Hello Jan,
When I load one of my scenes in ZB it will give the next error:
[31mWed/Jun/12,22:37:52:[20:1] Error loading rules:Error evaluating 'hal.tussendeur:breached & eetkamer.luxsensor:lux < 12 & once(05:00..08:30) => keuken.ledkastjes:on ; wait(00:00:45); remote(_myNodeRed,#speak{data='goede morgen'}) ' attempting to index non table with key:'tussendeur'[0m
[32mWed/Jun/12,22:37:52:[HC2 ] Scene [20:1] terminated (thread: 0x03385748)[0m
hal.tussendeur is listed in HomeTable
I have more of this kind of errors
Please advice
HomeTable not active in ZB?
/uploads/monthly_2019_06/image.png.ddc32721a62e7ad8137bddb9455b31ba.png" alt="image.png.ddc32721a62e7ad8137bddb9455b31ba.png" />
look for this line in HC2.lua and remove -- in line 2. Then all data from HC2 will be stored in HC2.data file. Then it should not be a problem
    Another way is to open the Web GUI (http://127.0.0.1:6872/emu/main) and click the button "Copy setup from HC2". If you uncomment that line it will read the config from the HC2 at every run which adds a delay at startup that can be annoying. Btw, have you tried to install the ZBS plugin (
    )? It gives a keyboard shortcut and menu to open the web GUI when the emulator runs.
    Ah, nice feature :D
    22 hours ago, jompa68 said:
    Yes, 515 is my ical.lua. All settings are standard, nothing changed.
    No extra events logged in scene.
    Ok, fixed the bug with ICal and multiple alarms. Pushed a new version B11, but you can patch your current version if that's quicker
    Line 315:
    Change
    to
    Line 315:
    Change
    to
    Great, i was spammed yesterday also with notification about remembering the garbage. 60 times ;D
    Hello Jan,
    removed the line
    As I click on copy setup from HC2 it will give error
    url load localy
    I checked my log in credentials
    __HC2_USER           = "[email protected]" -- used for api.x/fibaro:* calls to HC2
    _HC2_PWD            = "xxxxxxxxxx"
    _HC2_IP             = "192.168.1.153"
    Now I am lost
    Please advice
    [35mThu/Jun/13,08:07:23:[HC2 ] Configuration from file, Globals:0, Scenes:0, Device:0, Rooms:0[0m
    [32mThu/Jun/13,08:07:23:[HC2 ] System trigger:{"type":"autostart"} at Thu Jun 13 08:07:23[0m
    [35mThu/Jun/13,08:07:23:[HC2 ] Reading configuration from H2C...[0m
    [31mThu/Jun/13,08:07:23:[HC2 ] HC2 returned error '401 ' - URL: 'http://192.168.1.153/api/globalVariables/'.[0m
    Program completed in 24.60 seconds (pid: 2992).
    Debugging session completed (traced 0 instructions).
    1 hour ago, Sjakie said:
    Hello Jan,
    removed the line
    url load localy
    Now I am lost
    Please advice
    401 means that the authorization failed. That must mean that username or password is wrong. Should be the same credentials as when you log in to the HC2.
    Do you have an "HC2credentials.lua" file with old credentials? HC2.lua reads "HC2credentials.lua" at startup and will overwrite variables set in the file header.
    Wait a minute. Your _HC2_USER has 2 dashes infront of the variable name. Thats the problem!
    /J
    Hello Jan,
    hehe this is solved but regret to say
    Test.lua:9: attempt to index global 'fibaro' (a nil value)
    I downloaded from Github a fresh test.lua and it hangs on:
    if fibaro:countScenes() > 1 then fibaro:abort() end
    Please advice
    3 hours ago, Sjakie said:
    Hello Jan,
    Please advice
    Sorry, the test scenes have not been updated since the last rewrite of HC2.lua so they were not compatible anymore.
    I have updated them now also it should work.
    All scenes that you run in the emulator need the line
    in the beginning. The line is ignored when moving the scene back to the HC2 as 'dofile' returns nil on the HC2.
    Hello Jan,
    Hehe I started to doubt on myself!
    But I copied and pasted one scene (Beveiligen) complete in ZB. File is listed in the row of test, HC2data, HC2.lua
    Program starting as '"C:\ZeroBraneStudioEduPack-1.80-win32\bin\lua.exe" -e "io.stdout:setvbuf('no')" "C:\Users\sjaak\AppData\Local\Temp\.BDF2.tmp"'.
    Program 'lua.exe' started in 'C:\ZeroBraneStudioEduPack-1.80-win32\myprograms' (pid: 4564).
    Debugging session started in 'C:\ZeroBraneStudioEduPack-1.80-win32\myprograms\'.
    [33mThu/Jun/13,13:51:14:[HC2 ] HC2 HC2 emulator v0.10 fix5[0m
    [33mThu/Jun/13,13:51:14:[HC2 ] Local mode, will not access resources on HC2[0m
    [32mThu/Jun/13,13:51:14:[HC2 ] Created Event server at 192.168.1.184:6872[0m
    [32mThu/Jun/13,13:51:14:[HC2 ] Web GUI at http://192.168.1.184:6872/emu/main[0m
    [35mThu/Jun/13,13:51:14:[HC2 ] Reading and decoding configuration from HC2.data[0m
    [35mThu/Jun/13,13:51:14:[HC2 ] Configuration from file, Globals:125, Scenes:82, Device:226, Rooms:21[0m
    Program completed in 2.26 seconds (pid: 4564).
    HC2.lua:1271: File load error: cannot obtain information from file `Beveiligen.lua' in C:\ZeroBraneStudioEduPack-1.80-win32\myprograms
    stack traceback:
        [C]: in function 'error'
        HC2.lua:1271: in function 'loadEmbedded'
        HC2.lua:79: in function 'main'
        HC2.lua:210: in function 'startup'
        HC2.lua:3456: in main chunk
        [C]: in function 'dofile'
        ER 57 Beveiligen.lua:52: in main chunk
    14 minutes ago, Sjakie said:
    Hello Jan,
    stack traceback:
    It's important that you have HC2.lua and your scene file (Beveiligen.lua in this case) in the same working directory. Also in ZBS set project directory to the same directory (Project -> Project Directory -> Set From Current File)
    Hello Jan,
    Both done >>same error
    /monthly_2019_06/image.png.8e64202dca901c07a1f3f29491c62a84.png" alt="image.png.8e64202dca901c07a1f3f29491c62a84.png" />
    2 hours ago, Sjakie said:
    Hello Jan,
    What button in ZBS do you press to start the scene? You need to press the single green arrow or F5. (circled in red). It starts running in debug mode.
    The other start in scratch-pad or without debug and then it doesn't work.
    I may try to fix it in the future but it's a bit complicated...
    /monthly_2019_06/debug.png.0a4bb2930ecfbe368a679226d6aab3c1.png" style="width:300px;height:auto;" alt="debug.png.0a4bb2930ecfbe368a679226d6aab3c1.png" />
    Hello Jan,
    Yep that button I use. I just wanted to get more familiar with ZB. It is not a big deal my tests I will do life.
    I will concentrate on my scenes to smooth them up, thanks for your time and effort!
    My scenes are still running without restarting manually
    Question:
    I have one scene with all my Hue light, all are in the living room. I extend Hue also in the garden (is a separate scene)
    In my Hue scene you advised to write Hue.define So will I use Hue in garden I need to do the same Hue.define (the garden lamps??)
    Hue.define("ambitvlight", nil, 12278)
    Hue.define("lampplafondklokzijde", nil, 12281)
    Hue.define("spotkastlinks", nil, 12312)
    Hue.define("spotschilderijrechts", nil, 12320)
    Can this be moved into HomeTable?>>> I tried but it goes wrong with the nil
    I already have in HomeTable:
    woonkamer{ambitvlight=12278,lampplafondklokzijde=12281,spotkastlinks=12312,spotschilderijrechts=12320,spotschilderijlinks=12321,spotstoelarleta=12322,spotbeeldlinks=12323,spotbeeldrechts=12324,lampplafondtvzijde=12325,spotstoelsjaak=12326,
    Please advice
    Hello Jan,
    Apologize for all my questions but I need your expertise!
    I think I am almost ready with guarding the complex. Found some where here in the discussions use rules from one scene in another. I want to use it but need your advice/comment.
    The proposal for the change of color of my flag hue light I modified a bit and can use it also as red alert light in case alarm status is on!
    Guard the hose scene        woonkamer scene (Hue)
    here I have used on your advice:        Can I use here
    Rule.eval("hal.voordeur:breached & hal.voordeur:armed=='1' =>
    post(#AlarmState); $Telegram='Alarm, hal.voordeur breached'")                                           ule.eval("#AlarmState =>  alarmlights:on; colorIndex2=1; enable(colorShow2)") -- Start show
        Question,  nothing further mentioned or under %%event
        AlarmState  in header?
    Must think will become button on VD or something
    Rule.eval("429:btn=1 => signalisation:off; post(#AlarmStateOff);                                          Rule.eval("#AlarmStateOff =>  disable(colorShow2); alarmlights:off")
    $Telegram='Alarm signals switched off '")
    Please advice
    15 hours ago, Sjakie said:
    Hello Jan,
    Please advice
    The way to trigger rules in other scenes is to post an event to them.
    postRemote is like post but sends the event to another scene. Nothing need to be mentioned under %% event header in the  woonkamer scene.
    Unfortunately we can't trigger on a VD button being pressed as it doesn't generate any scene triggers (setting labels and sliders do)
    What you can do is put Lua code in the VD button to send the event to the scen,
    Hallo @jgab need again your advise .  I have a Raspberry Pi running Domoticz (for Oregon weather station RFX433 ), NodeRed, InfluxDB and Grafana. And not on a SD card but an USB-stick. Worked ok for one year but crashed(?) last week. Now I have a Pi with Domoticz and NodeRed, no Grafana,  no InfuxDB. Upgrade also my ER programs to B57. But something must have gone wrong and now I get no response to my ER from NodeRed any longer, not in ZBS and not to the HC2.
    Ok,
    Your Pi box (node-red) has IP and port 192.168.1.158:1880 ? (what you have declared ib the ER scene)
    Have you configured the ZBS and the HC2 node urn the upper part of the node-red flow (they are in the upper part in my flow , you may have moved them)
    The ZBS should be configured to the OC running the emulator (http://192.168.1.127)
    and HC2 should be configured to point at your HC2 box.
