sorry found ER
    1 hour ago, Sjakie said:
    Wowwww Jan now it will become more easy  for us, thanksssss!
    COH1.18 no action thats a pitty because I use this version, some quick fix?
    COH1.19 it shows in QAUpdater and if I click update it uodates the older version
    ER I dont see anymore???
    //Sjakie
    ER still 05 fix 79
    Ok, so the old versions of ER4 and COH don't have the UID that identified them as ER4 and COH.
    However, there is a hack  - if you name your ER4 QA to "EventRunner" and your COH to "ChildrenOfHue" it will be treated as an updatable version of QAs, and you should be able to upgrade them.
    Please don't do that with a very old version of COH (before 1.12) as the child devices format is not compatible and will not work.
    Jan,
    versionnumber deleted?
    /monthly_2021_11/image.png.e305c39f7bc5e6a482a0155d92e40108.png" />
    Jan,
    No, it should be there. What version did you upgrade to? Does the QA start and log the version?
    I have the latest v0.5 fix 79
    The number disapeared after using QA updater
    //Sjakie
    //Sjakie
    Yes, but in the log console when the QA starts up - does it log a version number?
    Ex. if the QA crashes the version number will not be set.
    Jan, I installed copy of my QA v0.5 fix 79
    Run QA updater
    QA crashed
    I only have:
    main
    Eventrunner
    fibaro extra
    error:
    //Sjakie
    Thanks, that was a bug as postRemote wasn't included in the new code...
    Switching from the Toolbox library to the fibaroExtra library may cause this as I myself don't use all functions so I don't see if they are mixing - at the moment I had not tested remote....
    Refresh QAUpdater and upgrade to EventRunner4 v0.67 and see if it works?
    Jan now it works, thanks!
    If I update my 7 QA's it jumps back to first screen and I must select ER again can he be fixed on the latest used?
    //Sjakie
    empthy line in debug
    mmmh qa's are restarting
    QA 1302 >>>QA crashes:
    QA 1301 >>>crashes
    Jan,
    this one is solved (my fault)
    Please look at post! for QA 1301
    Jan,
    No color in debug
    16 minutes ago, Sjakie said:
    Jan,
    No color in debug
    Thanks for helping me to debug :-) Update to v0.68 and see if it fixes your problems.
    Jan, no color in debug
    Jan, post doest generate error anymore
    Ok, I have to move the colortags to the new version - tomorrow
    Jan no problem at all have a good nightand thanks for your exellence QA.
    //Sjakie
    Hi. I have had a problem with my rule for about the third day, which used to work without problems.
    HomeCenter3 , fw:5.090
    Eventrunner4 v0.66 also tested in version v0.50
    HT = {
        _Kancel_pohyb = 350,
       PriemerTempVonku = {380,37,28},
        _Kancel_hlavica_ = 332,
    The rule has 18 degrees when the movement is activated and at the same time the temperature on the head
     change the temperature setting value on the head to 22 degrees.
    rule("_Kancel_pohyb:breached & (sum(PriemerTempVonku:temp)/size(PriemerTempVonku) <= 12) & (_Kancel_hlavica_:heatingThermostatSetpoint == 18) => _Kancel_hlavica_:heatingThermostatSetpoint = 22")
    This part of the rule stopped working, when I delete it from the rule, the rule works. It still worked a few days ago. Did Fibaro change anything?
    and at the same time, this second rule, which worked three days ago, stopped working:
    The rule monitors the movement and when it is safe for 30 minutes, it sets the temperature on the head to 18 degrees.
    rule("trueFor(00:30,_Kancel_pohyb:safe) => _Kancel_hlavica_:heatingThermostatSetpoint = 18")
    Please advise where the error is
    HT = {
    Ok, it seems like it's always return floats now... so my comparison instruction didn't work. I've pushed v0.5fix80 for the old version and v0.66 of the new version with a fix for this.
    Thanks for reporting the bug.
    Thank you for the correction. It's already working.
    Eventrunner4 v0.69 also tested in version v0.50
