@jgab Pi with NodeRed has 192.168.1.158:1880. ZBS and HC2 settings as below. Nothing special here.
/monthly_2019_06/592147369_ZBSHC2settings.jpg.51185567eba43e0d5579308951c8d1b9.jpg" alt="592147369_ZBSHC2settings.jpg.51185567eba43e0d5579308951c8d1b9.jpg" />
Good morning Jan,
Something is wrong curtains does not open anymore,
      Rule.eval("oprit.luxsensor:lux > 105 => post(#morningMsg)")
      Rule.eval("@sunrise => post(#morningMsg)")
     Rule.eval("#morningMsg & once(05:00..09:15) =>  remote(_myNodeRed,#speak{data='de gordijnen worden geopend'}); wait(00:00:15); woonkamer.gordijnvoor:open; wait(00:00:08);woonkamer.gordijnzijkant:open; wait(00:00:05);   woonkamer.gordijnoprit:open; wait(00:00:06);  eetkamer.gordijnachter:open; wait(00:00:05);  eetkamer.gordijnzijkant:value=100")
  In Debug it was posting morningMsg   >>> but I lost the copy
Please advice
mmmh
Other scene does not show it is stopped but all out side light is still on! Time now 07.17
HC2 uptime 106 hours
HC2 restartedto see tomorrow if this helps
/monthly_2019_06/image.png.9ca8d913150a419c155cf80a26ec717a.png" alt="image.png.9ca8d913150a419c155cf80a26ec717a.png" />
07.22 restarted and supervisor reports all scenes are alive
    30 minutes ago, Sjakie said:
    Good morning Jan,
    Please advice
    I assume the rule has worked and just stopped working?
    I have tried it myself and it is working well for me. (It's not that sunrise if before 05:00? Here in Sweden it is now sunrise at 03:30  )
    If you are sure it posts the message (within the time limits) it should trigger the third rule.
    The other scene that didn't turn off the outside lights, do you see logs of fibaro:call(X,"turnOff") ?
    I don't recognise the dialogue for ZBS (Return immediately - don't wait for reply) - What version of node-red are you running?
    For HC2 I guess you have "Use authentication" checked and provided?
    Yes on both scenes.
    It was posting morningMsg further no action
    The same with the lights it posted sunrise and no action .
    The dialog for ZBS is set to 'Never-keep connection open' and for HC2 it is set to 'Basic authentication' with my login and password for the HC2. The screen dump was only to show the IP-settings. Node.js is 10.16.0 and Node-Red version is 0.20.5
    Ok found that I have to set HC2 return to 'a binary buffer' to get something returned to my HC2. But still no response back to ZBS.
    Good morning Jan,
    This morning curtains where open as normal!So I am confused why the last two days it did not work.
    /monthly_2019_06/image.png.6d8641a4bd53f69e4def4ddc7ce786f9.png" alt="image.png.6d8641a4bd53f69e4def4ddc7ce786f9.png" />
    That should not be needed - UTF-8 string works for me.
    I upgraded to Node.js 10.16.0 and Node-Red  0.20.5 as you but it still work as before for me.
    It seems like you receive the events from ER ok, and that node-red is trying to send back responses ("Outgoing payload" debug msg)
    My ZBS node (http request node) look like this (IP of my laptop is 192.168.1.18)
    I imported your flow from your post on January 18 and it shows a tcp request node as output to ZBS?
    AH, it
     Ah, it may be an old flow.
    Try the one in
    In "Reveal hidden content" under the flow picture.
    Try the one in
    Thank you Jan. Great, working again. I think I must have used this flow before the crash and when that happened I used your february flow and just added my mod for Openweathermap. Thanks once again and have a nice day in Stockholm.
    On 6/13/2019 at 7:10 AM, jgab said:
    Ok, fixed the bug with ICal and multiple alarms. Pushed a new version B11, but you can patch your current version if that's quicker
    Line 315:
    Change
    to
    @jgab your changes did not work, at least not for my wife :D
    This was difficult. I pushed a new version B12 that fixed it. Fingers crossed.
    Hello Jan,
    What I am doing wrong?
     Rule.eval("alarmapp.alarmrelais:isOff => post(#AlarmStateUit); postRemote(1626,#AlarmStateUit); 1631:start;  signalisation:off; $Telegram='AlarmToeters worden uitgeschakeld'")--????
        --just for testing Rule.eval("@08:20 =>  $Telegram='Alarm Toeters worden uitgeschakeld'")
    1626 is the scene to receive
    gives error:
    /monthly_2019_06/image.png.02f52f85b10c459a3e613811ca7fd55c.png" alt="image.png.02f52f85b10c459a3e613811ca7fd55c.png" />
    Please advice
    22 minutes ago, Sjakie said:
    Hello Jan,
    gives error:
    Please advice
    Sorry, I gave you the wrong advice previously. The command is 'remote', not 'postRemote'.
    Hello Jan,
    hehehe I am glad! I started to doubt on myself.
    This is more fun>>> the command comes in at the other scene. Temporary I have used a relais to for fill the task but now it is as it should be. Thanks.
    In my alarm scene disable the alarm lights goes out and I want to switch on some other lights  (it should not become dark in the house by alarm). So I made  a rule to switch on between sunset and sunrise.
    This rule I want to use to switch off, if alarmStateUit is present for 30 minutes switch off lights. Remark those lights are also used in other scenes but not together with AlarmStateUit
    is this correct?
    Please advice
            Rule.eval("once(for(00:30, #AlarmStateUit)) => {woonkamer.spotbeeldrechts, woonkamer.spotschilderijrechts, woonkamer.spotstoelsjaak}:off")
    32 minutes ago, Sjakie said:
    Hello Jan,
    is this correct?
    Please advice
    No, you can't use an #event to test for that. An event happens once and have no extension in time. You need something that is stateful (like a device or a GV) to test against.
    There is a type of ER variable that start with '_' that can be used to keep a state and use as rule trigger. However, you need some  event that signals that #AlarmStateUit is not valid anymore.
    Ex. (I'm not sure if this is the best in your case)
