That is not possible, it is default behavior of the HC2
Hi Jompa,
Thanks.
btw can you send email from ER scene?
1 hour ago, Sjakie said:
Hi Jompa,
Thanks.
Dont think so, or @jgab?
    Yep,
    The header and body of the email is split at the first ':' in the message.
    Good morning,
    What I am doing wrong?
                   Rule.eval("woonkamer.spotsjaak:isOn =>  log('woonkamer spotsjaak - aan')")
                        Rule.eval("woonkamer.spotsjaak:isOff =>  log('woonkamer spotsjaak - uit')")
        Does not post in debug
    Please advice
    //Sjakie
    /monthly_2019_09/image.png.6ad6be30982a28b61e180a70d748fa1a.png" />
    5 hours ago, Sjakie said:
    Good morning,
    Please advice
    //Sjakie
    events from Hue devices is a bit tricky. I used to have a filter that seems to have been accidentally set to nil in the code and thus didn't let through any events when a Hue value was changed from Lua code (Hue.monitor still works)
    I pushed a version with a fix (v3, B66) . It now emits events when a Hue device is turned on and off from Lua code. (so :isOn,  and :isOff should work).
    Having said that, I'm not happy how the code looks like and will think about a better way to do this.
    Thanks for calling my attention to this
    /J
    Hello Jan,
    Thanks!!
    Service excellence!!!!
    All are hue lights:
    /monthly_2019_09/image.png.f62dd5ec4112842d8bed7941645f80d5.png" />
    @jgab
    I need your help - how to transfer hue settings to latest version:
    I have:
    I tried:
    but there is error:
    Error loading rules:EventRunnerLights1.lua:3064: attempt to index local 'hub' (a nil value)
    in this:
    26 minutes ago, petrkl12 said:
    @jgab
    I have:
    I tried:
    but there is error:
    in this:
    Hi, (I think you are the only one with multiple Hue hubs using ER, or?)
    Anyway, the the setup is right. However, the Hue.define has changed to only take 2 arguments; 'Hue name' and ID.
    If you need to assign it to a ER variable you do
    Hue.define returns the ID (30001) that you use for Util.defvar...
    still error - it looks that .connect is called too late ... (where is definition for more hue hubs)
    The definitions should be before main()
    Ex.
    (in the example I just define two hubs pointing to the same physical hub)¨
    Do you get any warnings?
    Now it's OK. (I had typo in hueusername)
    Hello Jan,
    /monthly_2019_09/image.png.7969a61ab8ba7e6993b919fd1f67433f.png" />
        Two errorrs:
    first error ist marked in red?
    second:
    Rule.eval([[once(oprit.luxsensor:lux < 50) & once(16:00..23:15,n/24:00) => post(#eveningMsg); log('TRIGGER:%s',tjson(env.event));
                  log('voortuin lux sensor post eveningmsg')
     gives parser error  ,
    if I remove  once(       and    ,n/24:00)    it will give the red message
    This rule I want but I cant fix it.
    Please advice
    //Sjakie
    25 minutes ago, Sjakie said:
    Hello Jan,
        Two errorrs:
    second:
    Please advice
    //Sjakie
    It's difficult to tell from the log. Can you PM me the scene and I will have a look at it /J
    Hello Jan,
    May I come back on the HUE?
    In my Alexa scene it command to turn on/off
    in the debug I see as well the command and the confirmation  of woonkamer.spotsjaak, all is okay
    /monthly_2019_10/image.png.a3f0d304b3911377ecd8dd22473561ab.png" />
    In my livingroom scene I have also the command confirmation of woonkamer.spotsjaak:
    Why It doest post the on/off woonkamer.spotsjaak  command by Alexa?
    //Sjakie
    Just looked at the code, you have a badly terminated [[]] string here
    that causes some issues, there may be more problems too but I have to check that this evening when I'm home.
    Jan, Thank you very much!!
    Stupid mistake over looked it several times but I was on the wrong track with parser error (,)
    I think this solved the problem if not I will let you know
    Thanks again
    //Sjakie
    Hello Jan,
    May I request something?
    All my rules are now according this example with the Trigger and log
    To follow better if a rule is executed
     Rule.eval("trueFor(00:15:00, serre.spotdubbel:isOn) => serre.spotdubbel:off;log('TRIGGER:%s',tjson(env.event)); log('serre spot dubbel - uit')")
      I like to have this log in another color
     Rule.eval("serre.spotdubbel:isOn) =>  log('serre spot dubbel - aan')")
     Rule.eval("serre.spotdubbel:isOff) =>  log('serre spot dubbel - uit')")
    The old notify is in green but is the same as the rules by starting and I removed from aal scenes except arming
    Thanks for consideration.
    //Sjakie
    10 hours ago, Sjakie said:
    Hello Jan,
    //Sjakie
    Unfortunately the color settings for log became hidden with the last rewrite.
    However, you could define your own log function that takes a color argument and use it in your rules.
    and you can choose other colors.
    Oh, it seems like you can set
    and all calls to 'log' becomes red.
    Hello Jan,
    Thanks its looking good!!!
    Is it possible to read the temperature value of a sensor and let Alexa set it in voice?
    First part seems easy
    Rule.eval("#alexa{device='Temperature',cmd='On'} =>
    For second part I need your experience.
    Thanks in advance
    //Sjakie
