Jan,
I had this rule
  Rule.eval("$StookSeizoen=='Nee' => log('Stookseizoen Nee')").start()>>>error
Rule.eval("$StookSeizoen=='Nee' => log('Stookseizoen Nee')") >>>no error but also no log
Please advice
    10 minutes ago, Sjakie said:
    Jan,
    I had this rule
    Please advice
    This should work "Rule.eval("$StookSeizoen=='Nee' => log('Stookseizoen Nee')").start()"
    What kind of error do you get?
    Jan, unfinished string
    Rule.eval("$StookSeizoen=='Nee' => log('Stookseizoen Nee').start() >>>attempt to index a nil value
    Hi Jan,
    Am I do it right?
    In HT:
    hueMap={ [12278]='ambitvlight',[12281]='lampplafondklokzijde'
    also in
    woonkamer={ambitvlight=12278,lampplafondklokzijde=12281,
    and in scene where HUE is used:
    Hue.define("ambitvlight", nil, 12278)
    Hue.define("lampplafondklokzijde", nil, 12281)
    Is this to combine? I guess I can delete the HUE out the woonkamer?
    Please advice
    this logic seems that have been changed also
    Fixed, bug in parser. pushed B11.
    Tested from your post
    rule("log('Echo returns '%s',nodered(#echo{test='Hello'},true).data.test))")
    Got
    tokenizer failed at '},true).data.test)
    Also in V.2 B66 I had
    rule([[@@00:01 => remote(_myNodeRed,#wetter{}); a=tonumber($yttertemperatur); b= tonumber($windhastighet); c= $windriktning; d=tonumber($regn); remote(_myNodeRed,#egetwetter{yttertemp=a, vindstyrka=b, vindriktning=c, regn=d})]])
     rule("#wetter =>   moln=env.event.data.clouds")
    I changed it to
     rule("@@00:01 => nodered(#wetter{}); a=tonumber($yttertemperatur); b= tonumber($windhastighet); c= $windriktning; d=tonumber($regn)")
     rule("@@00:01 => nodered(#egetwetter{data=yttertemp=a, vindstyrka=b, vindriktning=c, regn=d}")
    Wed/Jul/31,12:16:30:[10:1] Rule:6[@@00:01 => nodered(#wetter{}); a=tonumber($yttertemperatur); b= tonumber($windha...] = "OK"
    but then it stops.
    And how do I get back 'moln=env.event.data.clouds' from NodeRed?
    nope, still error
    /monthly_2019_07/1927847980_Skrmavbild2019-07-31kl_12_20_31.png.80885f14cf27e029b826fccc8a227cd4.png" />
    Got
    I changed it to
    but then it stops.
    Sorry, the rule was not grammatically correct. strings were wrong.
    The new rule you could do
    nope, still error
    It looks like _defaultNodeRed is nil in the remote call at the end ?
    1 hour ago, Sjakie said:
    Hi Jan,
    Am I do it right?
    In HT:
    also in
    Please advice
    No keep in woonkamer because you want to address the light as woonkamer.ambitvlight in your rules.
    If you have the hueMap you can make all the Hue.defines in a loop
    Is the logic changed on postRemote to NR? i have not change anything in NR
    No, only changed name from _myNodeRed to _defaultNodeRed
    Have you set up _defaultNodeRed in the beginning?
    Guys, what it means ?
    [DEBUG] 13:15:29: Error in '185:manual == 0 =>||$roletakuchnia =='1'>> log('Closing');VD.SterowanieRoletami:btn=6': /opt/fibaro/scenes/392.lua:2002: no triggers found in header
    forgot add the rule :
    rule("185:manual == 0 =>||$roletakuchnia =='1'>> log('Closing');VD.SterowanieRoletami:btn=6")
    Edited by domin12
    yes i have.
    1 minute ago, jompa68 said:
    yes i have.
    Try B12 I just posted.
    /monthly_2019_07/image.png.8e490048c281258fcee8204c87d6ef40.png" />
    It means I forgot to add 'manual' to the list of triggers ?- I fixed it and pushed B13.
    So, somehow you give nil as first argument to remote(<arg>,<event>)
    Rule 3 looks like below? (Mona/Johnny)
    then it's something strange with '_defaultNodeRed'
    Can you try to log it?
    Jan ,
    there is no function called _copy any longer ?
    how could i change this function to get proper working :
    Edited by domin12
    /monthly_2019_07/470882230_Skrmavbild2019-07-31kl_13_39_38.png.bfd26355434eb27441887879f3e5bdca.png" />
