Testing Telegram setup, get this error but message arrives anyway.
/monthly_2019_08/285833939_Skrmavbild2019-08-11kl_12_47_53.png.ffa627d4b6c605bcaa124a089c2162dd.png" />
Guest kallecux
Hello!
I'm really trying to connect to Node-Red, but without success.
This is my structure:
and in Node-Red i have this simple flow:
/monthly_2019_08/379482671_Bildschirmfoto2019-08-11um15_01_31.png.9cfce314d5291ed578a17bbfacc154c1.png" />
with this details:
954212966_Bildschirmfoto2019-08-11um15_05_41.png.82ffe4f27c8d601344612c44619c309e.png
There is no debug-Output.
Do you have any tip?
Thanks!
Edited by kallecux
    2 hours ago, kallecux said:
    Hello!
    Sure port is 1880 and not 8080?
    Btw, I posted v3 B46 that has better error messages if a request to nodered goes wrong (http request)
    The "Handshake error" seems to come from inside http:request(...) ?
    The "network unreachable" is what the error handler for the http:request gets back. I'm a bit clueless as I haven't seen this before.
    Is it this way with every request?
    Guest kallecux
    Yes, i am using Port 1880 by default.
    When i shutdown Node-Red i get this:
    thats OK. When Node-Red is running i get this in the Node-Red logfile:
    401 means unauthorized?
    My Node-Red config is like this:
    Sorry for the "Node-Red questions".....
    Edited by kallecux
    thats OK. When Nord-Red is running i get this in the Node-Red logfile:
    No, problem.
    Ok, it seems like you run with ssl (requiring https) which ER is not using (only unauthorised http)
    The HC2 is in general doesn't support https so that's why https is not done from ER.
    We could support some basic authentication but there had been no need for it so far as most run their nodered on the home network close to the HC2.
    Can you try to turn off ssl for nodered and see if it works.
    Guest kallecux
    No better result :-(
    I think it's a problem with my Node-Red instance or my environment.
    I try a fdisk and format C:/ and make an new Node-Red installation ;-)
    Thank you for your help.
    Greetings
    Karl Heinz
    Greetings
    Karl Heinz
    I run node-red on a Raspberry-PI as an app started from the Raspberry desktop, I believe that @jompa68 may run it from a container on a PC server...
    Pushed v3, B49.
    It turns out that net.HTTPClient():request(...) in scenes, due to its asynchronous behaviour, can cause some issues.
    Code that sent many request to Hue, flooded the bridge and commands where ignored.
    I solved that with a hack that queued  the Hue requests in B43. Queueing means we don't send a request before we get a call-back to our success (or error) handler...
    Well, it turns out you can DDos Telegram and Nodered also by sending requests too quick.
    The sense moral of this is that we should never send request to an external server quicker than we get responses back.
    So, I implemented a generic queuing replacement for net.HTTPClient():request(...) and is using that now for Hue, Telegram, and Nodered.
    I have made some initial testing and it works quite well (the throughput is still good).
    The other big change in B49 is that support for Event.postRemote(url, event) or Rule.eval("remote(<url>,<event>) is removed.
    Now postRemote/remote only accepts a numerical sceneID as the first argument and is only used to send events between scenes.
    It was possible to use postRemote/remote to send events to Nodered in the past but now that should be handled through Nodered.post(event)
    If you have some issues, including strange error messages from the services, let me know.
    Good, was about to write a post regarding this. Did see that yesterday morning. Will update now and report back if still an problem
    Sorry,
    managed to introduce a bug in postRemote
    Pushed v3, B50.
    Did get an question from @jgab today about "tradfri" devices and if i have tried to add them to a hue bridge. So was not the case, i did not know that was possible even.
    After few minutes of reading on google i did give it a try.
    Firmware needs to be latest on your "tradfri" device, they need to be removed from their default gateway and reseted to factory default, then it is possible to add them to hue bridge.
    So now i can handle them easy like other hue devices in ER. How cool is that ?
    (an example how i use them, start or stop charging our phones during sleep time.)
    Cool!
    Btw,
    Just update to 3.0 B52
    And its something wrong with this version.
    /monthly_2019_08/image.png.5034118eb2ebb328d3f46bc4d2d27f5c.png" />
    Rolled back to 3.0 B51 and it works again.
    Edited by sonnyboy
    Sorry, pushed V3, B54 with a fix.
    Nice now it works again :)
    Here is a list of the commands/constructions that are available in EventScript in ER v3 B58.
    I will come back to this post and add more documentation.
    Grammar
    Rules:
    Script rules comes in four main flavours, and always contain a '=>'
    Rules are expressed as Lua strings and are compiled and registered with the function Rule.eval(<rule string>)
    Later when matching conditions are met the rule is executed - conditions are on the left-hand side of the '=>' and actions on the right-hand side
    Expression given to Rule.eval without an '=>' is evaluated immediatly.
    @time -- always part of a rule. Run action at time of day
    @{t1,...tn} -- always part of a rule. Run action at times of day
    @{catch,t1,...} -- if the first argument in the time parameter list is the constant 'catch' the framework tries to catchup actions that have already passed when the framework starts up
    @@intervall -- always part of a rule. repeat action at specified interval
    #event -- event triggering rule.
    '#foo' is a short for {type='foo'}
    '#foo{bar=9}' is a short for {type='foo', bar=9}
    Matching with constraints are allowed in event values and start with '$..'. Variables bound in matching expression available as local vars in rest of rule.
    'env' -- script variable that is bound the the environment the script is executing in. Specifically env.event is the event (sourceTrigger) that triggered the rule.
    User functions:
    • Time constants
      Time constants are converted to seconds.
      This allows for arithmetics like Rule.eval("11:20 == 10:30+00:50")
      • HH:MM[:SS], 10:20 == 3600*10+60*20
      • +/HH:MM[:SS],  Add time to current time. +/10:20 == os.time()+3600*10+60*20
      • t/HH:MM[:SS],  Epoc of time today. t/10:20 == midnight+3600*10+60*20
      • n/HH:MM[:SS], Epoc of next 10:20. Today if it's before 10:20 and 10:20 tomorrow if it's after 10:20
      • YYYY/MM/DD/HH:MM[:SS], Long form for Epoc. Ex. 2020/03/01/10:20
    • Arithmetic operators
      • %,*,+,-,/ - Normal operator precedence is used and parentheses is also allowed
      • Please login or register to see this code.
      • '+=','-=','*=' - increment and assign. works with variables only
    • Comparison operators
    • Logical operators
    • Date and day related
      • HM(<time), converts a time to string  "HH:MM"
      • HMS(<time), converts a time to string  "HH:MM:SS"
      • now, seconds since midnight
      • midnight, epoc for last midnight
      • dawn, seconds from midnight to dawn
      • dusk, seconds from midnight to dusk
      • sunrise, seconds from midnight to sunrise
      • sunset, seconds from midnight to sunset
      • wnum, week number
      • date(<string>), cron test
      • day(<string>)
      • month(<string>)
      • wday(<string>)
      • osdate(<string>)
      • ostime(), current time in epoc (midnight+now)
      • time(<string>), converts time string to seconds
    • Table operations
      • add(<table>,<element>)
      • remove(<table>,<index>)
      • size(<table>)
    • Mathematical functions
      • rnd(<n1>,<n2>)
      • round(<number>)
      • sign(<number>)
      • average(<table>)
      • max(<table>)
      • min(<table>)
      • sum(<table>)
      • sort(<table>)
    • Type and name functions
      • num(<element>)
      • idname(<deviceID>)
      • str(<element>)
      • type(<element>)
    • Log and formatting
      • log(<string>,...)
      • fmt(<string>,...)
      • fjson(<string>)
      • tjson(<table>)
    • Rule and event functions
      • post(<event>,<time>)
      • cancel(<post ref>)
      • remote(<sceneID>,<event>)
      • publish(<event>)
      • subscribe(<event pattern>)
    • Managing fibaro globals
      • global(<string>)
      • listglobals()
      • deleteglobal(<string>)
    • VD functions (only HC2)
      • label(<deviceID>,<tag>)
      • label(<deviceID>,<tag>)=<string>
      • slider(<deviceID>,<tag>)
      • slider(<deviceID>,<tag>)=<string>
      • VDev.define(<name>,<tag>,<version>,<rows>)
      • VDev.remove(<tag>)
      • VDev.clearCache()
    • EventScript  functions
      • env - variable that contains the event that has triggered the rule
      • eval(<string>)
      • disable(<rule>)
      • enable(<rule>)
      • trueFor(<time>,<expression>)
      • again(<n>)
      • once(<expression>) -- Expression needs to turn false before it will be true again.
        The rule will rigger the first time the temp > 10, then it needs to go below 10 and above again for it to trigger the next time.
        Plays good morning message only once when sensor breached between 6-7
      • wait(<time>)
      • trace(<boolean>)
      • match
      • pack(<function call>)
    • Control structures
      • if <expr> then <statments> elseif <expr> then <statments> else <statments> end
      • while <expr> do <statments> end
      • repeat <statments> until <expr>
      • for i=<expr>,<expr>[,<expr>] do <statments> end
      • for k,v in ipairs(<table>) do <statments> end
      • for k,v in pairs(<table>) do <statments> end
      • || <test> >> <statments> ...
    • Rule constructs
      • @<time> [& <additional tests>] => <statements>
        Schedule rule at <time>  every day
      • @@<time> [& <additional tests>] => <statements>
        Schedule rule at repeating <time> intervals
      • <trigger expression> => <statements>
        <trigger expression> contains triggers (deviceID, fibaro globals), and rule will be called every time they change status
      • #<event> [& <additional tests>] => <statements>
        Rule will be called every time #<event> is posted
    • Integration with other systems
      • Nodered.connect(<url>)
      • Nodered.post(<event>)
      • Hue.connect(<user>,<ip>) (only HC2)
      • Hue.define(<name>,<deviceID>) (only HC2)
      • Hue.monitor(<deviceID>,<ms>) (only HC2)
      • Hue.dump() (only HC2)
      • Telegram.bot(<token>) (only HC2)
      • Telegram.msg(<id>,<string>) (only HC2)
    Property functions:
    • <ID>:value - returns value property of device. fibaro.getValue(id,"value")
    • <ID>:value=..  - set value property of device. fibaro.call(id,"setValue",...)
    • <ID>:isOff. -- returns true if device value is false or 0
    • <ID>:isOn -- returns true if device value is true or > 0
    • <ID>:isAllOn
    • <ID>:isAnyOff
    • <ID>:off -- turns off device. fibaro.call(id,"turnOff")
    • <ID>:on - turns on device. fibaro.call(id,"turnOn")
    • <ID>:toggle
    • <ID>:dim={<time>[,'up'|'down',<step>,<curve>,<start,<stop>}
    • <ID>:breached,   synonym for :isOn but more appropriate for motion/door/window sensors
    • <ID>:safe,  synonym for :isOff but more appropriate for motion/door/window sensors
    • <ID>:isClosed
    • <ID>:isOpen
    • <ID>:close
    • <ID>:open
    • <ID>:stop
    • <ID>:bat
    • <ID>:power
    • <ID>:power=..
    • <ID>:lux,  synonym for :value but more appropriate for lux sensors
    • <ID>:temp,  synonym for :value but more appropriate for temperature sensors
    • <ID>:last
    • <ID>:trigger
    • <ID>:secure
    • <ID>:unsecure
    • <ID>:lock, synonym for :secure
    • <ID>:unlock, synonym for :unsecure
    • <ID>:isSecure
    • <ID>:isUnsecure
    • <ID>:isLocked, synonym for :isSecure
    • <ID>:isUnlocked, synonym for :isUnsecure
    • <ID>:manual
    • <ID>:wake
    • <ID>:name
    • <ID>:HTname
    • <ID>:roomName
    • <ID>:start
    • <ID>:start=..
    • <ID>:kill
    • <ID>:scene
    • <ID>:access
    • <ID>:central
    • <ID>:armed, fibaro:getValue(<ID>,"armed")=='1'
    • <ID>:armed=<expr>, fibaro:call(<ID>,"setArmed",<expr> and '1' or '0')
    • <ID>:btn=..
    • <ID>:dID
    • <ID>:defemail=..
    • <ID>:email=..
    • <ID>:msg=..
    • <ID>:defaultPartyTime=..
    • <ID>:removeSchedule
    • <ID>:retryScheduleSynchronization
    • <ID>:interval=..
    • <ID>:schedule=..
    • <ID>:scheduleState=..
    • <ID>:setAllSchedules
    • <ID>:setpointMode=..
    • <ID>:targetLevel=..
    • <ID>:thermostatSetpoint=..
    • <ID>:mode
    • <ID>:mode=..
    • <ID>:time
    • <ID>:time=..
    • <ID>:B=<expr>, fibaro:call(<ID>,"setB",<expr>)
    • <ID>:G=<expr>, fibaro:call(<ID>,"setG",<expr>)
    • <ID>:R=<expr>, fibaro:call(<ID>,"setR",<expr>)
    • <ID>:W=<expr>, fibaro:call(<ID>,"setW",<expr>)
    • <ID>:B, fibaro:getValue(<ID>,"B")
    • <ID>:G, fibaro:getValue(<ID>,"G")
    • <ID>:R, fibaro:getValue(<ID>,"R")
    • <ID>:W, fibaro:getValue(<ID>,"W")
    • <ID>:color
    • <ID>:color=..
    It would be nice if "isSecure" and "isUnsecure" would be supported :)
    That's probably easy to add but I don't have a lock so you need to help me.
    <ID>:secure translates to fibaro:call(<ID>,"secure") and locks the lock I assume.
    <ID>:unsecure translates to fibaro:call(<ID>,"unsecure") and unlocks the lock I assume.
    (Btw, should we change name of these to <ID>:lock resp. <ID>:unlock  ?)
    How do you get the status of the lock?
    fibaro:getValue(<ID>,"value") or fibaro:getValue(<ID>,"secured") or ? and what does it return?
    Change name to lock and unluck would be nice, it sounds more up to date.
    This below is the lock status when i run this code
    When the lock is Unsecure (unlocked) [DEBUG] 11:00:50: Value danalock : 0
    When the lock is Secure (locked) [DEBUG] 11:01:43: Value danalock : 1
    Can you try
    because it seems like some other "lock" devices has that property.
    I wonder if all "locks" respond to the "value" property or "secured".
    It makes a difference because you need to declare the triggers as
    <ID> value
    or
    <ID> secured
    in the scene header.
