Hello Jan,
I am still smoothed out my alarm scene.>>hehe
Surprised as I was after testing 20 times with some doors open the system suddenly  used the open door to switch in alarm state.
I modified all my rules in:
To check:
          Rule.eval("hal.check:isOn & hal.tussendeur:breached => log('let op tussen deur hal open'); $Telegram='Let op er staat een tussendeur in de hal open'")
To arm:
         Rule.eval("hoofdslaapkamer.bbeveiliging:isOn & hal.locatiegezin:isOn & hal.tussendeur:safe => hal.tussendeur:armed=1")
So alarm will be triggered:
        Rule.eval("hoofdslaapkamer.bbeveiliging:isOn & hal.tussendeur:breached & hal.tussendeur:armed=='1' => post(#AlarmState); remote(1627,#AlarmState);log('hal tussen deur breached'); $Telegram='Alarm, hal.tussendeur breached'")
I do not see anything I missed?
For the binairy sensor I am confused both are working but whats the
good one?
Rule.eval(" alarmapp.elroalarm:armed=='0'  => post(#AlarmState); log('Elro breached'); $Telegram='Alarm, ELRO breached'")
          Rule.eval(" alarmapp.elroalarm:value=='0'
what is the correct rule for my example below? If i want to check lux value is higher than 250
and is this publish rule correct?
Edited by jompa68
Think i got it to work
I wanted to have same solution for my Google Home like i have for my Alexa, to integrate it with node-red and ER.
Found
, it is a free module for node-red (donation possible)
So i did give it a try and it was easy to setup. You find instructions on the link above.
/monthly_2019_07/990914244_Skrmavbild2019-07-16kl_21_18_36.png.339fabd9543a667e2ea9cfbe4917e3d9.png" />
Node-Red flow
ER rules
device in Google Home App
Edited by jompa68
    Yes, this is a straightforward solution. The advantage is that the value 250 can be fetched from a variable.
    However, another solution is to leverage the event matchning support that is builtin, and that allow us to only match values that fullfil certain conditions.
    Ex.
    This will bind the local script variable 'lux' to the lux field, but the match will only succeed if the value is >= 250.
    If we don't need the 'lux' value the last rule can be replaced with
    We can do it even more efficient and only subscribe to events with lux>=250.
    This means that every #VirtualSensor{deviceID=Lux.ute} we receive is guaranteed to have value >= 250 and we get less traffic between the scenes.
    Found
    Nice. It seems to allow for a larger vocabulary than the local Alexa node. I may need to invest in a google home device...
    On 7/11/2019 at 5:57 PM, Sjakie said:
    Hello Jan,
    To check:
    To arm:
    good one?
    The error you get in the log screendump is related to some Hue device that doesn't exists. Does Hue device with id 10 exist?
    Hello Jan,
    Thanks for your answer!
    - Hue 10 is an existing lamp, I am getting much errors with HUE. I also switched off all fancy clors with Hue because of that. I must see if it also goes wrong if I do it with lua or perhaps with nodered.
    - Is this okay for Binary sensor>>> Rule.eval(" alarmapp.elroalarm:value=='0'  ?
    Hi Jan,
    Ical gives the following debug message. VERSION.json ??
    [DEBUG] 15:41:24: iCal - EventRunner v0.9 B12
    [DEBUG] 15:41:24: Fibaro software version: 4.542
    [DEBUG] 15:41:24: HC2 uptime: 672 hours
    [DEBUG] 15:41:24: Sunrise 04:41, Sunset 21:50
    [DEBUG] 15:41:24:
    [DEBUG] 15:41:24: Loading rules
    [DEBUG] 15:41:24: VD iCal ER already exist
    [DEBUG] 15:41:24:
    [DEBUG] 15:41:24: Scene running
    [DEBUG] 15:41:26: Slow mailbox watch:1.997071s
    [DEBUG] 15:41:26: New ICal version, v:0.9, fix:B11
    [DEBUG] 15:41:26: Patching scene to latest version
    Hello Jan,
    If I arm my house it arm the doors and windows but not the motion sensors??
     Rule.eval("hoofdslaapkamer.bbeveiliging:isOn & hal.locatiegezin:isOn & serre.deur => serre.deur:armed=1")
     Rule.eval("hoofdslaapkamer.bbeveiliging:isOn & hal.locatiegezin:isOn => eetkamer.bewegingssensor:armed=1")
     Rule.eval("hoofdslaapkamer.bbeveiliging:isOn & hal.locatiegezin:isOn => woonkamer.bewegingssensor:armed=1")
    Device 145 and 166 are motion sensors
    /monthly_2019_07/image.png.625a19e3109715c87030e732d313a47f.png" />
    What is my mistake?
    1 hour ago, FrankT said:
    Hi Jan,
    [DEBUG] 15:41:24:
    [DEBUG] 15:41:24:
    sorry, forgot to update version info. B12 is latest.
    12 minutes ago, Sjakie said:
    Hello Jan,
    What is my mistake?
    When the rule runs it should log the fibaro:call(deviceID,"setArmed",1) - does it do that? (also _debugFlags.fcall should be set to true)
    Sorry Jan,
    That I forgot, yes it is listed. Fibaro alarm panel is disabled.
    I was away from home and saw it on the app 1.4
    Fibaro  shows Doors as armed!
                               motion sensors not armed!
    Now I am unable to find it?
    /monthly_2019_07/image.png.953039960969a881ad79fbfb80cceed5.png" />
    Hi Jan,
    need som help to understand what's happening. I have a scene now running for 2 weeks without any problems but  today I got this:
    /monthly_2019_07/error.jpg.d8fce315c432a142bb39ca5b7609e83e.jpg" />
    {"bedlamp_frank":122,"bedlamp_margaretha":173,"balkondorr":370,"temp_balkondorr":371,"nodon_wallswitch":424} is not used at all in this scene.
      rule("@@00:10 => a=tonumber($yttertemperatur); b= tonumber($windhastighet); c= $windriktning; d=tonumber($regn); remote(_myNodeRed,#egetwetter{yttertemp=a, vindstyrka=b, vindriktning=c, regn=d})")
     rule("@@00:01 => remote(_myNodeRed,#wetter{})")
     --Får från NodeRed tillbaka 'cloud'= molntäckning.
      rule([[#wetter =>
          d=tjson(env.event); h=string.find(d,"data")+6; g=string.find(d,"}"); moln=string.sub(d,h,g-1); tid=ostime();
          lb = tonumber(luxb:value); lf = tonumber(luxf:value); log('luxbak luxfram = %s %s', lb,lf); m1=tonumber(screen:value);
          m2=tonumber(sovm:value); m3=tonumber(tvm:value); m4=tonumber(extram:value); m5=tonumber(altanm:value); log('m1..m5 %s %s %s %s %s',m1,m2,m3,m4,m5);
          post(#tvrum); post(#extrarum);
          || (08:00..15:00) >> post(#screen); post(sovrum)
          || (sunset-10..sunset+50) >> post(#nattscreen)
      rule([[#nattscreen =>
           || (lb < 2000) & (m1 == 99) >> screen:value = ner; log('4 SCREEN NED KVÄLL %s %s',y,m1)
           || m1 >> log('inget nattscreen lb m1 %s %s',lb,m1)
      rule([[#screen =>
          || (lb > lf) & (lb > 8000) & (moln <= 60) & (08:00..15:00) & (m1 > 25) & (a > 0) & (screen:last > 00:15) >> screen:value = ner; _lux=lb; log('m1 screen NED 1 %s %',moln, screen:last)
          || (lb > lf) &(lb > 8000) & (lb < 12000) & (moln > 60) & (08:00..15:00) & (m1 == 0) >> screen:value = upp;log('m1 screen UPP 2 moln mer 60 %s %s %s %s',moln,a,lb, screen:last)
          || (lf > lb) & (lb < 14000) & (08:00..15:00) & (m1 == 0) >> screen:value = upp; log('m1  SCREEN UPP 3 moln %s %s %s %s %s',m1, moln, lb, lf, screen:last)
          || m1 >> log('inget screen lb moln m1 %s %s %s', lb, moln, m1)
    Hi Jan,
      rule([[#wetter =>
      rule([[#screen =>
    Could it be '#sovrum' instead of 'sovrum' in this line?
    'sovrum' seems like a hometable value.
    Btw. I see what you do here
    but can't you do something like below?
    I don't know how the data structure look like but you should be able to make an access path to the cloud field.
    Thank you Jan. Sometimes one gets blind, I changed a little in the code yesterday and forgot what I had changed!
    But sorry d=env.event.data.cloud does not work: ': attempting to index non table with key:'cloud'. Node Red sends back the following:
    "%7B%22type%22:%22wetter%22,%22data%22:100%7D"
    1: "%%ER%%"
    1: "%%ER%%"
    So the event you get back from NR is
    then this should work.
    Jan good morning,
    What I do overlook?
    Rule is the same as others
                Rule.eval("hoofdslaapkamer.bbeveiliging:isOn & woonkamer.raam:breached & woonkamer.raam:armed=='1' => post(#AlarmState); remote(1627,#AlarmState); log('Alarm, woonkamer raam geopend');  $Telegram='Alarm, woonkamer raam geopend'")
    in HT woonkamer.raam
    6 minutes ago, Sjakie said:
    Jan good morning,
    What I do overlook?
    It looks like  woonkamer.raam:armed returns nil.
    Can you just do Rule.eval("log('%s',tostring(woonkamer.raam:armed))") and see what you get?
    I'm trying to improve the error handling (next version). Now when I see that the error is on line 1728 and 1453 in your log I can't match that against the line in the code because you have added lines in the beginning (your rules).
    If you can, it would be nice to get code in lines 1453 and 1728 so I can verify that it is indeed the "==" in "woonkamer.raam:armed=='1' " that is the problem.
    /monthly_2019_07/image.png.ede626ee3f0c2a012b053e0d386352ba.png" />
