    The important rule is the
    It will watch alarm partition 1 and send 'willArm' events when armed.
    ...will watch the whole house (all partitions)
    Guest kallecux
    Hi @jgab,
    I've searched a little, but haven't found anything.
    Can you give me a short example of how I can formulate an http command "from outside" that triggers an event in ER4?
    Thanks in advance.
    Best regards
    Karl Heinz
    or with curl
    Guest kallecux
    Do you know if it is possible to convert this curl command into a single http-call to use it as an api-call from within an other app (doorbird). I dont use any parameter, only an event.
    There is a GET versions too, but you need to be able to set headers for authentication and "X-Fibaro-Version: 2"
    On 12/1/2021 at 10:02 PM, jgab said:
    It's not the first of month that is the problem - that works. The issue is with the energy panel as we don't understand how it works...
    then I play with the energy panel
    1) as I said before, I have a meter QUBINO 3-PHASE SMART METER, after the latest updates of the fiboro from it received incorrect data, and then everything was zero.
    2) I just deleted it and added it to the system, then the data started coming from the meter.
    3) ER4 also began to receive data from the energy panel.
    4) But there is one problem:
    4.1) in ER4 come the figures from the SUM of all devices that can calculate energy consumption.
    4.2) and it turns out that for example:
    my light bulb -1 consumed 15 kW, my light bulb -2 consumed 25 kW,
    4.3) but there are still many devices in the house that are not connected to smart relays, so it is logical that we see ALL the other energy consumed on the main meter QUBINO 3-PHASE SMART METER ...
    4.4) so it turns out that the energy panel counts our 2 light bulbs in TOTAL CONSUMPTION and counts the indicator QUBINO 3-PHASE SMART METER in total consumption, but in QUBINO 3-PHASE SMART METER it is already our 2 light bulbs are counted !!!
    4.5) Therefore it is necessary to extract from the energy panel ONLY data from the GENERAL COUNTER, which I have QUBINO 3-PHASE SMART METER
    5) I dug into the swagger and although I'm not a programmer, but as if there is an opportunity to extract data on energy consumption from a specific ID or a specific room.
    5.1) Then we would have real data
    5.2) It remains only to implement this in ER4)))
    I have had the old LUAScheduler for HC2 v1.3.2 running on my HC2 fora couple of years but now I am looking into the HC3.
    original by robmac
    contibutions from jompa68 , A.Socha
    I recently began testing the EventRunner3 and since I have a whole bunch of block scenes running I was wondering if there is a way to call and run them from within EventRunner3?
    ;-) Mike
    original by robmac
    ;-) Mike
    Guest kallecux
    @fastvd
    Hi!
    try to read this:
    Greetings
    Karl Heinz
    2 hours ago, jgab said:
    Sweet!
    Simple pimple, thanks!  :-)
    New(bie) questions...
    I see variations in naming of rules...what's the difference? Both of them are working?
    And how is winter/summer supposed to be used?
    Mike
    2 hours ago, kallecux said:
    @fastvd
    Hi!
    try to read this:
    Greetings
    Karl Heinz
    thank. its works
    Is it possible to have ER "push a button" in a VD?
    ID:btn=BtnID' - :btn=BtnID, press button with id BtnID on virtual device ID, i.e. 'fibaro:call(ID,'pressButton',BtnID)'
    Thanks a lot!
    I´m slowly getting the hang of it...  ?
    Can I change the value of a variable like this?
    And also is there any difference between them? I see both in this topic.
    Mike
    Mike
    Yes you can assign a global variable with $<name> = <value>
    The value is automatically converted to a string. Tables are json.encoded.
    If 'below120' is a variable bound to a number it will get the number.
    If you want to assign it the string "below120" do
    Rule.eval and eval is the same thing.
    'rule' is defined as
    'rule' is just a bit shorter to type...
    Thanks!
    I can get the values into globals but I don´t understand how to change one of the predefined values?
    :-) Mike
    Can't you just do
    rule("@sunset => $AWAYStatus = 'Home'")
    rule("@sunrise => $AWAYStatus = 'Away'")
    13 minutes ago, jgab said:
    Can't you just do
    I have tried tried this but I don´t know if my fingers might be glued together... ?
    The code runs but when I look at the variable panel nothing has changed...
    I was looking for a script to get all variables picked up and printed in the log but I couldn´t find one.
    Mike
