1 minute ago, jgab said:
that's only for v0.5fixXY, for newer versions you can give them any name as they use a serial number in the QA code to recognise the right QA.
Yes - i saw that. It's a masterpiece you made?
    Because it's a separate updater you should be able to revert to the previous version if something goes wrong with a new release.
    This is a little trick to make it easier to work with timers in ER4.
    It's common that if an event happens you want to start a timer or post something in the future. However, if the event happens again you want to
    cancel the first timer and restart it.
    Ex.
    If someone press btn1 and then later press btn2 (or press btn1 again) you want to cancel the first post for btn1.
    We can do that by keeping track of the post reference and cancel it.
    With some helper functions we can do it easier
    The previous rules would then look like
    e.g. events posted under the same name will cancel each other automatically.
    Good morning Jan,
    Is there a possibility that the system fils this rule with names or numbers?
    Devices = all battery operated
    Thanks in advanced,
    //Sjakie
    26 minutes ago, Sjakie said:
    Good morning Jan,
    Thanks in advanced,
    //Sjakie
    This just creates a variable named 'devices' with an array of numbers. What do you want to do with it?
    You can get the max battery
    You can get the average of the battery
    If some of them don't have a batteryLevel property you may get into trouble...
    Good Sunday Jan
    I have a single rule that stopped working after upgrading to the new EventRunner4 v0.78 N/A
    c02sensor = 521
    -- Grøn, Blå, Gul, orange, rød, lilla
    rule([[#device{id=c02sensor,value='$value'} =>
        || value < 600 & value > 0 >> 224:color={2,255,2,16};
        || value < 900 & value > 600 >> 224:color={2,2,255,16};
        || value < 1000 & value > 900 >> 224:color={255,2,2,16};
        || value < 2500 & value > 1000 >> 224:color={255,2,255,16};
    Trigger Showed in the History
    578 ppm , 521, CO2 Tornskadevej Indoor, Hjem/Stue, System, 16:43:08
    [22.05.2022] [16:43:09] [DEBUG] [QUICKAPP1103]: [{"type":"device","id":521,"value":"$value"}]>>'Rule:25[#device{id=c02sensor,value='$value'} =>...]'
    [22.05.2022] [16:43:09] [DEBUG] [QUICKAPP1103]: fibaro.call(224,"setColor",2,255,2,16) => nil
    [22.05.2022] [16:43:09] [ERROR] [QUICKAPP1103]: in Rule:25[#device{id=c02sensor,value='$value'} =>...]: ./include/EventRunner.lua:1953: ./include/EventRunner.lua:1359: attempt to compare nil with number
    Any idea of why this changed behavior ?
    I guess that $value is empty ??
    It looks like the rule trigger twice, and the second time there is no value parameter in the event (thus nil and the error when comparing value with <).
    You could add a log to see what event you get (and if there is no 'value' in it, that's the problem)
    Could it be that the co sensor sends 2 events for 2 different properties?
    Yes, you get the log changes as events these days - it was a request from some other user.
    Do this:
    In general, if you trigger with the event definition #device{id=..., value=..., property=...}
    always add the property name you want to match against as there can be different properties triggers that have a value
    If you match
    The c02sensor:value only matches with property name 'value'
    Hallo Jan,
    My HC3 is again connected.
    I have some errors;
    [26.05.2022] [14:48:00] [ERROR] [QUICKAPP1305]: main.lua:120: unexpected symbol near ')'
    Thansk in advance,
    //Sjakie
    2 hours ago, Sjakie said:
    Maybe like this:
    11 minutes ago, jwi said:
    Maybe like this:
    An extra '(' in the beginning?
    Hi, does ER4 has something like find my iPhone ? lately I bought HC3 and trying to move all functionalities from HC2 ER3 to new one, i'll be grateful for any help
    W dniu 28.03.2021 o 14:59, jgab napisał:
    This is the flow I use for ER4
    Hi again, is Node Red still supported, asking because when enabled I had this, did I miss something? :
    [27.05.2022] [22:54:01] [ERROR] [QUICKAPP22]: QuickApp crashed
    [27.05.2022] [22:54:01] [ERROR] [QUICKAPP22]: EventRunner.lua:83: attempt to index a nil value (global 'Nodered')
    Ok, first the global 'Nodered' should exist. What version of ER4 are you running?
    Secondly, I tested the Nodered code that is commented out in the main file
    and discovered a bug that I have fixed in v0.80 that I just pushed.
    thnx @jgab i'm using the latest one , ER4 v0.79, been installed by theQAUpdater v0.65
    Edited by domin12
    You should be able to update to 0.8 with QAUpdater now.
    Why the 'Nodered' global lua variable is not available is a mystery though.
    Can you add
    just before
    to see what value it has.
    @jgab to late , i updated it when you pushed new version,and what is wired, downgrade to 0.79 doesn't gave the error anymore
    Hi All, @jgab
    In ER4 i have that rule, it recives data from nodered  :
    rule("#bmw_s5 {msg='$msg'} => fibaro.call(74,'updateView','labelPsi','text','Front Left:'..msg.frontLeft.status.currentPressure/100)")
    [29.05.2022] [20:31:57] [ERROR] [QUICKAPP22]: in Rule:3[#bmw_s5 {msg='$msg'} => fibaro.call(74,'updateView','labelPsi','text','Front Lef...]: ./include/EventRunner.lua:1953: ./include/EventRunner.lua:1820: Bad arguments to between '...', 'Front Left:' '2.4'
    can You help to write correct rule?, right now it throwing an error. thnx
    '..' is not for concatenating string. '..' is reserved for the between operator.
    Ex. rule("88:breached & 10:00..15:00 => ....")
    Use '++' to concatenate strings
    However, I would recommend using the function 'fmt' - same as Lua's string.format - to create the text string. It will also allow you to control number of decimals
