Yes but my feeling is that somehow Fibaro cloud is causing these issues from time to time, they are not local.  I have no idea if thats even possible, it is just a hunch.
I set up rule that send me email every time Event runner 4 QA is starting and I got email every hour at 28 minute. Then i add another "clean" EV4 QA, to be sure that restart is not caused by my bad written rule, but another one QA do the same. Is anybody else having this problem, or i have to reset whole HC?
Mine does not do that. I am on version Fix67.
First i would check if there is any rule that triggers the restart. Disable all the rules and see if it still does that.  Then reboot if it still does.
Now, thinking about it, is there a way to turn off/on all the rules in a QA of ER4 ?
There are those 4 buttons which to be honest i never looked at what they do ?
/monthly_2021_07/image.png.efef2a37df9fc7872048b388d985cb50.png" />
Trigger : displays all triggers
Post: does not seem to do anything .  What is it supposed to do ?
Rule: not sure what it does also as no matter if i set it on ON or OFF rules still work :)  Seems to be about displaying all (true or false) or only true.
Restart: does a restart.
So excuse my noobish question, what are POST and RULE supposed to do ?
Cheers :)
Edited by Momos
Fellow ER 4 users.
Fibaro showed me yesterday evening  in the cloud a red sign! I did not pay attention on it because you mention it it can be.
I dont know but as long as HC3 is on (on-off line it doest matter) QA's are running.
ER4 is much better than Fibaro so its easy error>>Fibaro.
If you write much worse rules as me than you will see after restart an error in debug, mostly.
I use to get info about restarting  QA's:
At this moment I prefere Telegram option because its always functioning, push messages not.
//Sjakie
    Cheers :)
    It's old code that toggle the debugflags
    _debugFlags.trigger = true -- log incoming triggers
    _debugFlags.post = true    -- log internal posts
    _debugFlags.rule=true      -- log rules being invoked (true or false)
    Jan,
    We where a few days away from home.
    The first evening our complex disarmed because somebody at home according IOS. Wierd me,(user and admin) and my wife left physically.
    Now we are back home and I see that my wife is still away. So I modified the rule that also her device will be in log if location change.
    //Sjakie
    Ah that one about internal post i did not figure . ?
    But stil, is there a clean way of turning off all the rules in a QA ?  Example: i have an AC QA - thats all it does, control some AC units.  But when i leave home for 2-3 days i would like to just turn off the rules in the QA so AC doesnt start for nothing. Now i go into edit mode and commebt each rule ?
    Possible ?
    @Momos use atHome with rules or away with rules.
    //Sjakie
    Possible ?
    Well, you can disable the QA in the WebUI but of course that may be too "manual" and there is no way the QA can enable itself... However, another QA could enable/disable the QA.
    Another approach is that you can enable/disable individual rules
    Ex.
    The rule function returns a reference to the rule that can be used as an argument to enable() and disable()
    The reference also has functions for enable/disable/print/start that we can use directly
    So enable(ref) is just a function that calls .disable() on the ref.
    The advantage with enable(ref) is that it can also take a list of rule references.
    If we declare our rules inside a list we can use that list to enable and disable sets of rules
    We start the rules disabled by calling .disable() on the ref we get back from rule(...).
    .disable() returns the ref again so we can chain the commands. Try rule("@@00:00:02 => log('Ding')").disable().print()  ....
    We can also create sections of rules
    This looks cleaner than collecting them in a list. You can create multiple sections and enable/disable them individually.
    Jan,
    Normal this rule will post restart +00:00:05 or 8 second
    why it also starts 5 & 8 sec after midnight?
    //Sjakie
    38 minutes ago, Sjakie said:
    Jan,
    //Sjakie
    I see a Rule:2 that starts 5s after midnight and a Rule:23 that starts 8s after midnight.
    'now' is always the current time. All @rules recalculate their time for the coming day at midnight so it will be 0+5 and 0+8, because 'now' is 0 at midnight.
    If you only want it to run at start/restart don't make it a rule (no =>)
    On 7/13/2021 at 7:18 AM, jgab said:
    Not sure what you want. Fibaro globals are accessible with the name prefixed by '$'
    ex.
    Hi jan,
    please can you check if creating global variable works fine? if i create global variable manually then it is accessible in ER4 by '$', but when i want to create some it do nothing.
    $MyVar is always nil.
    I updated to new HC3 version (5.072.14 (beta)) and ER4 don't restart anymore.
    4 hours ago, kubo said:
    Hi jan,
    Fibaro globals always need to be created manually before used. They will not be autocreated.
    Btw, there are some ER functions to deal with Fibaro globals
    quickAppVariables ($$) are autocreated as that is the way fibaro.setVariable work
    Problem with v0.5fix68 that's been out for an hour. If you upgraded it will crash. I have fixed it now so upgrades should work again.
    If the QA crash go into the QA files and the file "Toolbox" and line 694 and change
    to
    Ok, v0.5fix68 should work now.
    There has been a long time "bug" that disabled some error checks in ER4, and they are enabled now.
    Be prepared that you may see more error logs.
    In particular it's setTimeout/setInterval/net.HTTPClient that will report an error if the callbacks/functions provided throws an error.
    On the HC3 this is normally silent but it will show up now.
    In the emulator these errors has always been reported.
    Hi @jgab
    any idea why my alarm started failing? i didnt change anything for months in this section?
    5 hours ago, ChristianSogaard said:
    Hi @jgab
    This expression is strange
    post(#Armed from Matrix as Keypad);
    It's not a valid event name - spaces not allowed.
    Either
    post(#Armed_from_Matrix_as_Keypad);
    or
    post(#ArmedFromMatrixAsKeypad);
    or did you mean
    post(#Armed); -- from Matrix as Keypad
    or did you mean
    log('#Armed from Matrix as Keypad');
    Jan I have thsi error:
    Please advice,
    //Sjakie
    Please advice,
    //Sjakie
    Can you post the whole rule20?
