@Joel,
I use  this QA (also from JGab) and its doing what isnecessary.
//Sjakie
    19 minutes ago, Sjakie said:
    @Joel,
    //Sjakie
    The commands supported (like to set colors) are listed here
    thanks @jgab @Sjakie
    I'll have a play, I was hoping to use the Hue All in one QA, purely because I can trigger the built in hue scenes. I was assuming it would be simple matter of adding the fibaro call to that QA into the ruleset:
     but I get an error, which seems to be complaining that it needs a string, not a number
    [ERROR] [QUICKAPP130]: in Rule:9[BATH_Motion:breached => fibaro:call(HUE_Main, "HueCommands", {type='Hue', action...]: ./include/EventRunner.lua:1953: ./include/EventRunner.lua:270: Wrong parameter type, string required. Provided param '175' is type of number[22.02.2022] [12:59:00] [ERROR] [QUICKAPP153]: Unknown error occurred:
    fibaro.call is with a ‘.’ on the HC3. Not ‘:’
    Thanks, I must have been looking at ER3 examples
    19 hours ago, kallecux said:
    Sorry, but i will not work:
    This is the QA:
    and this is the rule log:
    and yes, there are many logs after your debug-hint, but no one from device 810.
    Greetings.
    Karl Heinz
    That is a mystery.
    I haven't been able to try exact your code - will see if I have the time tonight.
    Instead of the sleep loop have you tried
    ...just thinking if there is some issue with not giving background time to the QA...
    Guest kallecux
    I have two other binary sensors (787 und 788) and i made some tests and i THINK that there is NO event, when changing the log.
    These are the ER4 rules:
    Greetings
    Karl Heinz
    P.S.
    I changed the code to:
    function QuickApp:onInit()
       print("Bin da")
       setInterval(function() self:updateProperty("log",os.date("%S")) end,3000)
    but no reaction in the ER4 log.
    Edited by kallecux
    ...I think I know what's going on - let me run some tests tonight and I will be back.
    Ok, Its'a problem with fibaroextra that ER uses.
    Actually, for some reason the log property is not reported in the usual way like other property changes - instead it's reported in the .changes files the state returned by /refreshStates.
    It means some extra coding to lift that event so it's visible to ER.
    I will try to find some time tomorrow to code it.
    It means that there will also be a new version of ER4 to support the new event.
    Ok, I fixed the log issue.
    It will appear as a device event with property 'log'.
    #device{id=<id>, property='log', value='...'}
    New version of ER4 (0.77)
    New version of fibaroExtra.lua (0.934)
    New version of TQAE emulator.
    Guest kallecux
    Hi @jgab it works! Thank you very much for your work and your support!
    Have a good time!
    Greetings Karl Heinz
    Hello Jan,
    How can I send
    to Nodered?
    Or must I ask how to import this post into Nodered?
    //Sjakie
    Hi Jan,
    Thanks again for a great QA.
    I have run into a problem with a trigger from a tibber QA, that the value is "CHEAP", "NORMAL" with "" in the value can i somehow use like /" to escape in your rules?
    Single quotes also works for strings.
    rule("77:value=='' => log('Value is empty string')")
    yeah but the this is the value contains " " so the rule would be like
    rule("77:value=='"CHEAP"' => log('Value is "CHEAP"')")
    Ok, now I understand what you mean. I bit strange though that the value is quoted.
    Anyway, either
    rule("77:value=='\"CHEAP\"' => log('Value is \"CHEAP\"')")
    or use [[ ... ]] as outer quotation for the rule string
    rule([[77:value=='"CHEAP"' => log('Value is "CHEAP"')]])
    Ah thank you will try
    Thanks Jan it worked great.
    rule([[$tibber_currentLevel_410=='"CHEAP"' => log('Tibber level is "CHEAP"');49:msg = log('Tibber level is now CHEAP')]])
    Hello Jan,
    can you help me finding right notation for rules in reference to keyfob?
    example like this brings error:
    LiDeckeWZ = 407
    --EG1
    rule("KF_LiSchFluerEG:central.keyId==2.keyAttribute='Pressed' => LiDeckeWZ:toggle")
    --EG2
    rule("KF_LiSchFluerEG:central.keyId==2.keyAttribute==Pressed => LiDeckeWZ:toggle")
    Thanks in advance!
    22 hours ago, Speedo67 said:
    Hello Jan,
    Thanks in advance!
    The correct  way is to check each field separate (keyid and keyAttribute) with an AND '&' between them
    It's a bit repetitive and  verbose so I usually make a special rule for the keyfob  that reposts the event as a #keyFob event where the keyAttribute and keyId is concatenated.
    It also makes it easy to "fake" a key fob press to toggle the device automatically
    Ex.
    rule("@sunset+00:10 => post(#keyFob{value='Pressed2'})") --  Toggle device 10 past sunset...
