    The test for 'equality' is '==', a single '=' is for assignment.
    Which is the same as writing
    because the variable is true when we want something too be done.
    Important that you have declared
    Util.defTriggerVar('GAR_L_State',false)
    before the rules are declared in main()
    What I'm missing here is some rule to set GAR_L_State to false when the light is automatically turned on.
    Unless you use it elsewhere you don't strictly need the GAR_L_State variable?
    Here we have a non-trigger variable, GAR_L_Manual to remember if the light was turned on manual and in that case not turn ot off, after 8 minutes....
    Hi Jan,
    Could i turn off a rule for like a time?
    like if i manually turn off the light in a room the light should not turn on by the motion rule?
    Many thanks
    24 minutes ago, Qwerty1979 said:
    Hi Jan,
    Many thanks
    I guess after some time after the light was turned on it's still ok to turn own the light with the sensor?
    Here I reset the 'manual' flag after 30min being true...
    On 2/4/2022 at 1:09 PM, Sjakie said:
     , asbypass for your Denon plug it in a wall plug.
    If power higher than x >>on and lower than x >>off
    //Sjakie
    @Sjakie yes I also was thinking about this workaround,but rather try it first through the software before buying another piece of hardware.
    when I don't get it to work I will try your idea
    @Joel, I see the following error:
    On the left side if you use as trigger:
    @edwin023,
    okay
    --I dont know how you enable Denon
    --I dont know if Denon can give by API command back, I doubt I thought its one way traffic
    You have a qa who switch Denon on
    ad another rule:
    same trigger as Denon:on but extend trigger with & sunset..sunrise
    It will only switch Denon:on if he is already on but I dont think you will notice it.
    I hope it solves your problem.
    //Sjakie
    On 2/4/2022 at 8:26 AM, jgab said:
    Something like below. (I haven't been able to test run the rules so there could still be some issues and spelling mistakes)
    I think you should use the HT to define names for your device - like I did for woonkamer.motion
    Then you can use their names in the rules instead of the device number. Device numbers may change if you need to reinstall a device. Then you only need to update the HT and not all the rules.
    I put your changes that you suggested, but I got an error but the light turns on:
    in Rule:8[woonkamer.motion:breached & woonkamer.hue:isOff & woonkamer.lichtinval:lux < 25 =>>...]: ./include/EventRunner.lua:1953: ./include/EventRunner.lua:1358: attempt to compare number with nil
    Now the L log command separates user  logs from ER logs. Set USERTAG back to QUICKAPP if you want them in the same log.
    Are your Hue lamps Philips only - or you use some 3rd part signee lamps?
    Iam still trying to implement the log options think I don't understand so iam gone read some more on this subject.
    I only have Philips Hue lamps, as far as I know Zigbee is still not supported yet by hc3.
    when I define the 207 in the following rule it doesn't work (207=woonkamer.schakel)
    rule("207:scene ==  20 => woonkamer.hue:off")--Handmatig Hue lampen uit.
    I will post the changed code down below.
    local HT = {
      keyfob = 26,
      woonkamer = { motion = 229 ,lichtinval = 231 , temp = 230 , spotjes = 208 , hue = 180,203,175,291 , schakel = 207 , reciever = 290 , kodi = 194},
      gang = { motion = 218 , lamp = 38 , temp = 219 , lichtinval = 220 },
      keuken = { motion = 235 , lamp = 78 , temp = 236 , lichtinval = 237 }
    Util.defvars(HT)
    Util.reverseMapDef(HT)
    local USERTAG = "Eventrunner" -- "QUICKAPP"
    function L(c,f,...)
      return string.format("#T:%s%s##C:%s#%s",USERTAG,quickApp.id,c,string.format(f,...))
    rule("log(L('green','My ER starting (%s,%s)',E_VERSION,E_FIX))")
    --------Daytime-------------------------------------
    rule("log(L('orange','-------------- Regels vaststellen ---------------'))")
    rule("global('DayTime')")
    rule("07:00..12:00-1 => $DayTime='Morning'").start()
    rule("12:00..18:00-1 => $DayTime='Day'").start()
    rule("18:00..23:00-1 => $DayTime='Evening'").start()
    rule("23:00..07:00-1 => $DayTime='Night'").start()
    rule("@@01:00:00 => log('Status woning %s state',$DayTime)")
    --------------------Gang tafelamp------------------
    rule("gang.motion:breached & gang.lichtinval:lux < 10 => gang.lamp:on ")
    --Tafel lamp aan na beweeg en lux onder 10.Auto uit na 3 min.
    rule("trueFor(00:03,gang.motion:safe) =>  gang.lamp:off")--lamp automatisch uit na 3 min geen beweging.
    -----------------------Woonkamer --------------------
    rule("log(L('orange','-------------- Woonkamer ---------------'))")
    rule([[woonkamer.motion:breached & woonkamer.hue:isOff & woonkamer.lichtinval:lux < 25 =>>
      || sunset-00:30..19:00 >> woonkamer.spotjes:value=20
      || 19:00..21:00        >> woonkamer.spotjes:value=15
      || 21:00..23:59        >> woonkamer.spotjes:value=10
      || 23:00..sunrise      >> woonkamer.spotjes:value=1
      || true                >> log(L('red','Woonkamer breached outside time intervals'))"]])
      ---Spotjes na beweeg en lux onder de 20 aan.Hue lampen uit.Lumen afhankelijk van de  tijd.
    rule("trueFor(00:20,woonkamer.motion:safe) => woonkamer.spotjes:off")--Spotjes automatisch uit na 20 min geen bweging.
    --rule("208:isOn & 208:manual >= 0 => 208:off")
    --Hndmatig Hue lampen aan en spotjes uit.
    rule("207:scene ==  21  => woonkamer.hue:on & woonkamer.spotjes:off")
    rule("woonkamer.reciever:on & sunset-00:30..sunrise+00:30 => woonkamer.hue:value=70")--reciever aan hue lampen aan
    rule("#device{id=woonkamer.kodi,property='state',value='playing'} & sunset-00:30..sunrise+00:30 => woonkamer.hue:value=30; woonkamer.spotjes:off") --Kodi play Hue aan gedimt 30%. Spotjes uit.
    rule("#device{id=woonkamer.kodi,property='state',value='paused'}  & sunset-00:30..sunrise+00:30=> woonkamer.hue:value=50")--Kodi pauze Hue lampen gedimt 50%
    rule("#device{id=woonkamer.kodi,property='state',value='stopped'} & sunset-00:30..sunrise+00:30 => woonkamer.hue:value=70")--Kodi stop hue lampen gedimt 70%.
    ---------------------Keuken lamp-------------------
    rule("log(L('skyblue','-------------- Keuken ---------------'))")
    Util.defTriggerVar('time',3*60) -- 3min
    rule([[keuken.motion:breached &  keuken.lichtinval:lux < 20 =>
      || sunset-00:30..19:00 >> keuken.lamp:value=20
      || 19:00..21:00        >> keuken.lamp:value=15
      || 21:00..23:59        >> keuken.lamp:value=10
      || 23:00..sunrise      >> keuken.lamp:value=5]])                --Lamp na beweeg en lux onder de 20 aan.Lumen afhankelijk van de  tijd.
    rule("trueFor(time,keuken.motion:safe) =>  keuken.lamp:off; time=00:03:00")-- lamp automatisch uit na 3 min geen beweging.
    rule("log(L('orange','-------------- Alle regels vastgesteld---------------'))")
    4 hours ago, Sjakie said:
    @edwin023,
    okay
    ad another rule:
    //Sjakie
    I control my tv and connected it to my Denon receiver trough hdmi,when I turn on my tv it also turns on my Denon receiver.
    I could not get the qa to work with my Samsung tv so I wanted to try the qa for my Denon receiver to turn on some light when I turn on my tv/reciever.
    using the qa for de Denon I can only mute/unmute and have volume control but I cannot turn on/off the Denon for some reason.
    But I think you are right and the qa only sends commands to the receiver but doesn't send a commant back.
    So I think I have to do your suggestion to make it work.
    local HT = {
      keyfob = 26,
    You need to set the hue ids in a table
     woonkamer = { motion = 229 ,lichtinval = 231 , temp = 230 , spotjes = 208 , hue = {180,203,175,291} , schakel = 207
    Thank you for the quick reply.
    Iam gonne dive into the colored debug lines and trying to smooth out my code a little bit.
    @edwin023, wierd you cant switch on/off
    did you try this, change IP adres in yours:
    If you put it without ("     "); in your internet browser it should work and operates your Denon.
    //Sjakie
    I think that's what I was doing wrong.
    The way I am working it is that the GAR_L_State is set to false by default, defined in my variables section.
    When the door opens, it turns the light on and sets GAR_L_State to "true",  then when the light switch is flicked while the lights are on it sets GAR_L_State to "false" and turns the light off. I'm not sure if there is a better way do to it but I will do some more testing. I can't just rely on the door trigger because sometimes I am in there while the door is shut but still want the lights on.
    //Sjakie
    @Sjakie after a late night search i found a Denon Qa that works,i can turn on/off , mute/unmute and change input.
    So now i have to figure out if i can use it to trigger the lights in ER.
    Thank you for the links, i wil check them out this evening.
    If you note the deviceID of the Denon QA, ex 567, you can add this rule
    and make a note on what events you get when you start stop the Denon and other  operations.
    These events you can then use to write ER rules to trigger actions like turning on/off lights
    @Sjakie @jgab
    Gentleman thank you for you support, I got I working.
    Big thumbs up.
    Can I use the log rule that jgab posted above also with other qa?
    iam trying to figure out how to get an Plex qa working.
    With this QA I get the name of the movie and the duration, but no play/pauze/stop status.
    It gets its info from a http link using GET,see code below.
    I think I have to dive into the api of Plex, but I think its an impossible task sinds Plex Support Webhooks( perhaps something I have to learn)
    function QuickApp:connectPlex()
     local address = "http://"..self.ip..":"..self.port.."/status/sessions"
    self.http:request(address, {
            options = {
                headers = {
                    ["X-Plex-Token"] = "......",
                    ["X-Plex-Client-Identifier"] = "...........",
                    ["Accept"] = "application/json",
                method = "GET"
            success = function(response)
    if tonumber(plexdata.MediaContainer.size) > 0 then
        metaDataInfo = plexdata.MediaContainer.Metadata[1]
        media = metaDataInfo.librarySectionTitle
        audioCodec = metaDataInfo.Media[1].audioCodec
        duration = self:convertTime(metaDataInfo.duration)
        summary = metaDataInfo.summary
                plexdata = json.decode(response.data)
                --self:debug(response.data)
                self:videoData(plexdata)
                end,
            error = function(err) self:debug("Error: " .. err) end
    also found some Webhooks payloads, is there something I can use?
    Media starts playing (media.play). An appropriate poster is attached.
    Media playback pauses (media.pause)
    Media playback resumes (media.resume)
    Media playback stops (media.stop)
    Media is viewed (played past the 90% mark) (media.scrobble)
    Media is rated (media.rate). A poster is also attached to this event.
    Edited by edwink023
    @jgab i stil get the error, is this created because I manual turn of the light?
    dwwdwdsdf
    dwwdwdsdf
    Can you post the whole rule?
      || 19:01..21:00        >> woonkamer.spotjes:value=15
      || 21:01..23:59        >> woonkamer.spotjes:value=10
    It's an extra '>' char at the end of the first line
    glad its that simple, i changed it and will see if the error stays away.
    thans you for the quick responds.
