works ok in ZBS but when running on HC2 there is nothing:
    [DEBUG] 16:26:20: NodeRed - EventRunner v2.0 B65
    [DEBUG] 16:26:20: Fibaro software version: 4.550
    [DEBUG] 16:26:20: HC2 uptime: 52 hours
    [DEBUG] 16:26:20: Sunrise 04:54, Sunset 21:36
    [DEBUG] 16:26:20: Hue system inited (experimental)
    [DEBUG] 16:26:20:
    [DEBUG] 16:26:20: Loading rules
    [DEBUG] 16:26:20: Rule:1:#response{data='$d'} => log('Got back:%s',d.data)
    [DEBUG] 16:26:20: Rule:2:#wetter => moln=env.event.data.clouds; log('moln= %s',moln)
    [DEBUG] 16:26:20:
    [DEBUG] 16:26:20: Scene running
    Node Red debug shows:
    2019-07-25 16:26:21node: Outgoing payloadecho : msg.payload : Object
    object
    args: array[2]
    0: "%7B%22type%22:%22response%22,%22data%22:%7B%22data%22:%22test%22,%22type%22:%22echo%22,%22_from%22:397%7D%7D"
    1: "%%ER%%"
    2019-07-25 16:26:22node: Outgoing eventecho : msg.payload : Object
    object
    type: "response"
    data: object
    data: "test"
    type: "echo"
    _from: 397
    2019-07-25 16:26:23node: Incoming event1echo : msg.payload : Object
    { data: "test", type: "echo", _from: 397 }
    2019-07-25 16:26:24node: Incoming event1wetter : msg.payload : Object
    { type: "wetter", _from: 397 }
    Could it be Fibaros new software 4.550?
    Did also have strange error on one of my ER scene. 4 rules that did work before update to 4.550. An restart of HC2 did not solve it, after that i did stop and start scene and all rules did work again without any errors.
    @jompa68  I did restart the HC2 twice and the scene is a test scene only to check if NR sends back something. I deleted this testscene and copied it again from ZBS. Same result. Now 29 degrees C in Falkenberg, 21:13!
