    6 hours ago, amilanov said:
    Jan,
    Have you used this to replace all your automated lighting?
    I'm looking to replace my own code, but haven't found anything yet that does what I want which is to manage all zones from one place - which is roughly what my automated lighting does (albeit I wrote it 5 years ago and it needs an hug overhaul and tidy up)
    I can't have duplicate scenes for each zone as it is too much maintenance to go into so many different places when I want to make a change or when the code gets updated.
    Regards
    Aleks
    Yes, I do.
    In general there is no problem with the number of rules, as rules only run when triggered (many other frameworks poll all the rules in regular intervals).
    What can be a problem (and that's true for scenes that's get triggered in general) is the frequency of triggers. It's usually manageable and ER has some
    tricks to cope with it and for triggers that can arrive in bursts (like 'power' triggers) there are work arounds.
    Because ER is a general purpose framework there are many ways to structure your rules. I'm happy to discuss and help you if you want to try.
    ...and you can run ER in the HC2 emulator, so you can easily speed through 24 hours to see if your lights turn on and off at the right times - and you can simulate sensor breaches to see if your rule logic makes sense.
    Never mind, i did not have an updated hc2.data in ZBS. It is ok now.
    not sure if i found a bug or an mistype of rule
    Hue.monitor gives this error in ZBS
    Edited by jompa68
    Fixed
    I wish I have EventScript implementation in C...
    @jgab can i dump HUE light somehow to see what color code it have?
    @jgab
    i have setup different scenes in HUE app and i can see the name of them in ER but how do i address to scene with a rule?
    Did find some early post in this topic from you but they don't seem to work, can you help or someone that use scenes with ER that now the rule setup?
    Hi Jompa,
    My scenes in Hue are having the same name in ER
    So in ER I more or less copied it
    rule("HueRight={ 12321,12328,12331}")
    //Sjakie
    So you have a scene in HUE with name HueRight?
    yep
    I have a few duplo spots so right are all  right spots
    Hueright
    Hueleft
    HueTv>>> ambilight and two colored Hue's for light effects
    Huediverse
    HueFlag>>with colorshow
    Huegarden>>with colorshow
    the whole controle is via ER
    I dont use HUe app
    Only for light effect on TV
    Does not work for me, it will not change to the scene i want.
    If I change from for example huerigt into hueleft
    first sitch on left with color or brightness than switch off right works well here
    Got it to work, after reading some old post.
    what kind of nice alarmlight you have?
    I have added a couple of IKEA tradfri bulbs to my HUE bridge so i can use them with ER.
    So i will use one of the bulb to show if alarm is on/off and if someone is home. Will also set a soft light during night.
    Was inspired(again) from @cag014 post
    Yes, if the argument (string) is the same as the name of a scene it will set the scene for that lamp. The scene names can be listed with Hue.dump()
    Otherwise if the argument can be translated to a number it will set the dim level to that value.
    Else if the argument is a table it will send the table properties to the Hue light unmodified.
    I have some of my Hue lamps in roof lamps that are turned on/off with a wall switch, cutting the power. The problem is to make the lamps turn on with a preferred value.
    There is a little discussed property for Hue lamps 'customsetting', that allows to set Hue properties that should be used when the lamp starts up.
    If you flick the switch twice rapidly the light will turn on with default white again. (so you don't accidentals set a very low dom default and then in an emergency you need to turn on the light...)
    On 6/18/2019 at 4:37 PM, jgab said:
    This was difficult. I pushed a new version B12 that fixed it. Fingers crossed.
    @jgab
    any updates on iCal lately that i have missed? ?
    anyway i have problems with it, it say that i have entry on a day that i don't have any in my calendar.
    Cannot upload any proof now because forum gives me an error when i try to upload a picture ?
    Morning,
    here too error while uploading, please contact us>>>done
    why Fibaro is not testing after change something??
    Good morning Jan,
    rule("settings=woonkamer.spotsjaak:values")  how to log the values?
    //Sjakie
    Jan,
    ICAL_version,_fix = "0.9","B12"  -- June 13, 2019
    Perhaps you pushed V13?
    5 hours ago, Sjakie said:
    Good morning Jan,
    //Sjakie
    Jan,
    B12 is the latest. I'm not using it that much myself so I haven't seen any issues.
    It should be possible to run iCal in the HC2 emulator and maybe find the problem that way?
    Otherwise, I will try and add some scens this evening and see if I see anything strange - maybe something is changed in the API?
    Jan,
    Thnaks!!!
    You mentioned to push ICAL?? B12 but my B12 is from June, just to alert you.
    Thanks for the service!!
    //Sjakie
