    5 minutes ago, Sjakie said:
    That it takes 10s to turn off something is a sign that there is something wrong...
    Could it be that the z-wave network is behaving strange due to some device being faulty and spamming?
    One could try to do a turnOff, check if it came through and if not try again.
    Something like
    ...but it's a bit messy and not a sustainable fix.
    How to check or monitor the Zwave network?
    If I switch on/off manual from my laptop all zwave devices responding directly.
    Did you try Z-Wave monitor... I mean it should monitor dead traffic.
    Another tool that I think could help you is All-in-One Scene... just download it and run it without any changes.
    You should see Dead traffic table that shows all NACK/dead traffic.
    Edited by cag014
    Yep, I was about to suggest something like @cag014 z-wave monitor. Haven't used it myself but there should be a thread on it in the forum.
    Installed and running we will see latertoday what pops up.
    Thanks guys
    Hello Jan,
    Is this in ER scenes also a good practice?
    If yes how to write this rule?
    Rule.eval([[#eveninglightOn =>
            zijkant.spotfietsenstalling:on; serre.spotenkel:on; log('TRIGGER:%s',tjson(env.event)); log('spot fietsenstalling en serre spotenkel - aan');
                    log('TRIGGER:%s',tjson(env.event)); log('Evening light on Post flaglightOn - aan')
    1 hour ago, Sjakie said:
    Hello Jan,
    In theory this should be a method to limit zwave traffic. In practice I see limited use for this kind of precautions in turning on/off things at specific moments where in 99% of the case you do want to set the opposite state. Put another way, in ER you tend to write rules that follow the state off the device and seldom apply rules to devices with unknown state.
    For a routine that turns off all lights in a house it could make sense to check before as you will probably turn off many devices that are already off.
    However if you try to turn off a device and it doesn’t turn off it’s another matter...
    anyway, to check before turning on to make sure you don’t turn if already on would look like (id:isOff&id:on)
    Jan,
    Thanks its clear!
    Yeah in some cases the state of the device is clearly of for example in the mornig if I switch light on.
    Indeed if I turn off all lights they will be turned off all independent off they are on or not.
    Specially for the HUE it can help.
    Will review all my scenes
    //Sjakie
    7 minutes ago, Sjakie said:
    Jan,
    Thanks its clear!
    //Sjakie
    Wait a minute. I can easily add that check to ER as I already patch fibaro:call anyway. When I come home this evening I will release a version of ER where you can set a flag if you want fibaro:call to check the value before. It will apply to turnOn/turnOff/setValue.
    Wowww Jan that is very convenience.
    To change  with --55:isOff&55:on is a long time job.
    btw I thought & was only to use on the trigger side?
    Thanksssssssssssss
    //Sjakie
    Thanksssssssssssss
    //Sjakie
    Turned out to be an easy fix (I think). I pushed B69.
    Somewhere in the beginning of main() do
    ... to enable the checks.
    Let me know if there are any issues.
    Hi Jan,
    In all scenes implemented no extra error(s) came up.
    The result is not direct visible for me but perhaps will Cag's Zwave monitor shows good numbers.
    Thank you very much for this outstanding service excellence!!!
    //Sjakie
    Hello Jan,
    What is the syntax for;
    Rule.eval([[trueFor(>00:05, woonkamer.gordijnvoor:value==0) =>
    thanks in advance
    //Sjakie
    15 minutes ago, Sjakie said:
    Hello Jan,
    thanks in advance
    //Sjakie
    This will log when the woonkamer.gordijnvoor:value been 0 for 5 minutes
    (it can't be more than 5min without being passing 5min)
    Or was it something else you wanted to achieve?
    Jan,
    All curtains will be closed.
    If the curtain in the living is closed it can take to max 2 hour if the curtain  back side will be closed when the back door closes.
    I have now this rule:
        Rule.eval([[woonkamer.gordijnvoor:value==0 & eetkamer.gordijnachter:isOpen & once(eetkamer.deur:safe) & sunset-00:30..sunrise-00:30 =>
            1740:start; wait(00:00:20); eetkamer.gordijnachter:close; log('TRIGGER:%s',tjson(env.event)); log('Serre deur dicht gordijnachter - sluiten')
    It works good  when the back door stays open even if curtains house are closed.
    Now you hope fully understand the problem if the back door is already closed as all curtains closes it will start also the message,
    1740:start is to start the announcement curtain back will be closed.
    So I thought if woonkamer.gordijnvoor:value==0 is longer than lets say 5min  closed and ....
    //Sjakie
    14 minutes ago, Sjakie said:
    Jan,
    //Sjakie
    Sorry, it's late so I'm not sure I still understand (and I haven't learned dutch yet to decipher the variable names :-) )
    However, you can get the time since the device changed state with deviceID:last
    So maybe this works?
    Btw, woonkamer.gordijnvoor:value==0. could be woonkamer.gordijnvoor:isClosed
    Sorry Jan,
    Curtain switch
    /monthly_2019_10/image.png.ae26bef22689f41904f68c7acf9aab46.png" />
    //Sjakie
    4 hours ago, Sjakie said:
    Sorry Jan,
    Curtain switch
    //Sjakie
    :isClosed, not :isClose...
    Sorry
