    1 minute ago, jompa68 said:
    Have not tried anything yet, you have some input to share?
    I never used a thermostat.
    If you can do
    fibaro:call(deviceID,'turnOn')
    fibaro:call(deviceID,'turnOff')
    fibaro:getValue(deviceID,'value')
    it will work with ER. I guess there is some way to set a setpoint too?
    Yes, possible to use setpoint, thinking to setup heat panel. Must read how that works first. Anyone of you using it at you home?
    There seems to be 2 operations one wants to do with thermostats
    setTime was already supported in ER and I pushed a new version (B63) that supports targetLevel
    If you set time or targetLevel does it generate a sourceTrigger back to the scene?
    Hi Jonny,
    Nope my heater order goes by http post
    Seems to be more actions possible. Can you post the device structure, especially with the actions field.
    E.g.what you get from  http://<HC2 IP>/api/devices/<controller deviceID>
    Ok, now there is support for (in B64)
    I don't know what the commands do :-)
    :schedule takes 3 arguments so you need to make it a table of 3 arguments as '=', assignment only takes one value in ER.
    Hallo @jgab , I am trying to move a scene which I use to show some measurements in Grafana via influxdb. Now I found node-red-influxdb-contrib and it works great when I send measurments fom OpenWeathermap in ER to this node. But how do I implement the following (which obviously doesn't work)?
    %% properties
    309 value
    317 value
    %% events
    %% globals
    %% autostart
    -- Don't forget to declare triggers from devices in the header!!!
    if dofile and not _EMULATED then _EMBEDDED={name="EventRunner", id=27} dofile("HC2.lua") end
    _version,_fix = "2.0","B59"  -- June 24, 2019
    -- EventRunner. Event based scheduler/device trigger handler
    -- Copyright 2019 Jan Gabrielsson. All Rights Reserved.
    -- Email: [email protected]
    _sceneName   = "testing"      -- Set to scene/script name
    _homeTable   = "HomeTable" -- Name of your HomeTable variable (fibaro global)
    _HueHubs     = {}          -- Hue bridges, Ex. {{name='Hue',user=_HueUserName,ip=_HueIP}}
    _myNodeRed   = "http://192.168.1.158:1880/eventrunner" -- Ex. used for Event.postRemote(_myNodeRed,{type='test'})
    --if dofile then dofile("credentials.lua") end -- To not accidently commit credentials to Github, or post at forum :-)
    -- E.g. Hue user names, icloud passwords etc. HC2 credentials is set from HC2.lua, but can use same file.
    -- debug flags for various subsystems...
    _debugFlags = {
      post=false,invoke=false,triggers=false,dailys=false,rule=false,ruleTrue=false,hue=false,msgTime=false,
      fcall=false, fglobal=false, fget=false, fother=false
    _EVENTSERVER=true       -- Starts port on 6872 listening for incoming events (Node-red, HC2 etc)
    ---------------- Here you place rules and user code, called once at startup --------------------
    function main()
      local HT = type(_homeTable)=='number' and api.get("/scenes/".._homeTable).lua or fibaro:getGlobalValue(_homeTable)
      HT = json.decode(HT)
      Util.defvars(HT)            -- Make HomeTable defs available in EventScript
      Util.reverseMapDef(HT)      -- Make HomeTable names available for logger
      local rule,define = Rule.eval, Util.defvar
       if _EMULATED then
        --_System.speed(true)               -- run emulator faster than real-time
        --_System.setRemote("devices",{5})  -- make device 5 remote (call HC2 with api)
        --_System.installProxy()            -- Install HC2 proxy sending sourcetriggers back to emulator
      ---------------START TEST------------------------
     deviceList =
     temperature = { Altandorrtemp = 85, AltanTemp = 14,
        ForradsdorrTemp = 231, Balkondorr = 371, Friggebod = 387 },
     energy = { TV = 290},
     motion = { PirAltan = 13, PirTrappa = 439},
     door = { BalkongSov = 370,  AltanVrum = 84, Entre = 92, Tvatt = 34,
        Forrad = 230, Friggebod = 386, TVmarkis = 252, Sovmarkis = 262},
     light = { Arbetsrum = 309, LillaSovr = 317 },
    local sourceTrigger = fibaro:getSourceTrigger()
    if (sourceTrigger['type'] == 'property') then
       processOne(sourceTrigger['deviceID'])
    function processOne(findDeviceID)
      for deviceClass, devices in pairs(deviceList) do
        for deviceName, deviceID in pairs(devices) do
          if (findDeviceID == deviceID) then
           rule("remote(_myNodeRed,#devices{class=deviceClass, name=deviceName, id=deviceID, data=deviceID:value}")
    function processAll()
    rule("@@00:02 => processAll()")
    This should work.
    You need to use the Lua function Event.postRemote instead of the rule(...).
    I do a reverse map of your deviceList so that it is quicker to lookup a device and get name and class - but you can do it your way too
    1 hour ago, jgab said:
    his should work.
    Working ok, great, thank you Jan.
    Hallo Jan,
    If I arm gona arm the house I will check first if all doors and windows are closed if not >>>> telegram
    To arm I use:
            Rule.eval("serre.deur:breached & serre.deur:armed=='1' => post(#AlarmState); postRemote(1627,#AlarmState);  $Telegram='Alarm, serre.deur breached'")
            Rule.eval("woonkamer.raam:breached & woonkamer.raam:armed=='1' => post(#AlarmState); postRemote(1627,#AlarmState);  $Telegram='Alarm, woonkamer raam breached'")
            Rule.eval("keuken.deur:breached & keuken.deur:armed=='1' => post(#AlarmState); postRemote(1627,#AlarmState);  $Telegram='Alarm, keuken deur breached'")
    Suppose a door is open when I switch on "arm" does that result in an alarm?
    Its telling me every second I am in alarm!
    Please advice,
    /monthly_2019_07/image.png.3d867a62f35d2b6fb9111fc5ad9128d8.png" />
    To get the triggers when it is armed or breached you need declare
    if serre.deur has deviceID 22. And for all the windows/doors.
    The reason you get a notification that you are in alarm every second must be some other rule. Can't see that from your log.
    Hello Jan,
    Yep according your device I did those in header.
    Okay let me struggle a bit to see if I can find something.
    @jgab today i control my SONOFF's devices with a VD but that fails to often so i would like to use ER instead. Did read some earlier post about httpGet, so is my understanding that line below should work?
    It's not a built-in function .- I provided it in an example for Sjakie
    very simple and no error checks besides the log.
    I have used the below example myself to retrieve the value from a get
    Ex.
    cannot get this simple rules to work, what am i doing wrong?
    Edited by jompa68
    Are all the rules in the same scene? 'publish' will only send to other scenes (that subscribe). Within scenes use 'post'
    Just now, jgab said:
    Are all the rules in the same scene? 'publish' will only send to other scenes. Within scenes use 'post'
    No, 1 publish scene
    and this is in another scene
    16 minutes ago, jompa68 said:
    No, 1 publish scene
    I'm trying the same rule on my HC2 and it works ok. Have you declared pirSensor.wc in the %% properties header so it triggers?
    Add a log and see if it triggers
    Do you see that the event arrives in the subscribing scene(s) ? ("Incoming event...")
    No events appears in 2:nd scene.
