    2 minutes ago, Sjakie said:
    Hello Jan,
    I will try!
    IOSLocator
    I came home at 11:55 No post
    If I change something in the scene and save it will post.
    Please advice,
    ioslocator will post all users's location when it starts up. It takes a minute or two between polling each user.
    After that it will only post when a user's location changes.
    So you will always get the post when you restart the scene - that's what you see.
    You sure that your position changed (enough?). You could log every time you get a new position to see if it works.
    3 minutes ago, jompa68 said:
    try to explain better, sorry for lack of info.
    This is the error i get in ZBS, only started with my first V3 scene (publish scene)
    Ah, that's another problem. Strange, I just did a pub/sub with two scenes in ZBS to test and it worked for me. Let me try to reproduce the problem.
    In any case, the error message is bad.
    You run the latest version of HC2.lua? "0.11","fix6"
    If you run the latest, post me you pub/sub scenes so I can try them out.
    Hello Jan,
    3 minutes ago, Sjakie said:
    Hello Jan,
    Sorry, just comment out the dofile at the end of the main(). I forgot it was there when I did tests and checked in in by mistake.
    In the next version it's fixed.
    error on Util
    If I remove dev from 1st line error is gone and scene continue
    1 hour ago, Sjakie said:
    error on Util
    Yes, those lines are for the inline HT table that is provided as an example. If you have a HT in a global that looks different you need another setup. Should work with the same setup as you had in the previous version.
    One scene running.
    Rule.eval("bijkeuken.wasdroger:power >10 & !bijkeuken.wasdrogerStarted => bijkeuken.wasdrogerStarted=true; log('wasdroger - working')")
    Please advice
    Okay just follow you to close!
    Thanks Jan
    4 minutes ago, Sjakie said:
    One scene running.
    Please advice
    Thanks Jan
    It seems bijkeuken.wasdroger is nil. Have you managed to setup the HT and do Util.defvars on the HT?
    Sorry Jan but this new version see a lot of errors( I am ashamed!)
    First rule no error
     Rule.eval("label(496,'lblWeather')=='clear sky'& @sunrise-01:00 => woonkamer.gordijnoprit:close; log('bij heldere hemel gordijn oprit sluiten')").start()
         Rule.eval("label(496,'lblWeather')=='light rain'& @sunrise-01:00 => woonkamer.gordijnoprit:close; log('bij heldere hemel gordijn oprit sluiten')").start()
         Rule.eval("label(496,'lblWeather')=='over clouds'& @sunrise-01:10 => woonkamer.gordijnoprit:close; log('bij heldere hemel gordijn oprit sluiten')").start()
    PLease advice and sorry for the heavy traffic here.
    Jan,
    The IOSLocator did not make any post the last days. I was away for 2 km
    First rule no error
    High traffic expected with new version :-)
    That was my problem - the Rule.eval returned a broken value so .start() was missing from the result... I pushed a new version B4 that fixes it.
    I have two lines wasmachine and wasdryer bot give error
    Correct me if I am wrong:
    If no HT set up all rules with devices should give error?
    Util.defvars same result I asume, when I tried to solve the Util.defvars it was ging error line b y line
    Both wasmachine and wasdroger are in HT.
    Jan my arming scene is running without any error.
    Jan sorry You are to fast and I am to slow, hahaha
    Yes, if you have not done Util.defvars with your HT it will not find the variables inside the rules.
    Exception is if you have "global" lua variables declared as they are accessible from within rules.
    Try adding a log rule just before the problematic rule to see what wasdroger is.
    I'm almost learning the names of all the dutch home appliances by now :-)
    /monthly_2019_07/image.png.1a7ded68d29fa959bd8b55a566f76501.png" />
    19 minutes ago, Sjakie said:
    My fault. Wrong priority for the '!' operator which made a mess of the expression. Added it to my test cases and pushed a new version, B5.
    Okay will update.
    Jan ready for the next one?
    Rule.eval("$StookSeizoen=='Ja' & hal.locatiegezin:isOn & once(trueFor(00:05,eetkamer.deur:breached)=> remote(_myNodeRed,#speak{data='de deur naar de serre is open en de thermostaat wordt ingesteld op 17 graden'})  ; httpGet('http://192.168.1.101/data.json?heater=0&setpoint=120&thermostat=0'); log('Verwarming uit serre op temperatuur')")
    Will do tonight when I arrive home again
    Hi Jan,
    Is one mailbox message not enough?
    Jan,
      Rule.eval("achtertuin.fontein:isOn =>  remote(_myNodeRed,#speak{data='de fontein wordt gestart'}) ,10*repeat(0)")
    Here I am clue less!
    @jgab
    Hm, testing. Got error 'Error loading rules:NR3TEST.lua:1814: NR3TEST.lua:1650: attempt to index local 'res' (a nil value)'
