Jan, wierd yesterday I saw the error for first time, HC3 was one month without error.
No problem strange things are happening.
//Sjakie
Jan, no triggers found in header
This log generates multiple messages: (just copied only two there is no difference in which partition is armed
What am I doing wrong?
Thanks for your support,
//Sjakie
    //Sjakie
    1.You need to run fix53 - do you do that?
    Then you must define the variables partition1....partition11 before the rule.
    2. Yes, {1,2,3}:armed will be true 3 times if they are activated the same time. It's a bit tricky to code around but I'm working on it. At the moment a work-around is to wrap it in once()
    Jan, I am on fix 53
    Let me try once(
    Thanks for your speedy respons,
    //Sjakie
    44 minutes ago, Sjakie said:
    Jan, I am on fix 53
    Let me try once(
    //Sjakie
    Oh, I forgot.
    {...}:armed is true if at least one is armed
    {...}:allArmed is true if all are armed
    {...}:disarmed is true if all are disarmed
    {...}:anyDisarmed is true if at least one is disarmed
    Jan, np I get error no triggers
    //Sjakie
    //Sjakie
    This should work, I see that you miss a ':' in your example
    Jan, excellent!!!
    Its almost perfect I have one "small" problem
    Jan in case 3 and 4 are armed I will recieve 3 times a msg.
    OK I can skip Rule 3 than I have still two messages and my goal is if armed just one message
    Is it possible?
    BUT in first rule 4 is NOT disarmed
    Please shine some light in this dark message
    //Sjakie
    8 hours ago, Darren_Teh said:
    Hmm Im using Broadlink with HC2. Haven't tested out HC3. I too having few flow in NR create http command node. Then I use VD in HC2 to sent the http command to trigger the Home Assistant to sent signal from Broadlink..
    1 hour ago, Sjakie said:
    Jan, excellent!!!
    Is it possible?
    //Sjakie
    Hi Jan @jgab
    4/5 EV4 is crashing - 1103 seems to be running (53) rest is 51 and will not auto update and is crashing. what is best way to fix?
    Actually it seems in a limbo between  53 and 51
    Edited by ChristianSogaard
    4 minutes ago, ChristianSogaard said:
    Hi Jan @jgab
    It's most likely the EventRunner file in the QA that is the problem.
    Cut and paste the text from fix53 EventRunner file into the other ER4s.
    will try - but the Screenshots with GUI at 51 and text with 53 was from same EV4
    That worked - but my log is now filled with Posting - is that possible to disable ?
    [17.05.2021] [19:36:37] [TRACE] [QUICKAPP1102]: Posting {"type":"INTERV0x2018cc00","_sh":true} at [Timer:19:36:37]
    [17.05.2021] [19:36:37] [TRACE] [QUICKAPP1102]: Posting {"type":"INTERV0x201c6210","_sh":true} at [Timer:19:36:37]
    [17.05.2021] [19:36:38] [TRACE] [QUICKAPP1102]: Posting {"type":"INTERV0x2018cc00","_sh":true} at [Timer:19:36:38]
    [17.05.2021] [19:36:38] [TRACE] [QUICKAPP1102]: Posting {"type":"INTERV0x201c6210","_sh":true} at [Timer:19:36:38]
    [17.05.2021] [19:36:39] [TRACE] [QUICKAPP1102]: Posting {"type":"INTERV0x2018cc00","_sh":true} at [Timer:19:36:39]
    [17.05.2021] [19:36:39] [TRACE] [QUICKAPP1102]: Posting {"type":"INTERV0x201c6210","_sh":true} at [Timer:19:36:39]
    [17.05.2021] [19:36:40] [TRACE] [QUICKAPP1102]: Posting {"type":"INTERV0x2018cc00","_sh":true} at [Timer:19:36:40]
    [17.05.2021] [19:36:40] [TRACE] [QUICKAPP1102]: Posting {"type":"INTERV0x201c6210","_sh":true} at [Timer:19:36:40]
    [17.05.2021] [19:36:41] [TRACE] [QUICKAPP1102]: Posting {"type":"INTERV0x2018cc00","_sh":true} at [Timer:19:36:41]
    [17.05.2021] [19:36:41] [TRACE] [QUICKAPP1102]: Posting {"type":"INTERV0x201c6210","_sh":true} at [Timer:19:36:41]
    In the beginning of the main file there is a line
    change to
    12 hours ago, Sjakie said:
    Jan, excellent!!!
    Is it possible?
    //Sjakie
    Try fix54, it has improved...
    Hello.
    Is it an important issue?(ER4 v0.5 fix54 &  fibaroapiHC3.lua v0.305)
    Or is there a way I can fix it?
    The writing part of the rule is as follows.
    Edited by Earybeongbeong7
    32 minutes ago, Earybeongbeong7 said:
    Hello.
    run
    once, and it will download the device templates from my gitHub
    Jan, something not right?
    1-2-3-4-5 are all armed
    First rule NO log
    Second should give No log either?
    same result
    //Sjakie
    First rule NO log
    same result
    //Sjakie
    {1,3,5}:allArmed) true if all are armed = true
    {2,4,6,7,11}:disarmed if all are disarmed = false, i.e. no log
    If you wan to test if any is disarmed you use
    {2,4,6,7,11}:anyDisarmed
    It's similar with
    {...}:on.        -- any light is on
    {...}:allOn     -- all lights are on
    {...}:off        -- all lights are off
    {...}:anyOff -- any light is off
    The idea is that if any light is on in a room, the room is light.
    For a room to be dark (:off), all lights. have to be off.
    The same thinking for alarms. If any alarm is armed, something is armed
    For the alarms to be disarmed, all alarms need to be disarmed.
    Jan, 1-3-4-5 are armed and all others disarmed
    So in first Rule no debug is okay because 4 is armed
    In that light 2nd rule should not give log too because 3 is armed!
    This is not consequent??
    3rd is okay because all are armed.
    Or do I miss something?
    //Sjakie
    sorry not mentioned 2-6-7-11 disarmed
    Jan 2QA's do not want to update?
    [18.05.2021] [07:40:00] [DEBUG] [QUICKAPP1307]: [true]>>'Rule:3[@{catch,07:40} => Util.checkForUpdates()]'
    Rule uodate has ran,
    stays on fix 53
    //Sjakie
    Jan delayed update??
    07:47 fix 54
    Thanks for the support!
    //Sjakie
