Hey Gap
I have another problem
It worked in ER4-3.fqa version
But in ER4-6.fqa it is an error
Example rule
  rule([[$PresentState=='Home' & officedeskLight:isOn =>
    || 22:00..23:00 >> officedeskLight:color={0,255,0,0}
    || 23:01..00:00 >> officedeskLight:color={0,119,155,0}
    || 00:01..01:00 >> officedeskLight:color={129,70,0,0}
    || 01:01..02:00 >> officedeskLight:color={215,0,255,0}
rule("officemotion:breached & 22:00..02:00 =>  officedeskLight:value=50")
rule("officemotion:breached & 02:10..04:00 =>  officedeskLight:value=20")
rule([[$PresentState=='Home' & trueFor(officetimer,officemotion:safe) & 22:00..04:00 => officedeskLight: value=5]])
rule("@04:00   =>  officedeskLight:off")
 Error
[DEBUG] 05.04.2020 23:22:32: [ERROR] in 'Rule:78[exitlamp:isOn =>...]': {"msg":"Error executing instruction:'["%prop",1,"isOn"]'","src":"Rule:78[exitlamp:isOn =>...]","ERR":true,"err":"EventRunner4.lua:2084: attempt to compare string with number"}
[DEBUG] 05.04.2020 23:22:32: [ERROR] in 'Rule:79[exitlamp:isOn =>...]': {"msg":"Error executing instruction:'["%prop",1,"isOn"]'","src":"Rule:79[exitlamp:isOn =>...]","ERR":true,"err":"EventRunner4.lua:2084: attempt to compare string with number"}
The device is fibaro RGBW
Second rule error
---season
rule([[@{00:00,catch} =>
    || month('dec-jan') >> post(#SEA{value='Winter'}); log('Set GV into %s',$SeasonState)
    || month('apr-may') >>  post(#SEA{value='Spring'}); log('Set GV into %s',$SeasonState)
    || month('jun-sep') >>  post(#SEA{value='Summer'}); log('Set GV into %s',$SeasonState)
    || month('oct-nov') >>  post(#SEA{value='Autumn'}); log('Set GV into %s',$SeasonState)
rule("#SEA{value='$val'} => $SeasonState=val")
error
[ERROR] in 'Rule:1[@{00:00,catch} => $Month = Months[os.date('*t').month];  log('Set GV into %s',$M...]': {"msg":"Error executing instruction:'["%var",0,"Months","script"]'","src":"Rule:1[@{00:00,catch} => $Month = Months[os.date('*t').month];  log('Set GV into %s',$M...]","ERR":true,"err":"EventRunner4.lua:1966: attempt to index global '_ENV' (a nil value)"}
[DEBUG] 05.04.2020 23:21:39: [ERROR] in 'Rule:2[@{00:00,catch} => $WeekDay = weekdays[os.date('*t').wday];  log('Set GV into %s'...]': {"msg":"Error executing instruction:'["%var",0,"weekdays","script"]'","src":"Rule:2[@{00:00,catch} => $WeekDay = weekdays[os.date('*t').wday];  log('Set GV into %s'...]","ERR":true,"err":"EventRunner4.lua:1966: attempt to index global '_ENV' (a nil value)"}
[DEBUG] 05.04.2020 23:21:39: Set GV into Spring
Third rule error
rule("Livingbath_door:safe => wait(00:00:10); post(#livingbathIn)")
rule("#livingbathIn => Livingvent:on ")
rule("Livingbath_door:breached =>wait(00:03); post(#livingbathOut)")
rule("#livingbathOut => Livingvent:off ")
Error
wait (00:00:20) <= not running
4th rule error
rule("rm.Philiocolorbutton2:central.keyId=='1' & ch.KidLight:isOff  =>  ch.KidLight:on")
 rule("rm.Philiocolorbutton2:central.keyId=='1' & ch.KidLight:isOn  =>  ch.KidLight:off")
ch.KidLight:isOn  <= Status value reflection
I need advice
Edited by minsad79
Do you have the next versi
/monthly_2020_04/4.PNG.422ff27c62ac59f1726a51725b69e186.PNG" />on of the quick app?
Hi. jgab
I use 0.1 fix9  version.
rule("button1:central.keyAttribute=='Pressed' => bedroomLight:value=50")
rule which above is not working.
I think set value command is not woking. bedroomLight:on , bedroomLight:off are working properly.
Sorry I did wrong. everything working fine.
Edited by luke-js
Guest kallecux
Hi @jgab!
If i use this rule:
rule("@@00:00:10 => fibaro.call(353,'publish','hc3/dachterrasse/erdfeuchtigkeit',Dachterrasse.Erdfeuchtigkeit:value)")
i get this in the debug console:
[17.04.2020] [18:04:20] [DEBUG] [QUICKAPP284]: [D] fibaro.call(353,"publish","hc3\/dachterrasse\/erdfeuchtigkeit",64.814814814815) => nil
it seems, that there i a conversion, so i can't handle the string i my publish method.
Greetings - Karl Heinz
P.S: I use ER4 Fix7 on HC3 :-)
Edited by kallecux
    On 4/17/2020 at 6:07 PM, kallecux said:
    Hi @jgab!
    If i use this rule:
    Isn't it just the way the log console prints the string with forward dashes in it? If you print the value in the receiving QA 353 does it look normal?
    QAs tend to do some funny conversion of arguments that are strings but look like other datatypes.
    Ex try this:
    The string with forward slashes when logged in the console have \/ (the onAction.. log) but when printed looks normal.
    However, the other values are converted to numbers, booleans, and tables - a bit unexpected...
    Guest kallecux
    Pardon, you are right!
    In QA 353 i get this:
    [22.04.2020] [16:04:04] [DEBUG] [QUICKAPP353]: hc3/dachterrasse/erdfeutigkeit
    [22.04.2020] [16:04:04] [DEBUG] [QUICKAPP353]: 60.3704
    but then QA 353 crashed:
    [22.04.2020] [16:04:04] [DEBUG] [QUICKAPP353]: No matching overload found, candidates: unsigned short publish(Client&,std::string const&,std::string const&) unsigned short publish(Client&,std::string const&,std::string const&,luabind::object)
    [22.04.2020] [16:04:04] [ERROR] [QUICKAPP353]: QuickApp crashed
    [22.04.2020] [16:04:04] [ERROR] [QUICKAPP353]: Unknown error occurred: handleJsonRpc
    Solution: the 2. parameter has to be converted via tostring()
    Edited by kallecux
    I guess publish is the MQTT public command?
    The error you get is because the arguments are wrong to publish - so I would add some code to print the args and their types before you call publish.
    Hi gab
    Rules below
    rule ("rm.Philiocolorbutton2: central.keyId == '1' & ch.KidLight: isOff => ch.KidLight: on")
      rule ("rm.Philiocolorbutton2: central.keyId == '1' & ch.KidLight: isOn => ch.KidLight: off")
    The isOn or isOff rule does not apply
    Are there? Modified version
    P.S: I use ER4 Fix9 on HC3
    Edited by minsad79
    Guest kallecux
    Hi @jgab!
    Are you planning to incorporate MQTT functionality into ER4?
    I had already read something about this in your posts, but the EventRunner4.lua is still in version 0.1 fix7 on the github.
    Best regards
    Karl Heinz
    P.S: ... that was probably a superfluous question, because the integration of fibaro is sufficient ... right?
    Edited by kallecux
    37 minutes ago, kallecux said:
    Hi @jgab!
    Best regards
    Karl Heinz
    Well, I have had some thinking how mqtt could be easier to use from ER rules...
    I have  been busy working the SDK/emulator but its slowly starting to come together so I will turn my attention to ER4.
    Jan,
    I try to add a value or is that not posible?
    Util.defTriggerVar('keuken') -- Define 'keuken' as a trigger variable
    Rule.eval([[@13:06 =>
            keuken = eetkamer.humidity:value
            log('keuken handmatig setA :%s%%',keuken); post(#keukenInfo);
            log('TRIGGER:%s',tjson(env.event))
    What am I doing wrong?
    Thanks in advance,
    //Sjakie
    6 minutes ago, Sjakie said:
    Jan,
    Thanks in advance,
    //Sjakie
     A missing ';' at the end of like
    Jan, sorry should have seen that by myself, error message distracted me.
    Here I  do something wrong too I am recalculate the setting Wind given in Km/h into Beaufort:
    Util.defTriggerVar('Wind') -- Define 'Wind' as a trigger variable
    rule("#keukenInfo => Wind = api.get('/weather').Wind") -- Update 'Wind' every call #keukeninfo
    the error is in the notation ==> or ==< I think
    Rule.eval([[#buitenInfo & Wind == <0.2 => Beaufort = 0; log('TRIGGER:%s',tjson(env.event)); log2('orange','windstil - zee als spiegel')]]
    Rule.eval([[#buitenInfo & Wind == >0.3 & Wind <1.5 => Beaufort = 1; log('TRIGGER:%s',tjson(env.event)); log2('orange','zwakke wind flauw en stil - kleine golfjes') ]]
    Please advice,
    //Sjakie
    Hi jgab
    Is there a way to run the profile in HC3 er?
    Edited by minsad79
    1 minute ago, minsad79 said:
    Hi jgab
    Is there a working version of the profile in HC3 er?
    to set and get current profile? (no not yet, next version)
    8 minutes ago, jgab said:
    현재 프로필을 설정하고 얻으려면? (아직, 다음 버전은 아닙니다)
    I want to set the profile of the image to work
    Home, away?
    Home, away?
    I don't think I understand.
    Do you want to start and stop the QA EventRunner4?
    Do you want to start and stop specific rules in EventRunner4?
    Do you want to activate/deactivate specific profiles from rules in EventRunner4?
    Do you want to activate/deactivate specific profiles from rules in EventRunner4? <===
    For example
    All lights off when leaving home
    I want to create a profile like the one above
    Hello Jan,
    Since months we are using your color scene to change color of our outside lights.
    When I was in Dubai I saw a kind of cascade with water fotain jumping form one spray head to another.
    Can you propose someting simular with HUE?
    lamp1>>red lamp2>>yellow>> lamp3>>blue>>lamp4>>green>>lamp5>>pink>>lamp6>>white>>
    lamp1>>white lamp2>>red>> lamp3>>yellow>>lamp4>>blue>>lamp5>>green>>lamp6>>pink>>
    lamp1>>pink>>lamp2>>white lamp3>>red>> lamp4>>yellow>>lamp5>>blue>>lamp6>>green>>
    lamp1>>green>>lamp2>>pink>>lamp3>>white lamp4>>red>> lamp5>>yellow>>lamp6>>blue>>
    and so one
    I used till now
      -- Every 10s, pick a new value from colorParams, wrap around at end of table.
      colorShow = Rule.eval([[@@00:00:10  =>
           oprit.spotbeeld:value=colorParams[colorIndex];
        colorIndex=(colorIndex % size(colorParams))+1
        ]]).disable()
     colorParams={  -- Table of color values
        {bri=245, hue=45573, sat=231, transitiontime=2, col=337},--blauw
    Thanks in advanced and much obliged.
    //Sjakie
    New version of EventRunner4.
     v0.2 fix1
    There are some changes in the structure of events. The previous version tried to mimic the structure of sourceTriggers on the HC2.
    This version is more like the HC3.
    Ex.
    HC2. {type='property', deviceID=88, propertyName='value', value=1}
    HC3. {type='device', id=88, property='value', value=1}
    These are the events supported currently
    There should be  no difference if you use eventscript syntax.
    However, if you access the fields in the event be aware
    the label() function to access and get triggers from the UI buttons are gone.
    Instead there is a 'UI' event posted when a slider/button is pressed (see list above)
    and there are some new functions to manipulate the QA and profiles
    To trigger on ex. profile change, add a trigger on the event
    Stay tuned...
