    7 minutes ago, Sjakie said:
    Jan delayed update??
    07:47 fix 54
    Thanks for the support!
    //Sjakie
    Your HC3 has a mind of its own - 7min delay to update is very strange.
    25 minutes ago, Sjakie said:
    Jan, 1-3-4-5 are armed and all others disarmed
    So in first Rule no debug is okay because 4 is armed
    In that light 2nd rule should not give log too because 3 is armed!
    This is not consequent??
    3rd is okay because all are armed.
    Or do I miss something?
    //Sjakie
    sorry not mentioned 2-6-7-11 disarmed
    Are you sure? In your example you said that 1-2-3-4-5 was armed.
    Jan
    Thanks for mentioning that my HC3 has his own mind.
    So now I dont need to worry about all the strange things happening.
    The other QA's where updating alsmost directly, perhaps this QA's update was in the cue because high traffic?
    //Sjakie
    Jan sorry
    1,3,4,5 are armed
    2,6,7,11 disarmed
    //Sjakie
    32 minutes ago, Sjakie said:
    Jan sorry
    1,3,4,5 are armed
    2,6,7,11 disarmed
    //Sjakie
    If the above is the rule.
    First, no log, 4 is armed.
    Second,  no log, 3 is armed
    Third, {2,6,7,11}:alarm=false can't be used in header  Use :disarmed.
    Note, '=' is always a command (setting something) and can't be used left of the '=>'
    To compare use '=='
    Sorry Jan,
    I was playing
    Now I get no trigger in header>>> was typo ::
    Jan you did it I have now  ONE message!!!!!!!!!
    Jan,
    HC2
    Whats the working cmd for    httpGet('http://api.
    error no such cmd httpGet/httpget
    Is there also another way to do a push with filled in text? or only the text created in Pushmsg?
    Thanks in advance,
    //Sjakie
    sorry  for the picture
    @jgab
    I have got a problem after a fix update.
    A couple of days ago, a rule stopped working, the one that dims the bedroom lamp.
    I suspect a small bug has crept into ER. Rule and error message as below.
    Rule
    rule("@{catch,22:10} => sovrum.dim_lampa:dim={600,'down'}") -- Time to sleep
    Error message when i test the rule
    [2021-05-19] [15:32:00] [DEBUG] [QUICKAPP20]: [true]>>'Rule:42[@{catch,15:32} => sovrum.dim_lampa:dim={600,'down'}]'
    [2021-05-19] [15:32:00] [ERROR] [QUICKAPP20]: in Rule:42[@{catch,15:32} => sovrum.dim_lampa:dim={600,'down'}]: {"ERR":true,"err":".\/include\/Toolbox.lua:219: \/usr\/share\/lua\/5.3\/json\/encode.lua:88: Failed to encode value, encoders for function deny encoding","msg":"Error executing instruction:'[\"%setprop\",2,false,[\"dim\"]]'","src":"Rule:42[@{catch,15:32} => sovrum.dim_lampa:dim={600,'down'}]"}
    An error message about HTTP call sometimes pops up. I have no rules with HTTP calls, so I do not know what is causing the error.
    [2021-05-19] [15:31:10] [ERROR] [QUICKAPP20]: No response from HTTP call
    I created these EV4 rules - the idea is from a friend of mine - Luise.
    Its a toothbrush timer for the bathroom, based on Matrix switch  - so you change the light every 30 sec to indicate next row of ? your mouth.
    If Badevarelset.Matrix is equal 1000, then Badevarelset.Tryk1 is +2 equal 1002, and  Badevarelset.Tryk2 is +4 and  Badevarelset.Tryk3 is +6 and  Badevarelset.Tryk6 is +6
    Just wondering if there intelligent way to optimize this code ?
    14 hours ago, RH_Dreambox said:
    @jgab
    Rule
    Thanks, that was a bug. Fixed in fix55
    Well, I think it's pretty clear code - you will understand what's going on when you look at the code a couple of months from now. Optimizing it will make it harder to understand - and the performance will be the same.
    Jan, I get error but no discription
    the rule is
    Whats wrong?
    //Sjakie
    Error disapered after restart.
    Jan, HC2
    BeveiligenAanw >>>in header and GV created
    J
    /monthly_2021_05/afbeelding.png.58a66a0fad958d092e5df1120c72c62f.png" />an HC2:
    Please advice,
    //Sjakie
    the rule is
    Whats wrong?
    //Sjakie
    If I test the same rule I get no errors. Which indicates that some of your HT values must be strange.
    Jan, HC2
    J
    an HC2:
    Please advice,
    //Sjakie
    This doesn't make sense. Do you have another rule that starts with
    $BeveiligenAanw=='Uit' ...
    It must be a rule that uses '/' division?
    Do you have any rule that involves division?
    @jgab
    this happend during ER4 autoupdate :) Where is ER4 engine :)
    I think autoupdate procedure should be rewritten and check if all components are OK
    1 minute ago, petrkl12 said:
    @jgab
    ER Engine is  the file EventRunner
    sorry, OK
    but ER4 didn't start and I don't know why ...
    any debug messages
    Edited by petrkl12
    2 minutes ago, petrkl12 said:
    sorry, OK
    Do you get any log/error messages?
    My own ER4 just updated to fix56 this morning without problem.
    4 minutes ago, petrkl12 said:
    sorry, OK
    any debug messages
    If you add a blank and re-save?
    any errors nor debug messages ... as you can see in my previous post
    You may also be a victim of this "QA stops working" syndrome. Seen it a few times with different QAs.
    Sometimes it works by restarting the HC3.
    It may also work by downloading the QA (save to .fqa) delete the QA on the HC3 and re-install the saved QA.
    just re-saved source code helped ...
    ER4 is my basic automatization sw :) so I will have to think how to detect and restart it from other QA
