this is getting frustrating ?? I just can not make it work lol
finally gave up using the id of the user and put all the devices as id's and old version works again ?
cheers:)
Edited by Momos
@jgab need some help pls :)
log is:
[21.04.2021] [11:19:33] [DEBUG] [QUICKAPP1149]: [{"keyId":1,"keyAttribute":"HeldDown"}]>>'Rule:19[WalliController:central => ...]'
[21.04.2021] [11:19:35] [DEBUG] [QUICKAPP1149]: [{"keyId":1,"keyAttribute":"Released"}]>>'Rule:19[WalliController:central => ...]'
[21.04.2021] [11:19:41] [DEBUG] [QUICKAPP1149]: [{"keyId":1,"keyAttribute":"Pressed2"}]>>'Rule:19[WalliController:central => ...]'
[21.04.2021] [11:19:43] [DEBUG] [QUICKAPP1149]: [{"keyId":2,"keyAttribute":"Pressed2"}]>>'Rule:19[WalliController:central => ...]'
[21.04.2021] [11:19:46] [DEBUG] [QUICKAPP1149]: [{"keyId":2,"keyAttribute":"Pressed"}]>>'Rule:19[WalliController:central => ...]'
What am i doing wrong ?
And second problem:
rule("@@01:00 => log(osdate('Uptime %H:%M',api.get('/settings/info/').serverStatus))")
Always reports
[21.04.2021] [11:19:17] [TRACE] [QUICKAPP1149]: Uptime 22:44
same 22:44 everytime.
Thank you :)
Edited by Momos
    log is:
    And second problem:
    Always reports
    Thank you :)
    Sorry, a bug had snucked into the ++ (and ===) operators.
    Your code is correct, the error was on my side.
    I have fixed. it now and pushed 0.5,"fix49"
    Thank you :)  however my ER4 just does not want to update to fix 49. Checks for new version and thats it.
    Jan, the same here no auto update fix 49 (from fix 48)
    I changed the time and no update.
    //Sjakie
    //Sjakie
    If you do an update/restart now? (forgot to bump the version number)
    Jan, omg you are human!!! :)
    Yep the QA is updated fix 49 >>>Thanks.
    Perhaps you overlooked please can you convert this I do not get it working!!! I
    Thanks,
    //Sjakie
    Thanks,
    //Sjakie
    rule("@now+00:00:03 => http.get('http://192.168.1.24/MainZone/index.put.asp?cmd0=PutMasterVolumeSet/150')")
    Thank you:)  CentralScene working now ! I have to say this is the cleanest way of handling CentralScene i have seen so far ?
    Why is
    Always reporting
    [21.04.2021] [11:19:17] [TRACE] [QUICKAPP1149]: Uptime 22:44  ?
    Why is
    Always reporting
    It turns out that .serverStatus is epoch when the box booted up.
    The uptime is then
    ostime()-api.get('/settings/info/').serverStatus
    Then the problem is how to present this. The diff is not epoch and os.date will wrap on. 24hours.
    You could present hours easily
    rule("@@01:00 => log('Uptime %0.0f hours',(ostime()-api.get('/settings/info/').serverStatus))/60)")
    nice:)
    rule("@@01:00 => log('Uptime %0.0f hours',((ostime()-api.get('/settings/info/').serverStatus))/60)")  works. Was one more paranthesis that needed to be added.
    Cheers :)
    Is it so simple? I did httpGet Idid not have any example.
    This is WAF!!!
    Thanks Jan,
    //Sjakie
    Jan ,
    i have  a situation -  as i dig more and more into ER4 i have more situations...
    Simple rule :
    rule("LightSensorBirou:lux < 20 & PIRFibaroBirou:breached  => PlafonieraBirou:on & ScafaBirou:on ")
    What it should do: should check if LUX is under 20 and motion sensor breached - then if both true turn on two lights.
    And it does that very well.  Too well in fact, as it does much more ?
    I'm in the room, lights are on. I want to leave the room so i walk to the door, close the lights from the switch on the wall and leave.  Lights turn off of course but after 3-5 seconds they turn back on ?.  I close them again, 3-5 seconds later they turn back on. - last night at about 3 AM when i noticed this i tried to turn them off about 5 times, even sneaking my hand through the doorway but they still came back on.  I was waay to tired so i gave up and went to sleep and left those light on. They won that battle ?
    I guess this has to do with the fact that the fibaro motion sensor stays in the breached state for a few seconds, so as i go out and turn off the lights, LUX drops - the sensor is still in breached state so lights turn back on.
    Now the question is: how can adjust that rule to prevent this from happening please ?
    Thank you !
    9 minutes ago, Momos said:
    Jan ,
    Simple rule :
    Thank you !
    Simplest is probably
    rule("PIRFibaroBirou:breached  => LightSensorBirou:lux < 20 & PlafonieraBirou:on & ScafaBirou:on ")
    but then the LUX conditon is never taken into account.  And lights will trigger dissregarding the lux level
    Yes, it will always trigger on motion, but the actions (right of =>) are combined with AND (&) and will only evaluate expression as long as it is true.
    If ightSensorBirou:lux < 20 is false it will not evaluate the rest.
    It's a short way of writing
    rule("PIRFibaroBirou:breached  => if ightSensorBirou:lux < 20 then PlafonieraBirou:on; ScafaBirou:on end")
    which you can also do as it supports if-then-else statements in the body (actions)
    very nice :)
    Good morning Jan,
    With this rule I can see the uptime of my HC3 604 Hours
    I have created back up yesterday 23-04-2021 at 21:44
    But it does not tell me the uptime after creating a backup.>>> this is not consequent because I did now a backup and the uptime is now 4 hours???? Can you explain this deviation?
    Thanks in advance,
    //Sjakie
    Jan, I have some errors who I can not resolve.
    This error does not point to the rule but I asume its the first rule after log('Douche........
    1)
    HomeTable   doucheRuimte = {deur=836
    Rule:
    Any guidance is appriciated,
    //Sjakie
    1)
    Rule:
    //Sjakie
    If the error occurs when a rule run you will get the rule.
    I think that you are using doucheRuimte.deur in your main() in some non-rule code (without '=>')
    ...and doucheRuimte is not set so it complains about the nil table.
    Maybe you have forgot
    or you use doucheRuimte.deur before you define it.
    That's why you get the "main() error:" message
