Sorry Jan,
rule("phoneID=447")
error>>call global nil value
447 and 470 are listed in IOS Fibaro both have error
Please advice.
My compliments about the version 3.0
It showed a lot of errors I never have seen before still surprised it was still working.
    1 hour ago, Sjakie said:
    Hello Jan,
    Please can you explain??
    This rule gave error index field
    I was checking the rule the debug window refreshed(full) and error gone, without edit anything.
    Is it your magic hand?
    The scene auto-updates when you restart if there is a new version. Maybe that’s what happened?
    1 hour ago, jgab said:
    for -> trueFor
    Great, that works. What about this?
    Sorry, seems to have accidently removed support for #event triggers inside nested expressions (the trueFor in this case)
    I'll fix it tomorrow morning.
    I fixed #event triggers in nested expressions so it behaves as the old version. (v3.0 B8)
    the .start() is unnecessary as the condition will always be false as there is no #VirtualSensor event available that have triggered the rule.
    Looks like "osDate" have been adjusted, this is not working anymore and osdate does not fit in
     osDate has gone and you just use os.date (on ZBS I patch os.date and os.time to work with simulated time)
    (In ER rules you can use osdate())
    and this?
    5 minutes ago, jompa68 said:
    and this?
    OR is single '|'
    The old parser was a bit more "forgiving"... for "test1 || test2" it generated "test1 OR false OR test2"...
    Ah, ofcourse.
    so now all 138 rules have status "OK" and seems to be running.
    Hey,
    Recently I do not have time to update the ER, but I see that the time has come and I started to do it today, unfortunately I encountered a problem with this:
    [DEBUG] 08:33:36: 2019-07-31 08: 33: 36.335398 [fatal] Unknown exception: /opt/fibaro/scenes/392.lua:2986: attempt to call global 'eventConsumer' (zero value)
    i'll be appreciated with any help, what i've missed:)?
    Just now, jompa68 said:
    Ah, ofcourse.
    Great!
    @Sjakie, you and @FrankT have helped me kill a lot of bugs the last 24 hours. Thanks!
    There are of course more bugs to be uncovered but I feel the code is improving.
    4 minutes ago, domin12 said:
    Hey,
    My bad, made a quick fix this morning that made eventConsumer disappear - I pushed a new version B9, or just remove the 'local' infront of 'function eventConsumer()' in the upper part of the scene where it's declared.
    1 pass , another to resolve  ? :
    [DEBUG] 08:51:22: 2019-07-31 08:51:22.671862 [ fatal] Unknown exception: /opt/fibaro/FibaroSceneAPI.lua:146: Assertion failed: Expected string
    Ugh, I should not push changes without testing on the HC2.
    I pushed a new version v3.0 B10.
    If you want to patch your existing code it's inside eventConsumer. The calls to _getGlobal and _setGlobal should have a nil as first argument.
    Update .version also
    Done.... now! :-)
    Thats resolve the problem, and getting new one , sorry guys , but to many new post to find solution quickly,
    what is change , this rule previously working fine :
    [DEBUG] 09:17:25Error in '#location{user='[email protected]',place='away'} => $placeDominik = '%s',$pozDominik': /opt/fibaro/scenes/392.lua:1720: Parser error char 77 (',') in expression '#location{user='[email protected]',place='away'} => $placeDominik = '%s',$pozDominik' (/opt/fibaro/scenes/392.lua:1472: attempt to index field '?' (a nil value))
    Edited by domin12
    sorry, you have missed to update evenrunner3.lua with new version. Patching is looping
    @jgab
    Edited by jompa68
    @jgab
    Yes, didn't check it in. Done now.
