    12 hours ago, Sjakie said:
    hello,
    just an idea to do: I have a flag outside with a light spot on. Idea change the light bulb into hue color.
    If switched on changing every 5 minutes the color
    How to do?
    With my knowledge I will fill an a3 paper with rules guess it should be able to short it
    I used the wait but that is not give the good result
    Rule.eval("@20:27  =>  woonkamer.lampplafondklokzijde:on ; wait(00:00:15) ; woonkamer.lampplafondklokzijde:value={bri=125, hue=50, sat=0, transitiontime=2, col=75} ,wait(00:00:15) ; woonkamer.lampplafondklokzijde:value={bri=125, hue=50, sat=62, transitiontime=2, col=150} ; wait(00:00:15) ; woonkamer.lampplafondklokzijde:value={bri=125, hue=50, sat=124, transitiontime=2, col=75}; wait(00:00:15) ; woonkamer.lampplafondklokzijde:value={bri=125, hue=50, sat=186, transitiontime=2, col=75} ; wait(00:00:15) ; woonkamer.lampplafondklokzijde:value={bri=125, hue=50, sat=255, transitiontime=2, col=75}")
    Or do I overload HC2, supervisor or all?
    Please advice
    OK, this is how I would do it. You can have any number of color parameters in the table and it will cycle through them.
    Hello Jan,
    Any idea to lower the load on HC2?
    /monthly_2019_05/image.png.380559c896fab81962dd98f7dada6947.png" alt="image.png.380559c896fab81962dd98f7dada6947.png" />
    1 minute ago, Sjakie said:
    Hello Jan,
    Any particular scene that makes the load rise? I could take a look at that scene and see if there is something strange.
    It depends on the scene and even with ER it's possible to overload the system.
    Hello Jan,
    I am just finished to clean the HC2. I was concentrating on the scenes but I found in devices also some heavy crap.
    I am watching the graphic for over 16 minutes and I hope the picture is okay now?
    The scene living room has a hugh load because of 3 power triggers>> all disabled
    But why Supervisor is still skipping 1-2 minutes?
    /monthly_2019_05/image.png.642724cda3f912cbd89cbda85f06d9af.png" alt="image.png.642724cda3f912cbd89cbda85f06d9af.png" />
    18 minutes ago, Sjakie said:
    Hello Jan,
    Some VDs can cause load, I'm unsure why, something with the main loop I guess.
    Instead of having power triggers in the scene header you can add this code to the ER main()
    It defines a function 'watchProperty' that polls a list of devices for a specific property value and if the values have changed more than 'threshold' it will post a "fake" event of that type. ER rules can't tell the difference and will trigger on the posts like a regular scene trigger. The advantage is that you can poll at a slower intervall for values that are not important to trigger on the second. In the example, we watch two deviceIDs if the 'power' property changes more than 20, and we do it every 5s. If it's not so important to get the trigger immediately you can increase the interval to 10s. In any case it will load the scene much less than to have scene power triggers in some cases.
    What do you mean by Supervisor "skipping" 1-2 minutes?
    It jumps from 11.01.26 to 11.02.31
    sometimes it is almost 2 minutes freeze?
    /monthly_2019_05/image.png.5efa104302a9bfa2c91962b4d135d965.png" alt="image.png.5efa104302a9bfa2c91962b4d135d965.png" />
    I blanked out those power rules temporary
    and what is POLLINTERVAL ?
      local POLLINTERVAL = "+/00:05"    -- poll every 3 minute
      local PINGTIMEOUT = "+/00:02:00"  -- No answer in 10s, scene will be restarted
      local STARTUPDELAY = "+/00:00:40" -- Time for scene to startup after a restart before pinging starts again
      local MAXRESTARTS = 2             -- Number of failed restarts before disabling the scene
    all scenes are still running since 8.00
    so a bigg step forward
    Is this a normal behaviour?
    The two peaks?
    /monthly_2019_05/image.png.00cc2b065b7e6dcdbc5a94c330e9822a.png" alt="image.png.00cc2b065b7e6dcdbc5a94c330e9822a.png" />
    Supervisor is pinging each scene every 5min with your value for POLLINTERVAL, and depending on how fast they answer back the interval that Supervisor wakes up and ping will vary a bit. Sleep periods of 2min is not exceptional. I would expect that after some time it would be more evenly distributed,
    What you should try to check in the log is if Supervisor pings a particular scene every 5min (+ reponse time from scene) (in this case) or if that is also  drifting and becoming longer intervals.
    The two peaks?
    I have seen those peaks myself.
    Can you see if it is a particular scene or VD that causes the peaks? (try to disable and watch the cpu curve).
    I have the feeling that sometimes it's not the scenes but other "housekeeping" stuff that the HC2 box is doing.
    Temporary peaks are usually not a problem.
    Hello Jan,
    The only VD's I have is the:
    Hue from Sankotronic
    Sonos
    Sonos Krikroff
    Battery check
    Door/window check >>>>will remove
    Calendar Google
    10 scenes GV
    All other scenes on manual
    Let me add first your power proposition
    If okay I will pm you one of the two scenes who are sometimes restarting by supervisor
    Thank you very much!!!!! looks nice I am curious how it shine when its dark.
    9 hours ago, jgab said:
    No, it fetches data every 30min, and when it starts up.
    I have pushed a new version of iCal.lua (B2) with some more debugs.
    At the end of main() there is the lines
    uncomment and add your URLs and run in emulator to see what happens.
    Probably should add a forceUpdate command.
    /monthly_2019_05/1365606488_Skrmavbild2019-05-31kl_19_17_32.png.f5ca1d174e1a21f0a0401e479f0c6d21.png" alt="1365606488_Skrmavbild2019-05-31kl_19_17_32.png.f5ca1d174e1a21f0a0401e479f0c6d21.png" />
    32 minutes ago, jompa68 said:
    Is it an iCloud url?
    Does it have the format " "webcal://p64-calendars.icloud.com/published/2/MTGHKJLJPJPJKL:LKJOHGJKJLFrjxFq9NvCD"
    and you change the webcal: to https: ?
    Like  "https://p64-calendars.icloud.com/published/2/MTGHKJLJPJPJKL:LKJOHGJKJLFrjxFq9NvCD"
    Yes it is an iCloud and it starts with https (long url)
    It fails in the emulator too?
    Not at home right now, cannot test that before monday night.
    Update
    can run "offline" and no errors in emu
    Edited by jompa68
    Update
    Ok, it seems like "checkCertificate = false" in httpRequest disappeared from the iCal I pushed to GitHub. I pushed a new version. Try that.
    /J
    Success
    /monthly_2019_05/588806530_Skrmavbild2019-05-31kl_20_59_23.png.da1f6c9f4224c9de7213f093c34665d3.png" alt="588806530_Skrmavbild2019-05-31kl_20_59_23.png.da1f6c9f4224c9de7213f093c34665d3.png" />
    now i get the info to my ER-Main scene also.
    /monthly_2019_05/1823003801_Skrmavbild2019-05-31kl_21_12_34.png.eb0982cb3a38ebb7adbef54c5c32f441.png" alt="1823003801_Skrmavbild2019-05-31kl_21_12_34.png.eb0982cb3a38ebb7adbef54c5c32f441.png" />
