@jgab have something changed in iOSLocator.lua? This 2 lines does not work any more.
    Nop, nothing changed in that logic.
    Do you see that IOSLocator sends the event to your scene (in IOSLocator's log) ?
    Ah, sorry. Did play around with 2 different versions of rule, so typo error. All ok now.
    /monthly_2019_06/1260602554_Skrmavbild2019-06-23kl_20_20_05.png.26f75d6533b1e1b3f929fca27089ae91.png" alt="1260602554_Skrmavbild2019-06-23kl_20_20_05.png.26f75d6533b1e1b3f929fca27089ae91.png" />
    7 hours ago, Sjakie said:
    I feel myself at the center of the Forrest without any navigation.
    What did I do (wrong)?
    First, you have a telegram bot if i understand it right. Have you fill in your telegram token and chatID in Node-Red?
    I have created a group for my bot so i use this group chatID in NR
    Hello Jompa,
    Yes I have a TelegramBot.
    The connection error is solved ( I copied your Nodes in my file)
    I see also on scene 1608: Got back Test (in Yellow color) >>>>>how to use this in a rule?
    In NodeRed I dont see any errors in Debug
    So a part is working, thanks for that.
    How to get that message also on >>>>>>>my phone via Telebot??
    Please advice
    Create a telegram group and invite your account and your bot. Change chat I'd so it match group instead
    Hello Jompa,
    I created a group in TelegramBot and modified ID in GroupsID.
    From ER scene TelegramBot message 23.00>>>> to mobile  did not see it in debug Node Red
    @Sjakie send me you NR flow (export) so i can take a look. Send it in private, perhaps in a txt file.
    Why does this rule not work?
    When all iOS devices is away from home, this should run.
    Do you get the event to your scene? (_debugFlags.triggers=true)
    Does the IOSLocator send the event? (_debugFlags.fother=true and scene logs fibaro:startScene(...) )
    Do you subscribe to the event or have you configured what scene to send to in IOSLcator/HT ?
    Above is from iOSLocator
    and below is from my alarm scene
    i am already away from home so when she did leave it should trigger "allaway" (what i think)
    Edited by jompa68
    First it seems like you get 2 events when Mona is away. Do you still have the
    as part of the HT/configuration? Then you will get an event from that + from the subscription .
    Have the IOSLocator detected that you are away? Or do you still have that Mona email adress as a user also?
    When it starts up it logs "User:..", can you check that you only have 2 users, you and Mona?
    From the "client" scene you can do
    and it will re-send all user+locations it knows about. It can be a way to debug it. (one #location event per user it knows about)
    Make it an "Telegram" rule so you can ask who it knows about when you don't get the status you expect.
    I will update IOSLOcator with some better debug statements but while you wait for that you can add a debug statement in IOSLocator. Around line 260 there is the code
    add the last
    that gives some info if it doesn't think that anyone is home or all are away... #locations are how many locations it has detected so far.. #iUsers are the number of registered users. homeFlag is the previous status (true someone is at home), and home is the new detected status.
    Implemented
    New error that i have not seen before, perhaps after update?
    /monthly_2019_06/image.png.9677490d3e2a1ff19db36c542720377a.png" alt="image.png.9677490d3e2a1ff19db36c542720377a.png" />
    24 minutes ago, jompa68 said:
    Implemented
    Ok, it was a bug in IOSLocator. I fixed it and hopefully allaway will work now. pushed new version. B7.
    The other error was because a line had disappeared from last eventrunner, have no idea how that happened. I pushed new version B59.
    You are the best! :D
    @jgab if my alarm scene restarts for some reason, when it starts again it never trigger/checks state of presence again. Want scene to arm alarm again if it have been temporary disarmed. (by dog or cat movement)
    Ok, I think I fixed it - but I have no chance to test it at the moment. B8)
    If you subscribe to #presence
    you should at startup get the latest #presence event from IOSLocator (if IOSLocator hasn't yet polled all users to decide if they are home or away the event will come later).
    This is what i have now but i never see state='allaway' in debug
    Fixed in B9. Still works?
    Yes, all ok now
