hi jgab
msg not working in new EventRunner4 v0.69 version
Have you changed the way it works?
rule("phoneID={1595}")
rule("et.DoorBell:isOn =>  phoneID:msg=log(‘Main DoorBell!’)”)
@minsad
Its working here on ER4 v0.69
    2 hours ago, Sjakie said:
    @minsad
    Yes, a <ID>:msg="Hello" is translated to
    fibaro.alert("push",{<ID>},"Hello",false)
    and if I put my iosDevice ID it works for me.
    hi jgab
    I wonder
    old version of notice
    rule("once(09:00..22:30 & kidCo2:value>1000) => phoneID:msg=log('House Co2 is over 1,000!: %s', kidCo2:value)")
    new version
    rule("once(09:00..22:30 & kidCo2:value>1000) => phoneID:msg ='House Co2 is over 1,000!: %s'; kidCo2:value")
    I want to send kidCo2:value to the notification
    can you give me an example ?
    9 minutes ago, minsad79 said:
    hi jgab
    I wonder
    new version
    it should be like old version
    rule("once(09:00..22:30 & kidCo2:value>1000) => phoneID:msg =log('House Co2 is over 1,000!: %s',kidCo2:value)")
    phoneID should be the one you find at api.get("/iosDevices") for your user
    jgab
    Noti works fine
      -----Test-------------
      rule("@@00:00:10 => phoneID:msg = 'House Co2 is over 1,000!: %s,BedCo2:value'; log('House Co2 is over 1,000!: %s', BedCo2:value)")
    [17.11.2021] [15:47:09] [ [32mDEBUG [0m] [QUICKAPP1001]: [true]>>'Rule:46[@@00:00:10 => phoneID:msg = 'Home Co2 has exceeded 1,000!: %s,BedCo2:va...]'
    [17.11.2021] [15:47:09] [ [34;1mTRACE [0m] [QUICKAPP1001]: House Co2 is over 1,000!: 450.0
      450.0 <= How to send?
     450.0 =<
    I don't think I understand you...
    phoneID:msg = "Hello"
    sends the string "Hello"
    log("Value is %s",45)
    logs the string "Value is 45" to the console, but also returns the string "Value is 45"
    so...
    phoneID:msg = log("Value is %s",45)
    logs the string "Value is 45" and sends the same string
    On 10/31/2021 at 6:16 PM, ChristianSogaard said:
    Could you also make COH, so it will update from Github like EV4 :-) its a mess to upgrade because too many EV4 rules depends on the HUE device ID :-). And i found a few bugs in COH, and know it will take me hours to update ;-) when reinstalling COH
    Yes it works now with QAUpdater - but only for versions I release. However, TQAE also have a feature to copy files to the QA on HC3. This means that you can easily fix bugs in the code in TQAE and when it works “patch” the real version on the HC3 with the working code.
    If you have fixes for bugs I can add them  to the code and release a new version (with QAUpdater)
    Jan, I have this error since new version I think
    mmmh I am lost a bit
    I wanted to downgrade QA 1302 but its on fix v5 fix80???
    I thought to downgrade to see if the error is there or can I figer out what cause this error
    Now QAUpdater only give 0.7
    Unable to see/select QA 1302
    Please advice,
    //Sjakie
    You can't downgrade v5 versions.
    You can only downgrade v0.7 (0.70) to 0.69
    ok
    How to downgrade from 80?
    He is not visable in QA updater
    /monthly_2021_11/image.png.7cc8bd74a2a2f4256e281fdd2a2321ed.png" />
    sorry Jan got it.
    Error was also present in fix80
    Dont know how to find the cause
    //Sjakie
    I pushed 0.72 with hopefully better error messages - and hopefully it will report your "empty" error and give us a clue.
    Jan, great and thanks
    Version 0.7 is still the highest.
    //Sjakie
    //Sjakie
    Forgot to push - try again.
    Jan, all QA's are now on .072
    I see only errors from removed devices for my upcommimg move to another house.
    Lets see after 24 hours run what pops up.
    Thanks!
    //Sjakie
    On 11/15/2021 at 1:40 PM, Sjakie said:
    Wowwww Jan now it will become more easy  for us, thanksssss!
    COH1.18 no action thats a pitty because I use this version, some quick fix?
    COH1.19 it shows in QAUpdater and if I click update it uodates the older version
    ER I dont see anymore???
    //Sjakie
    ER still 05 fix 79
    Thank you @jgab I love the updater :-) and COH as well
    Just update to newest COH.
    I have a small BUG in COH v1.20 and former versions.
    Its when you have more than one light in a ZONE - AND you turn off the POWER /240v to one of the lights in the ZONE.
    Then when you trying to turn off the rest of the light with COH in the ZONE, Turn OFF dont work.
    Turn ON a ZONE where one Bulb has no power/240v works fine - but turn off dont work for all if one of the bulbs in the zone has no power.
    Edited by ChristianSogaard
    P
    Ok, the group/room/zone code is a bit strange and I guess there can be something there.
    However, I'm experimenting with the v2 api and I've made a lot of progress so next version may be a v2 api.
    The api is a bit more consistent than v1 and there is a way to get events/changes resembling how we use the HC3 /refreshState which is less cpu consuming then polling the Hue Hub every second. So, I'm optimistic that v2 will be better....
    Ready for testing when you are :-)
    Jan, I didt see any error with blank line anymore!
    //Sjakie
