55 minutes ago, ChristianSogaard said:
Its strange what happend - but i follow you now
What about this? This also used to work . but now i got tokenizer failed at  & keyPrim
i looks like that central.keyId is not working anymore
matrix4Alarm = 439 -- Device for (Dis)arming the alarm
rule([[matrix4Alarm:central & keyPrim =>
     post({type=fmt('%s_%s_%s',keyPrim,matrix4Alarm:central.keyId,matrix4Alarm:central.keyAttribute)});
     keyPrim=nil
Error in 'matrix4Alarm:central & keyPrim =>      post({type=fmt('%s_%s_%s',keyPrim,matrix4Alarm:central.keyId,matrix4Alarm:central.keyAttribute)});       keyPrim=nil ': ./include/EventRunner.lua:1649: attempt to index a nil value (local 'e')
Something has for sure changed in EV4 ? -
central is not working anymore - seems to be replaced with centralSceneEvent.
Setting variable keyPrim=nil  seems to not work anymore
    19 hours ago, Sjakie said:
    Check your line 66 and 68 wrong character
    //Sjakie
    Yes, @Sjakie is on to something here.
    You have inserted unicode characters in your file - probably using some editor with unicode and cut&paste to the HC3 editor.
    The dreaded error
    says that it sees the character 194 (that is the first byte of a 2 byte unicode character) and it's not allowed and the QA crashes. It crashes as soon as the HC3 tries to load the QA code.
    If I run this short lua program that fetches your QA (570) and searches the code for 194 (0xC2)
    I get a lot of 194,160 unicode combos in the code. It's not a problem in  comment or strings but in code it will make the Lua crash.
    Thank you Jan
    But what about this ? - this is not character 194
    [19.09.2021] [11:34:25] [DEBUG] [QUICKAPP1268]: tokenizer failed at  =>   || 1:alarm.armed >> 1:alarm=false; log('disarming 1'); log('#Disarmed from Matrix as Keypad');  || !1:alarm.armed >> 1:alarm=true; log('arming 1'); log('#Armed from Matrix as Keypad');
    [19.09.2021] [11:34:25] [DEBUG] [QUICKAPP1268]: #Key439_2_Pressed3_4_Pressed2 =>
     = {"type":"Key439_2_Pressed3_4_Pressed2"}
    If 194 has sneaked into a string it may not match the string you expect.
    If I run this program that patches all "Non-breaking spaces" \xC2\xA0 to regular spaces in your QA, the QA loads.
    not like this? - you mean in zerobrane studio?
    Jan ... you are the man ?. I truly dont know what I should do without your assistance ?
     well i second that !!!!! One of the reasons we keep on using HC3 is Jan !!!
    • Thanks 2
    Is there a way to create a rule like this - using this HT Structure - so the rule run if one of the three sensores is breached.
    rule("terasse.lille:breached  => terasse.lille.lys:on; lilleTerrasseBreachedORManuelt=true")
    The problem is that terasse.lille is a key-value table, and the rule needs an array
    You could define something like
    I'm unsure what terasse.lille.lys is as it is not part of your HT.
    Good morning Jan,
    Regalar I have an error about
    If I exucute this rule now it does not generate an error.
    Why I get that error at 23:37?
    Rule:
    Please advice,
    //Sjakie
    31 minutes ago, Sjakie said:
    Good morning Jan,
    Rule:
    Please advice,
    //Sjakie
    Some device, in stekkers or the other tables are not a device that not have a value property that is a number or boolean (i.e. not a switch/dimmer type). Check your device IDs. I would guess that it's in stekkers?
    Jan,
    why it give sometimes an error and not always?
    I have plugs as;
    -binary switch>>Other brand
    -wallplug>>Fibaro
    //Sjakie
    32 minutes ago, Sjakie said:
    Jan,
    I have plugs as;
    -wallplug>>Fibaro
    //Sjakie
    Can be different reasons.
    Ex. a device, 99,  that always cause an error because it's value property is nil.
    But your test looks like
    {88, 99}:isOn
    where is returns true when 88 is on and never goes on to test 99. When 88 is off then it will test 99 and you get the error.
    Can also be that you have a broken device that sometimes return nil for fibaro.getValue(99,"value")
    If you have a device that you suspect you could make a rule like this that check it every 10s
    rule("@@00:00:10 & 99:value == nil => log('ERROR: Device 99 returns nil for value!!!')")
    Jan,
    Thank you!
    I adapted my QA lets see what is comming out.
    //Sjakie
    Jan,
    I saw in the other thread something about batteries.
    Is it possible for you in ER 4 to get warning(Push notification) empty batterie?
    In HC3  Fibaro gives me the notification but only the name and not the room so I need to scroll to device list to discover wich device needs replacement.
    It should be also nice to set the percentage for warning manually, if I am at home 5% and if we go on holiday I can manually change % so I dont have empty bats if we are gone.
    Thanks in advance,
    //Sjakie
    Well, devices do report property 'batteryLevel' changes. Something like this would work
    Jan, getting an error
    941= doorsensor
    //Sjakie
    941= doorsensor
    //Sjakie
    Sorry, Lua variables that we want to be used inside rules can't be local.
    Hello Jan,
    Its not working!
    592,608 value  < 45%   650=0%
    there is after 24 hours no log or push message
    Please advice,
    //Sjakie
    Jan here I have some difficulties to let the HUE color change
    If I post #concentratie no change in color.
    What am I doing wrong?
    //Sjakie
    1 hour ago, Sjakie said:
    Hello Jan,
    Its not working!
    Do you get any batteryLevel events?
    rule([[#device{id=devices,property='batteryLevel'} => log("BatteryLevel event:%s",env.event)")
    The rule will only run when a  device report a battery change.
    You could prime it at startup
    rule("for _,d in pairs(devices) do post(#device{id=d,property='batteryLevel',value=d:bat}) end")
    //Sjakie
    This rule does not work. You can only trigger on #event at left side of <=
    You are trying to do too many things in one rule....
    Jan, fixed
    Error was in push>>user wast defined (lost it somewhere).
    Thanks,
    //Sjakie
