Jan thanks will go for it after my memory problem is solved.
HC3 restarts because 1% memery free.
I have no idea what Fibaro is doing or did I never have seen this before.
Jan can ER4 do
Lets say every 5 days but a lot off times after eacg other to clear history to get somememory back
Manually I did in browser 50 times and going down from 99% >>>92% as long as it stays on that level.
Thanks for your support,
//Sjakie
Flott Jan, thanks for your help. Working fine and ready for the cold months ahead. Fantastic program and good fun to work with.  Takker
    Jan can ER4 do
    //Sjakie
    Have you tried
    Great Jan thanks!!
    was 72/45 after 20 hours
    now 62/40 after 5 minutes
    HC3 was always on 38 so something changed I didt modify or added some new stuff.
    Okay I know 2% differnce ist much but it is growing!
    Thanks again,
    //Sjakie
    Jan,
    If I restart HC3 after your beautifull rule the effect is bigger.
    How to extend your rule HC3 will restart? I couldt find it in the thread here.
    Thanks,
    //Sjakie
    On 7/10/2021 at 2:35 PM, jgab said:
    I have updated iOSLocator.fqa (v0.2)
    It is not really a EventRunner QA but it is a nice helper.
    QuickAppVariables
    • HomeVar
      Defaults to 'iOSHome' and is the name of the global variable where home status is stored.
      Possible values: 'all_home', 'all_away', 'some_home', 'unknown'
    • UserLocVars
      User names and the global variables to store their state in
      Ex. 'Bon:BobLoc,Ann:AnnLoc'
      will store Bob's status in global 'BobLoc', and Ann's status in global 'AnnLoc'
    • LocationsVar
      Defaults to 'iOSLocInfo'
      Is the name of the global variables where all location info for users are stored
    • HomeName
      Defaults to 'Home'
      Name of the place home. To avoid that home is logged as the HC3 name...
    • AwayName
      Defaults to 'Away'
      Name of the place away from a location
    The QA uses the defined locations, defined in the general/location panel
    Inside the QA a table 'USERS' need to be defined
    Ex.
    'User' is username - should be without spaces and strange characters (used in global variable name)
    'home' is true if user is part of people that live at home - used to decide if all at home etc.
    'device' is name of iDevice, matches so "iPhone" mathes 'Jan's iPhone'.
    'id' is the HC3 user id
    icloud.user is icloud username
    icloud.pwd = is icloud password
    Besides setting the global variables - that works for any user, not only HC3 users. If the 'id' field is set to a HC3 userID a GeofenceEvent will be emitted when user enter and leave locations, similar to the builtin geolocation function.
    If id is set you can capture it with a rule like
    if not you can use the global variables
    Hi Jan
    I'm trying to get iOSLocator up running in my environment.
    And I am a bit challenged here ?
    First - would it work, when i am using two factor authentication in icloud?
    I need to configure two places - right ?
    In the Variables fane, and Edit the Local users Section in the code
    I'm a little unsure how to use the UserLoCVar and "Local users" in combination?
    and i looks like im not connected to icloud
    /monthly_2021_10/2021-10-09_12-09-47.png.8ba9033c910637f5a857e49674d93a32.png" />
    6 hours ago, ChristianSogaard said:
    Hi Jan
    I think it works with 2-factor. It's an OATh API used.
    In the log does it say that it gets data for your user? You stopped the log short of when the interesting stuff happens....
    6 hours ago, Oddi_78 said:
    Yes, I have to share how I did it. My daughter uses a windows pc now, but when it becomes available I will show you. I have made two TTS scenes, one for Norwegian and one for English. I have also made 2 scenes for sound effects (playing mp3 filet), one for each of the 2 sonos speakers. The 2 TTS scenes listen to a global variable and the same with the TTS scenes. So when I create scenes with TTS and the Sound Effect I just set the variables and the 4 engine scenes take care of Sonos TTS and sound effects
    The log is complete. it just continues with
    [09.10.2021] [19:58:49] [TRACE] [QUICKAPP1260]: iOSLocator, deviceId:1260
    [09.10.2021] [19:58:50] [DEBUG] [QUICKAPP1260]: Event:start
    [09.10.2021] [19:58:50] [TRACE] [QUICKAPP1260]: Global variable for home status: iOSHome
    [09.10.2021] [19:58:50] [TRACE] [QUICKAPP1260]: Global variable for all location status: iOSLocInfo
    [09.10.2021] [19:58:50] [TRACE] [QUICKAPP1260]: Global variable for user: 'Ann' is 'AnnLoc'
    [09.10.2021] [19:58:50] [TRACE] [QUICKAPP1260]: Global variable for user: 'Bob' is 'BobLoc'
    [09.10.2021] [19:58:50] [TRACE] [QUICKAPP1260]: Name of home place: 'Home'
    [09.10.2021] [19:58:50] [TRACE] [QUICKAPP1260]: Name of AWAY place: 'Away'
    [09.10.2021] [19:58:50] [DEBUG] [QUICKAPP1260]: Event:setupLocations
    [09.10.2021] [19:58:50] [TRACE] [QUICKAPP1260]: Home set to 'HC3-00002517'
    [09.10.2021] [19:58:50] [DEBUG] [QUICKAPP1260]: Event:getIOSdevices Christian
    [09.10.2021] [20:00:20] [DEBUG] [QUICKAPP1260]: Event:getIOSdevices Christian
    Usually there is some kind of success or error log after "Event:getIOSdevices Christian".
    Or does the QA crash and restart?
    Seems to run "perfect"
    09.10.2021] [21:40:20] [DEBUG] [QUICKAPP1260]: Event:getIOSdevices Christian
    [09.10.2021] [21:40:59] [TRACE] [QUICKAPP1260]: iOSLocator, deviceId:1260
    [09.10.2021] [21:40:59] [DEBUG] [QUICKAPP1260]: Event:start
    [09.10.2021] [21:40:59] [TRACE] [QUICKAPP1260]: Global variable for home status: iOSHome
    [09.10.2021] [21:40:59] [TRACE] [QUICKAPP1260]: Global variable for all location status: iOSLocInfo
    [09.10.2021] [21:40:59] [TRACE] [QUICKAPP1260]: Global variable for user: 'Bob' is 'BobLoc'
    [09.10.2021] [21:40:59] [TRACE] [QUICKAPP1260]: Global variable for user: 'Ann' is 'AnnLoc'
    [09.10.2021] [21:40:59] [TRACE] [QUICKAPP1260]: Name of home place: 'Home'
    [09.10.2021] [21:40:59] [TRACE] [QUICKAPP1260]: Name of AWAY place: 'Away'
    [09.10.2021] [21:40:59] [DEBUG] [QUICKAPP1260]: Event:setupLocations
    [09.10.2021] [21:40:59] [TRACE] [QUICKAPP1260]: Home set to 'HC3-00002517'
    [09.10.2021] [21:40:59] [DEBUG] [QUICKAPP1260]: Event:getIOSdevices Christian
    [09.10.2021] [21:42:29] [DEBUG] [QUICKAPP1260]: Event:getIOSdevices Christian
    [09.10.2021] [21:43:59] [DEBUG] [QUICKAPP1260]: Event:getIOSdevices Christian
    Edited by ChristianSogaard
    P
    Hi Jan
    Any thoughts how to extend to logging or where I can start searching?
    42 minutes ago, ChristianSogaard said:
    Hi Jan
    You should be able to run it in my emulator.
    In
    function EVENTS.getIOSdevices(ev)
    there is a http request.
    Set a breakpoint in the error and the success handler and see what you get, if you get something.
    Hi, please advise:
    I have HC3, fibaro motion sensor, fibaro radiator head, I want to write it in EVENT RUNNER 4
    When the movement is disturbed, I want the temperature to be set to 25 at the head
      HT = {
         _Kancel_pohyb = 207,
         _Kancel_hlavica_ = 332,
    rule("_Kancel_pohyb:breached => _Kancel_hlavica_:fibaro.call(332, 'setHeatingThermostatSetpoint', 30)")
    or, maybe simpler
    rule("_Kancel_pohyb:breached => _Dielna_hlavica_:heatingThermostatSetpoint = 22.5")
    rule("trueFor(00:30,_Kancel_pohyb:safe) => _Dielna_hlavica_:heatingThermostatSetpoint = 18"
    So, this is a trick if you want a smoothed value instead of a jumpy value - ex. a power value.
    The value given to the smoothFilter functions is the number of values change the average should be calculated for (sliding window)
    The rule variable 'power11' is declared a triggerVar so it can be used to trigger other rules when it changes value. It's not really a "sliding average" but an approximation calculated without any buffer - that's why we call it a "smoothed" value....
    HC3 + EventRunner 4
     HT  = {
    PriemerTempVonku = {380,37,28},
    LUAscena = 159
    LUAscena - je scéna, ktorá beží ako LUA na HC3
    pravidlo ( "súčet(PriemerTempVonku:temp)/veľkosť(PriemerTempVonku) <= 10 = > ************************************ ********* " )
    fibaro . scéna ( 'execute' , {[ 1 ] = 159 , })
    Toto pravidlo by malo povoliť túto scénu LUA.
    Potom potrebujem druhé rovnaké pravidlo, ale podmienka bude > 10, takže LUA vypne scénu
    pravidlo ( "súčet(PriemerTempVonku:temp)/veľkosť(PriemerTempVonku) > 10 = > ********************************* ********" )
    EDIT: sorry i fixed it:  PriemerTempVonku = {380,37,28}
    Edited by budu
    error in text
    10 minutes ago, budu said:
    HC3 + EventRunner 4
     HT = {
    PriemerTempVonku = 48,
    LUAscena = 159
    LUAscena - is a scene that runs as LUA on HC3
    rule("sum(PriemerTempVonku:temp)/size(PriemerTempVonku) <= 10 = > ****************************************")
    fibaro.scene('execute', {[1] = 159, })
    This rule should enable this LUA scene.
    Then I need a second rule of the same only the condition will be > 10 so the LUA will turn off the scene
    rule("sum(PriemerTempVonku:temp)/size(PriemerTempVonku) > 10 = > ****************************************")
    Why do you sum when PriemerTempVonku is not a table with ids ?
    I believe that sum and size will not work if it's not a table.
    To start scene 159 you can do 159:start
    rule("PriemerTempVonku:temp > 10 => LUAscena:start")
    HC3 + EventRunner 4
     HT  = {
    _Kancel_pohyb  =  1 48 ,
    PriemerTempVonku  = { 380 , 37 , 28 },
    _Kancel_hlavica_ = 54,
    _WC_dielna_Hlavice_ = 55,
    pravidlo ( "_Kancel_pohyb:porušené &
    súčet(PriemerTempVonku:temp)/veľkosť(PriemerTempVonku) <= 10 &
    **************************** => _Kancel_hlavica_: heatingThermostatSetpoint = 21 _WC_dielna_Hlavice_: heatingThermostatSetpoint = 21 " )
    pravidlo ( "trueFor(00:05,_Kancel_pohyb:safe) => _Kancel_hlavica_:Nastavená hodnota termostatu vykurovania = 18 ; _WC_dielna_Hlavice_:Nastavená hodnota termostatu = 18" )
    Dobrý deň, mám dve pravidlá.
    K prvému pravidlu potrebujem pridať ****** miesto: _Kancel_head_ = nastavená na 18 stupňov Celzia.
    Vopred dakujem za rady.
    Edited by budu
    Hi. Here's how to create a rule:
    rule("@@00:05:00 & (PriemerTempVonku:temp < 10) => LUAscena:start")
    Thak you
    Edited by budu
