Jan, thanks,
I will follow your advice and gonna use a relais.
alarmapp.alarmrelais:isOff is normal 24/7 off in alarmstate it wiil be on and after switch off.
I need only to trigger this moment to switch  lights on. Is this rule okay?
Please advice
 Rule.eval("once(for(00:15, alarmapp.alarmrelais:isOff)) => {woonkamer.spotbeeldrechts, woonkamer.spotschilderijrechts, woonkamer.spotstoelsjaak}:off")
    7 hours ago, Sjakie said:
    Jan, thanks,
    Please advice
    In general you don't need to wrap a 'for' in a 'once'. This should be enough
    On 6/18/2019 at 4:37 PM, jgab said:
    This was difficult. I pushed a new version B12 that fixed it. Fingers crossed.
    Seems to work now, only 1 push this afternoon.
    @jgab how should the setup be if i want to change this line
    to something like this(want to change from fix time to when i change variable instead)
    But it cannot get it to work.
    1 hour ago, jompa68 said:
    This should work. Have you declared UHASSleepState as a trigger in the scene header?
    OH NO! o.O
    Hmm how could i forget that...thanks for heads up @jgab
    Happy midsummer :D
    Sorry that i quote you again @jgab but it did not work, even with variable in header
    A quick test in the emulator, with UHASSleepState declared in the header (88,99,100,101 not declared but defaults 'safe')
    works as expected in the emulator.
    If you just add
    before or after the 'for' rule, do you get som log message when you set the variable?
    Did test with another variable and it seems to work. Must check why my normal variable does not have same effect. Will let you now.
    Good morning Jan,
    All scenes are still up and running and HC2 is up for 40 hours now.
    In my variables the mailbox list is growing is there a way to delete it automatically?
    Sometimes it happens I can not connect remote with my app the HC2. If I am outside and want to disarm its a kind off frustrated.
    Can I disarm my complex using Telegram? If yes how to do it?
    Please advice
    @jgab think i found why repeat does not work when i add variable instead of time on my rule
    If scene is restarted for some reason it will never run this line anymore, only when variable is triggered
    Possible to solve it some how or just stick to clock time setup?
    It's simple.
    .start() triggers the rule once when it starts up. If the condition (dwSensors:safe & pirSensors:safe & $VSL_sleep_5 == 'Sover') is true it will start to repeat
    On 6/20/2019 at 7:32 AM, Sjakie said:
    Good morning Jan,
    Default is that one variable is created per ER scene (ID) - unless you have set _MAILBOXES to a higher number. There is no automatic way to date them but you could run
    to remove them all. However you need to restart the ER scenes afterwards so the ones that exists can recreate their GVs.
    Please advice
    Yes, the node-red flow has support to get messages from Telegram
    You need to setup a chatbot according to instructions for the Telegram node-red node. Search the posts in the event runner thread for Telegram to get more tips.
    When you can get a Telegram message into ER (of type #telegram{msg=<message>}) it is simple to make rules
    Ex.
    This is a bit more advanced, only removes variables that don't have a corresponding scene
    I have telegram running on my NR and ER
    works perfect. Can arm/disarm alarm remotely that way also.
    I am jalours!
    14 minutes ago, Sjakie said:
    I am jalours!
    Can export my flow and ER setup later today
    Hi jompa,
    that should be great, thanks in advance!!
    Here is my Node-Red flow for telegram
    There is some info how to setup in flow. If you find it difficult you are welcome to ask. Trickiest part is to setup a bot and get chatID and Token.
    My lua code for telegram
    Can also turnOn/turnOff devices or room, change variables.
    Hello guys,
    Jompa thanks for the info, Ialready have a part of it got it from Jan a while ago in the extended NodeRed flow
    I feel myself at the center of the Forrest without any navigation.
    What did I do (wrong)?
    In the Nodered from Jan SonosPollyTts is working since the beginning.
    TelegramBot was working via a Lua scene in HC2, not by ER.
    Jompa I checked all settings and did get not any message on my phone BUT I saw the test message in the debug window in NodeRed!!! So I was looking on the wrong screen,hahaha.
    23-6-2019 12:15:10
    echo : msg.payload : Object
    object
    data: "can I see this in NodeRed?"
    type: "echo"
    _from: 1608
    1608 is Telegram scene from Jan
     -------------- Trigger rules-----------------------------
    Rule.eval("#telegram{msg='$msg'} => cmd=msg.content; log('Telegram command:%s',cmd)")
    function telegram(ref,msg)
        local tmsg = _copy(ref)
        tmsg.content=msg
        Event.postRemote(_myNodeRed,{type='telegram',msg=tmsg})
      Rule.eval("#telegram{msg='disarm'} => post(#alarmOff)")
     -- rule("remote(NodeRed,#echo{data='test'})")
    rule("#response{data='$d'} => log('Got back:%s',d.data)")
      Rule.eval("@08:00 => $Telegram='Pillen innemen'")
      Rule.eval("@17:00 => $Telegram='Pillen innemen'")
      Rule.eval("@23:00 => $Telegram='Pillen innemen'")
       Rule.eval("@12:14 => $Telegram='test telegram jgab'")
      -- Now you post to a node-red server this way
    NodeRed = "http://192.168.1.89:1880/eventrunner" -- save url to server
    Event.postRemote(NodeRed,{type='echo', data='test'})
    -- or
      rule("remote(NodeRed,#echo{data='test 3'})")
    BUT this works only ( getting the message on my phone) if the lua scene is active?????????????????? So what I am doing wrong?
    Your scene for telegram iI inserted in the ESeneID
    Thanks in advance,
    Please advice
    mmmh something also to correct
    We noticed 5 failed login attempts to your HC2-055203 that seemed suspicious.
    For your security, the following IP address: 192.168.1.89 has been locked for 30 minutes.
