Jan,
doucheRuimte.deur is a device.
The error is a wrong name in deftrigger I saw now, corrected and error not showing anymore.
Thanks,
//Sjakie
I want to generate two variables for status for my extractor hood.
One for Step 0-4 and one for light on/off
So I tried this..
I see triggers like this.
but i dont see the log post ? and i dont see the [true]>>'Rule:15....
is this wrong?
    So I tried this..
    is this wrong?
    It works well, but is missing the parenthesis for the log function.
    However, it should throw an error message - I will fix that in the next version.
    Im unfortunately using IFTTT to call a two scenes when my extractor hood is turn on/off.
    If there a way to pass the  IFTTT triggers into EV4? - or do i need to use the scenes to trigger into EV4?
    As I understand it (I can be wrong) so can IFTTT only start scenes on the HC3?
    In that case you need to call the ER4 QA from the scene.
    ex. fibaro.call(ER4_ID,"whatever",...)
    Is it possible to send data to an Influx database from ER4?
    I want to log the status of a certain switch by sending a "1" to Influx if the switch is on (true), and a "0" if the status is off (false).
    host = "192.168.1.99"
    port = "8086"
    dbName = "HC3"
    dbTag = "status"
    deviceID
    deviceName
    value (number 0 or 1)
    Is it possible (easy) to do this via a rule in ER4, and if so, how?
    port = "8086"
    dbName = "HC3"
    dbTag = "status"
    deviceID
    deviceName
    How does the request/url look like?
    Quote
    I have borrowed and edited some code from this post:
    Hope that's what you're asking for.
    Well, you can easily call Lua functions from ER rules.
    Assume that you have a working Lua function
    You can write rules like this
    rule("lamp:value => saveToInflux('Light', lamp:value, lamp, lamp:name, ostime())")
    and it will trigger every time lamp changes value property.
    lamp:value is boolean if a switch and an integer if it's a dimmer etc.
    lamp:name is the device name. ostime() is the time in epoch.
    I have the latest fix and this morning noting worked in the house  i get this in the  debug  i have done noting att all for a month in fibaro ..
    i have restart´the hc3 4 times
    [2021-05-05] [19:03:31] [ERROR] [QUICKAPP61]: Error in '{Badsensor,Duschsensor}:breached =>
                 || Badlux:value < 39 & 06:00..10:00 >> log('Badrums lampan tänd %80 ');Badrumslampa:value=80; -- lampan 80%
                 || Badlux:value < 20 & 10:00..16:00 >> log('Badrums lampan tänd %50 ');Badrumslampa:value=50;  -- lampan 50%
                 || Badlux:value < 36 & 16:00..21:00 >> log('Badrums lampan tänd %60 ');Badrumslampa:value=80;  -- lampan 60%
                 || Badlux:value < 35 & 21:00..23:00 >> log('Badrums lampan tänd %80 ');Badrumslampa:value=80;  -- lampan 80%
                 || Badlux:value < 10 & 23:00..06:00 >> log('Badrums lampan tänd %30 ');Badrumslampa:value=30;  -- lampan 30%
                 || 81:breached >> log("Badrums Sensor Main är aktiverad!");
                 || 86:breached >> log("Badrums Sensor Dusch aktiverad");
                 ': ./include/EventRunner.lua:1277: Parser error char 143 (';') in expression '{Badsensor,Duschsensor}:breached =>
                 ' (./include/EventRunner.lua:1071: Bad expression)
    [2021-05-05] [19:03:31] [ERROR] [QUICKAPP61]: main() error:./include/EventRunner.lua:2250: Main() ERROR:./include/EventRunner.lua:2094: ./include/EventRunner.lua:1277: Parser error char 143 (';') in expression '{Badsensor,Duschsensor}:breached => || Badlux:value < 39 & 06:00..10:00 >> log('Badrums lampan tänd %80 ');Badrumslampa:value=80; -- lampan 80% || Badlux:value < 20 & 10:00..16:00 >> log('Badrums lampan tänd %50 ');Badrumslampa:value=50; -- lampan 50% || Badlux:value < 36 & 16:00..21:00 >> log('Badrums lampan tänd %60 ');Badrumslampa:value=80; -- lampan 60% || Badlux:value < 35 & 21:00..23:00 >> log('Badrums lampan tänd %80 ');Badrumslampa:value=80; -- lampan 80% || Badlux:value < 10 & 23:00..06:00 >> log('Badrums lampan tänd %30 ');Badrumslampa:value=30; -- lampan 30% || 81:breached >> log("Badrums Sensor Main är aktiverad!"); || 86:breached >> log("Badrums Sensor Dusch aktiverad"); ' (./include/EventRunner.lua:1071: Bad expression)
    hi @jgab
    i have 3 EV4 QA not working today - and not showing version number. Rest i working and showing . EventRunner4 v0.5fix50. I tried rebooting . but that didnt help. I didnt change anything . but i'm using the Event runner autoupdate
    Edited by ChristianSogaard
    P
    Ok, I reverted it to v49 and call it v51, so it should work.
    its working now for me :)
    It's really strange as it works ok for me and my tests.
    @systemfel, can you send me the rule that crashes for you?
                 || Badlux:value < 39 & 06:00..10:00...
    yes  i have sent ju a mess
    Next version I will implement a beta version model.... and it should be possible to revert a beta to the previous version.
    Jan, all (7) my QA's run fix 50 without any problem. :)
    //Sjakie
    15 minutes ago, systemfel said:
    Hi Jan - the same that worked before is now 51 - but the ones, not working before is still not working
    //Sjakie
    Yes, the issue was that my parser was too strict and considered a semicolon at the end of a || >> ...;
    to be an error. (It is unnecessary)
    Yes, that was what I did. I took 49 and called it 51 so you could "upgrade" to a functioning version.
