After today's update, the ER4 will no longer run. Is there a way to restart the QA?
Every attempt to edit ends with a Fibaro window with "ERROR 500 - Internal server error"
I don't want to start the HC3 every time.
[12.08.2021] [04:57:31] [DEBUG] [QUICKAPP96]: fibaro.call(119,"turnOff") => nil
[12.08.2021] [05:00:00] [TRACE] [QUICKAPP96]: New file version:EventRunner4Engine.lua - v0.5fix74
[12.08.2021] [05:00:01] [DEBUG] [QUICKAPP96]: 1 files needs to be updated
[12.08.2021] [05:00:01] [DEBUG] [QUICKAPP96]: 0 files needs to be added
[12.08.2021] [05:00:01] [DEBUG] [QUICKAPP96]: 0 files needs to be deleted
[12.08.2021] [05:00:01] [DEBUG] [QUICKAPP96]: Updating EventRunner
[12.08.2021] [05:01:00] [ERROR] [QUICKAPP96]: QuickApp crashed
[12.08.2021] [05:01:00] [ERROR] [QUICKAPP96]: Unknown error occurred:
[12.08.2021] [05:02:00] [ERROR] [QUICKAPP96]: QuickApp crashed
[12.08.2021] [05:02:00] [ERROR] [QUICKAPP96]: Unknown error occurred:
[12.08.2021] [05:03:00] [ERROR] [QUICKAPP96]: QuickApp crashed
[12.08.2021] [05:03:00] [ERROR] [QUICKAPP96]: Unknown error occurred:
[12.08.2021] [05:04:00] [ERROR] [QUICKAPP96]: QuickApp crashed
[12.08.2021] [05:04:00] [ERROR] [QUICKAPP96]: Unknown error occurred:
[12.08.2021] [05:05:00] [ERROR] [QUICKAPP96]: QuickApp crashed
[12.08.2021] [05:05:00] [ERROR] [QUICKAPP96]: Unknown error occurred:
[12.08.2021] [05:06:00] [ERROR] [QUICKAPP96]: QuickApp crashed
[12.08.2021] [05:06:00] [ERROR] [QUICKAPP96]: Unknown error occurred:
[12.08.2021] [05:07:00] [ERROR] [QUICKAPP96]: QuickApp crashed
[12.08.2021] [05:07:00] [ERROR] [QUICKAPP96]: Unknown error occurred:
[12.08.2021] [05:08:00] [ERROR] [QUICKAPP96]: QuickApp crashed
[12.08.2021] [05:08:00] [ERROR] [QUICKAPP96]: Unknown error occurred:
[12.08.2021] [05:09:00] [ERROR] [QUICKAPP96]: QuickApp crashed
[12.08.2021] [05:09:00] [ERROR] [QUICKAPP96]: Unknown error occurred:
[12.08.2021] [05:10:00] [ERROR] [QUICKAPP96]: QuickApp crashed
Thanks for helping
    Thanks for helping
    No, this is the QA trying to restart. I have seen this a few times in the past (also with other QAs) and someone else had the same problem. A restart of the HC3 seems to cure it.
    If you don't want to restart the HC3 there are some other options;
    You could try to download the QA from the HC3, delete the one on the HC3, and then upload the saved QA. I don't know if that is possible or will also give error 500. Alternatively install a new copy of ER4 and copy paste the main file content from the old QA to the new QA.
    hallo Jan,
    mmmhhh I missed the fun with updating your baby.
    I engage one QA for update>>> after debug reset select error result>>black screen
    So I permit the updated QA to launch by remote the updates for all other QA's.
    A big compliment, you are much better as Fibaro, all works like a charm no error at all.
    Best regards from a happy hc3 EVENT RUNNER camper,
    Thanks again for all the work you do,
    happy holiday,
    //Sjakie
    Jan, error light switched off should not happend in my opinion.  (uit =off)
    app.phone is not off according check
    Please advice or open my eyes.
    //Sjakie
    is this the cause? No state listed in devices In app I see the state I will revert back to previous restore no clue if it will help,
    //Sjakie
    I don't know why it shouldn't happen as I can't see the state of the devices you tests. However, the rule
    trueFor(00:05:31, appPhone.gastBoven:isOff & kamerBoven.Spottafel1:isOn | kamerBoven.Spottafel2:isOn | kamerBoven.Spotbed1:isOn | kamerBoven.Spotbed2:isOn | kamerBoven.Spotbed3:isOn) =>...
    will be interpreted as
    trueFor(00:05:31, (appPhone.gastBoven:isOff & kamerBoven.Spottafel1:isOn) | kamerBoven.Spottafel2:isOn | kamerBoven.Spotbed1:isOn | kamerBoven.Spotbed2:isOn | kamerBoven.Spotbed3:isOn) =>...
    So '&' (AND) has higher priority than '|' (OR) which is how it works in most programming languages incl. Lua.
    Is that the problem?
    I don't know. ER don't know about the app - will only use info in the HC3.
    Jan,
    the state of the device appPhone.gastBoven - off  false
    So this rule should not execute if state as above is false, my error?
    The state of the device is:
    17 minutes ago, Sjakie said:
    Jan,
    Yes, with the parenthesis like that it should work. But your rule from the log  looked like
    ...without the parenthesis.
    Jan yes I added the parenthesis.
    Wierd it came yesterday but thats because its earlier dark I gues.
    Thanks,
    //Sjakie
    Jan,
    Doorbell how to set volume?
    does not work.
    //Sjakie
    56 minutes ago, Sjakie said:
    Jan,
    does not work.
    //Sjakie
    How do you set it with a fibaro.call ?
    Jan, in block scene I only can select state == on/off
    If I open device
    If I open device
    Can you post the device structure? Use the swagger interface.
    fix76 implements 'setVolume' command. Unsure if your device supports it.
    You can try
    and see if it works...
    Jan,
    if I use volume the bell is silent with value it sound but not adjustable.
    Should this gives values of HUE as in HC2? I get nothing
     //Sjakie
    59 minutes ago, Sjakie said:
    Jan,
     //Sjakie
    Experiment with fibaro.call and see what works - then I can add to ER.
    Ex.
    does fibaro.call(ID,"setVolume",50) work?
    does fibaro.call(ID,"setValue",50) work?  (value shouldn't work as it seems to be a boolean value)
    does fibaro.call(ID,"setTone",2) work?
    etc.
    You can also try updateProperty
    api.put("/devices/"..ID,{properties={volume=50}})
    api.put("/devices/"..ID,{properties={tone=2}})
    Jan, you are the best!
    will work 0-100
    What about reading HUE settings?
    Thanks for your service!!
    //Sjakie
    will work 0-100
    But the 291:volume=100 should work in the latest ER.
    The lights store their Hue values in a quickAppVariable 'state'.
    This can be retrieved like below and ex. used to set default startup values for Hue lights...
    You could make an ER function
    and use it like
    To see the whole state do
    You can not trigger rules on state change, only on the properties being part of the Hue QA device definition. (like value etc)
    Jan, I miss your magic fingers.
    Jan typo:
    Hue I need to study more to let it work
    Thanks!!!!
    //Sjakie
    My typo, I mixed up mute and volume.
    Pushed fix78 that should correct it.
