Jan,
I have some problems wit internet connection or provider or my router
This didt work last night when we lost internetconnection something wrong?
The rule @07:24 didt report in debug
Thanks in advance,
//Sjakie
Jan,
I still have growing memory!
-is it possible that ER can do a backup and 5 min later a restore?
-ER can delete history with API but I dont know how
PLease make the rule for me.
Thanks,
//Sjakie
    This will not work
    because if you trigger on time (@07:24) you can't trigger on an event (#onlineEvent).
    Jan ok that rule was for me to see this morning is it working, now I understand it is not.
    But in debug there was no info at the time the internet connection was missing according Fibaro email at 2:27
    So there is something not good?
    //Sjakie
    Jan,
    stekkersVertraagdOff= wcdDelayedOff (plug)
    If we leave home there will be a delayed post (if the wassing is busy he can finish the program)
    How I can kill this delayed post if we return before the 02:15 is passed?
    If we come after the post is triggered it will be switched on by out pre
    Thanks in advance,
    //Sjakie
    27 minutes ago, Sjakie said:
    Jan,
    Thanks in advance,
    //Sjakie
    Hi again :)
    How is the function fibaro.callUI(1101,  'onReleased', 'button1') implemented please ?  (function taken from converting a block scene to LUA)
    I am trying to press the buttons on a QA from ER4 rules.  The id:btn=1 does nothing and i could not find how to do it :(
    Thank you  :)
    1 hour ago, Momos said:
    Hi again :)
    Thank you  :)
    fibaro.callUI seems to be a new function only available in scenes.
    Must be based on /plugins/callUIEvent.
    I thought the idea was to call QuickApp actions but I guess it's not compatible with old plugins
    Here is a version you can add to the QuickApp.
    You can then do
    Thank you @jgab.  Added one more ")" at the end and its working :)
    Is there any cleaner way to press a button from another QA ?
    Thanks Jan!
    Usually a button is tied to a (user) defined QuickApp function. and that function can be called with fibaro.call(QAid,<name>). However I guess that may not be supported by older plugins.
    Jan, what I am doing wrong?
    This rule is executed its out of the time frame?
    Please advice
    //Sjakie
    19.00..23:00 is interpreted as 00:00:19..23:00 (19s over midnight to 23:00)
    At least one of your openVan* was true too.
    Ok I see my stupid mistake.
    openVan I doubt according app door last change yesterday.
    I will solve different I will add 21:disarmed too so it will be more relayable
    Thanks Jan,
    //Sjakie
    Error post
    Edited by ChristianSogaard
    P
    Hi @jgab
    My Eventrunner4 QA starts crashing - the old ones seems to run, but the new fails.
    I tried everything - and as soon i ad just one line(that used to word) it crash.
    Right now i have around 80 rules that stopped working, and I have no ide.
    I could really use some assistance.
    /monthly_2021_09/2021-09-18_15-21-51.png.6928e996b0a677a911d7d29147daf91c.png" />
    Check your line 66 and 68 wrong character
    //Sjakie
    //Sjakie
    dosent seems to work for me - but thank you @Sjakie
    What is different with the old one?
    //Sjakie
    //Sjakie
    Its strange what happend - but i follow you now
    What about this? This also used to work . but now i got tokenizer failed at  & keyPrim
    i looks like that central.keyId is not working anymore
    matrix4Alarm = 439 -- Device for (Dis)arming the alarm
    rule([[matrix4Alarm:central & keyPrim =>
         post({type=fmt('%s_%s_%s',keyPrim,matrix4Alarm:central.keyId,matrix4Alarm:central.keyAttribute)});
         keyPrim=nil
    P
