    1 hour ago, Sjakie said:
    Jan good morning,
    How to convert a post in time?
    I like to do:
    Rule.eval([[#rise is after sunrise => post(#openCurtain)]])
    Thanks for your time,
    //Sjakie
    Sorry, I don't understand. "convert a post in time"?
    You want your rule to post #openCurtain if the event #rise comes after sunrise? or?
    Jan,
    correct.
    //Sjakie
    4 hours ago, Sjakie said:
    Jan,
    correct.
    //Sjakie
    Rule.eval([[#rise & now > sunrise => post(#openCurtain)]])
    'now' is a pre-defined rule variable that is always the current time.
    Hi @jgab
    I have some crazy ghosts in my EventRunner4 v0.5fix46.
    I am using EV4 and COH.
    I have 4 COH Bulp that wont turn off -
    Pressing a button (on A Matrix) It seems that there are send double "Central Scene Event" with toggle. It starts the Transision - within 1-2 Sec it the reverse back to 100%
    If I remove the the EV4 rule, I dont see the Double Trigger in the logs.
    BUT...
    The most crazy is in the example below, where the rule is taken out . Its still possible to control the HUE from the Matrix button, with turn on, off and DIMM. Like the rule is cached, and if i enable it again it triggered double again.
    It started yesterday i think - i haven't touched any EV4 rule here. I run 4 EV4 at the same time.
    Have you heard about this - Any ideas.
    Quote
    Edited by ChristianSogaard
    P
    12 minutes ago, ChristianSogaard said:
    Hi @jgab
    BUT...
    I'm running a custom version of the Fibaro HC3 firmware 5.062
    Well,the ghost can be  that double instances are running of the ER4 QA. I have seen this myself for the last month but I had issues previously. It's not just a ER4 issue but can happen other QAs too. The only way around it is to remove and reinstall the QA - or restart the HC3. The latter usually helps,
    Thank you for your fast reply. You help is amazing.. Restart helped
    P
    I trying to do a set of rules with following function
    A single switch (I am using Matrix with 4 keys) should have two lifes - A manual and a automatic controlled with PIR.
    --A manual Press on Key 1 will - turn TOGGLE the light at same Matrix and
    -- when Manual Turn on Key 1 the PIR is DISABLED.
    PIR is enabled when light is turned off.
    I tried following rules - in the first rule, the part "garage.Tryk1:manual >= 0 => disable(PIR)" dont seem to work, so i might have misunderstood the syntax for manual. Can manual be used with the Matrix?
    Your Matrix is always operated manually.
    :manual is for devices that can either be turned on/off manually or by a script.
    :manual returns the time since the device changed state caused by something that did not originated from a rule. Typically someone manually flip a switch as opposed to a rule flipping the switch.
    @jgab
    how to switch off this:
    I think I have newest version of ER4:
    E_VERSION,E_FIX = 0.5,"fix46"
    2 minutes ago, petrkl12 said:
    @jgab
    Can you check the file 'Toolbox_triggers' to see if it emits a TICK in the /refreshStates loop there?
    I did remove it some time ago but maybe your Toolbox in ER4 haven't been updated for some reason.
    However, I also used the /refreshStates loop with a 'TICK' in other QAs previous - maybe it's another QA?
    OK, I will verify
    btw.
    this should also update of Toolbox?
    4 minutes ago, petrkl12 said:
    OK, I will verify
    btw.
    Yes it does.
    ok, this is from your old QA for crash notifier
    how to replace that?
    Something like above - however the whole QA would need a refresh...
    Good morning Jan,
    This ist giving the value?
    < Rule.eval([[eetKamer.gordijnAchter:isClosed =>
            myLog('eetKamer.gordijnAchter %s %%',eetKamer.gordijnAchter:value); log('gordijn achter gesloten')
    What I am doing wrong?
    //Sjakie
    Jan, this started suddenly?
    ChildrenofHue version 1.16
    FIbaro fw 5.063.30
    Please advice,
    //Sjakie
    "FibaroapiHC3.lua / ver 0.198" does not work in ZBS.
    /monthly_2021_03/image.png.60de6c8776a772cf47c0b2488acbd70c.png" />
    You must set compiler to 5.3
    Can I see how to do it?
    ZBS Menu->Project->Lua Interpreter->Lua 5.3
