Jan still strugling with HUE light colors.
In debug it show set value "col":448
result still different color
What I am doing wrong?
Please advice,
//Sjakie
    Please advice,
    //Sjakie
    Should it be ct=448?
    Jan, I tried it before when I had other errors.
    I changed but no result
    //Sjakie
    So ct is the color temperature for a Hue light (the yellowness-ish). Is that what you want to set?
    Is it white lights that only control temperature you have?
    There is no 'col' attribute in Hue lights.
    If you want to set the (rub) color of a light there are other attributes.
    If I try it at home with a RGB light I can see a difference if I set different 'ct' values, but they have to differ quite a lot for the eye to notice. ct=10 almost turned off the light... 448 is a pretty normal value.
    Jan,
    I like to change the color (from white-blue-isch and yellow>>ct)
     ct set on 454>>light is dark yellow so this is good
    Debug ct 153 is wrong
    //Sjakie
    Set the color you want using the Hue app, then read out the state with ER and set it back with :value=…
    Jan, will do.
    Other minor anoying error:
    This rule works to well!
    If I start with the wake up routine arming complex:off and ringBewaking:on
    If wife lays still in bed makes pir safe and the bedroom window is open >>somebody enters from outside, how to avoid the alarm at this moment?
    Please advice,
    //Sjakie
    Hei @jgab
    Hei Jan, just to thank you for your previous assistance with eventrunner3 and scene for outdoor lighting. I ended up with rules for season and it works like a charm. Thank you ..
    I am back at the house again after several months away at work and wonder if you might have the time to help me,yet again, with a scene i am trying to write ?
    I have an outdoor heating cable for concrete step heating (when it snows or ices). The cable is installed without a sensor. I wish to create a scene that can regulate the heating effect similar to a manual regulator.  I had a Micro Matic MR16 that regulated heating over a 30 minute period. The regulator had a simple 0 to 10 scale where 1 was 3 minutes , 2 was 6 minutes etc.. Thus, setting the regulator to 5 would mean the heating was on for 15 minutes and off for 15 minutes. This of course repeats throughout the whole period the regulator is switched on.
    I have made a VD with slider (range changed to 30 min ) and 6 buttons for fast 5 to 30 min turn on times, and a global variable that stores the VD values.
    I have made a standard scene , if global variable is 5 , turn on heating cable 5 minutes turn off 25 minutes and so on but would like to have a more elegant way to compose and run this scene?
    I was thinking of using ev3 scene for heating.
    I have very limited skills with tables etc and have looked online for an example to work with but havn't found anything within my scope of understanding.
    Just to try out a variable switching a fibaro rele i tried:
    Rule.eval("$VarmeEffekt=='5'  => releid:on")   -----globalvariable VarmeEffekt = 5  turn on heating rele
    but get (bad argument #1 to 'pairs' (table expected, got nil)
    Hoping i made myself understandable ?? Any ideas or links to examples. Thanking you in advance.
    • Please login or register to see this link.
    8 hours ago, MARCUSP.I.L said:
    Hei @jgab
    I'm not 100% sure what you need.
    I assume that depending on 'VarmeEffekt' you want to run different "programs" e.g. sequences of on-off commands for the heating?
    First make sure that the  rules trigger on your global
    You are on HC2 and ER3? then don't forget to add the global variable trigger for VarmeEffekt in the header of the ER scene.
    Then make a table of your programs and rules like this
    Good morning Jan,
    I hope you can translate my room temperature in a log?
    If I ask my data with   "http://192.168.1.18/data.json?heater=1room_temp_1_lsb"
    it will list a bunch of data but this we need:
    to calculate room temperature:
    temperatuur(°C) = (value_lsb + value_msb * 256) / 100.0
    How to get this temperature visable in a log?
    How I can use it as trigger?
    Thanks in advance,
    You are an excellent support to bring my HA to the highest level!
    //Sjakie
    7 hours ago, Sjakie said:
    Good morning Jan,
    Thanks in advance,
    //Sjakie
    Something like this? - checks the temperature every minute
    Jan, Thank you very much!
    first run error
    If I post
    It returns the data list
    second run error
    Please advice,
    //Sjakie
    Thanking you Jan your your quick response. It took me a little while to get the idea but it works perfectly.
    I really have to spend more time with eventrunner, I will make it a point to read more.Thank you for your excellent work and your invaluable assistance.
    Edited by MARCUSP.I.L
    first run error
    If I post
    Is it a POST or a GET request?
    What do you get back from the http request?
    Can you post the complete rule as it stands?
    14 hours ago, MARCUSP.I.L said:
    Thanking you Jan your your quick response and assistance. I am working with your answer now but havn't managed to get it working. I feel quite dim to say the least ! The idea is that when i set values from a VD on my phone  it will start to run different "programs" e.g. sequences of on-off commands for the heating.
    Hoping you might find the time to point me in the right direction.  Takker
    So the example I posted
    will run different programs defined in ER depending on the number you set the global 'VarmeEffekt' to.
    Wasn't that what you needed?
    I tried a few options bu t no luck
    //Sjakie
    //Sjakie
    Sorry, too early in the morning - the url should be a string
    Jan
    So this works
    //Sjakie
    Jan. is there a rule to abort scene if global is not equal to ?
    I want the scene to stop if another global variable is not 1 or is 0.
    I ended up with the following ; the slider in VD sets intervals in minutes and buttons set quick 5 to 25 minutes.
    I use the slider(minutes) for fine adjustment of regulator( not really needed but good to know how).
    Otherwise the scene runs perfectly.
    Takker
    The idea was that program 0 turns off the relay and then just turns off every 60min now. It's like an off function, or is it a problem that it turns off every hour even if it's off?
    The long list of log rules can be replaced with just one rule.
    You can add another global to trigger on.
    Like
    3 hours ago, Sjakie said:
    Jan
    So this works
    //Sjakie
    Sorry, the 'turl' can not be declared local
